    Again -- MMM-Navigate can't get installed.
    20 Posts 3 Posters 2.8k Views 3 Watching
      crowimu @sdetweil
      Thank you for your hint, ist somehow worked, but now I get this error, when starting:
      [2025-02-28 16:14:25.717] [LOG]   MMM-Navigate, listen on GPIO PINs (BCM): 16,20,21
      [2025-02-28 16:14:25.726] [ERROR] Whoops! There was an uncaught exception...
      [2025-02-28 16:14:25.748] [ERROR] Error: EINVAL: invalid argument, write
          at Object.writeFileSync (node:fs:2367:20)
          at exportGpio (/home/dietpi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:18:8)
          at new Gpio (/home/dietpi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:172:36)
          at Class.intializeRotary (/home/dietpi/MagicMirror/modules/MMM-Navigate/node_helper.js:36:15)
          at Class.socketNotificationReceived (/home/dietpi/MagicMirror/modules/MMM-Navigate/node_helper.js:110:10)
          at Socket.<anonymous> (/home/dietpi/MagicMirror/js/node_helper.js:91:10)
          at Socket.onevent (/home/dietpi/MagicMirror/node_modules/socket.io/dist/socket.js:462:26)
          at Socket._onpacket (/home/dietpi/MagicMirror/node_modules/socket.io/dist/socket.js:430:22)
          at /home/dietpi/MagicMirror/node_modules/socket.io/dist/client.js:214:24
          at process.processTicksAndRejections (node:internal/process/task_queues:77:11) {
        errno: -22,
        code: 'EINVAL',
        syscall: 'write'
      S R 2 Replies Last reply Reply Quote 0
        sdetweil @crowimu
        @crowimu ok, now i dont know. if pi5 it would be new way for gpio
        but pi2 i dont know, module author would gave to help
          rkorell @crowimu
          @crowimu
          I‘m not using this module and I do not know which of GPIO‘s you are using for your rotary encoder -
          In the module‘s description the author mentioned an eventually necessary modification for some of the PI‘s:
          On some Raspberry Pis it is neccesary to put the following line to /boot/config.txt for the GPIO where "rotary press (SW)" is connected:
          gpio=19=ip,pu
          Background: Sets your GPIO 19 as input (ip) and pull up (pu) Change the entry according to the GPIO pin you use.
          Have you double checked this?
          Your error-listing shows „invalid argument , write“ in some context to GPIO…
          May there is a topic for further investigation….
          Good luck!
          Regards,
          Ralf
            crowimu @rkorell
            @rkorell said in Again -- MMM-Navigate can't get installed.:
            gpio=19=ip,pu
            Thanks for your help, , but it did not solve the error.
            I still get:
            [2025-02-28 22:27:10.007] [ERROR] Whoops! There was an uncaught exception...
            [2025-02-28 22:27:10.011] [ERROR] Error: EINVAL: invalid argument, write
                at Object.writeFileSync (node:fs:2427:20)
                at process.processTicksAndRejections (node:internal/process/task_queues:85:11) {
              errno: -22,
              code: 'EINVAL',
              syscall: 'write'
            [2025-02-28 22:27:10.012] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [2025-02-28 22:27:10.013] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
              sdetweil @crowimu
              @crowimu and you rebooted?
                crowimu @sdetweil
                @sdetweil Yes, sure. I assume there must have been a change in the GPIO handling, but have not figured out where. :(
                R 3 Replies Last reply Reply Quote 0
                  rkorell @crowimu
                  @crowimu
                  Only thing that comes in my mind that you have either put cable on wrong GPIO or cable is broken.
                  As per default you have either to use GPIOPins: [26,20,19]//rotary cw, rotary ccw, rotary press (BCM Numbering - marked yellow in the above picture) or (if occupied) enter the correct BCM (!) numbers in config of module.
                  If this is all correct, module should work.
                    rkorell @crowimu
                    @crowimu Last thought - after some googeling…
                    Axled (the author has a thread about his module.
                    In one of his posting he stated
                    “rotation and click (Button press) uses the same library (onOff).”.
                    “node_modules/onoff/onoff” is part of your error-listing.
                    So I can imagine you need this onoff -library to read the GPIO-output.
                    Further research on this let me assume that onoff in some kind is associated to node.js (@sdetweil for sure knows more on this than me…).
                    At least one onoff library in this context is this one - but I’m not sure if this is the right one.
                    May you give it a try…
                    edit: I’ve just checked - on my own mirror there is NO onoff directory in “MagicMirror/node_modules/”
                    Good luck.
                    Ralf
                      rkorell @crowimu
                      @crowimu Found in completely different context another hint to onoff - also related to GPIO (in concrete a GPIO related implemetation of a rotary decoder).
                      There was a suggestion
                      npm install --save onoff@6.0.0
                      I currently only „assume“ that @6.0.0 is the version - cause the cited post is from 2021 there could be a new version.
                      A quick google delivers this page and this one stated
                      npm install onoff
                      Will do the trick…
                      Good luck.
                      Ralf
                        crowimu @rkorell
                        @rkorell Thank you and all others for the hints, however up to now I did not manage to get the ‘onoff’ and the MMM-Navigate module workingon my system.
                        I have recompiled onoff, installed it globally, changed the node version.
                        Nothing helped yet :(
                        I have started to create a simple module for my needs to control some fuctions with a rotary encoder,
                        https://github.com/crowimu/MMM-RotaryNav
                        It’s early stage, please wish me luck. :)
