    Again -- MMM-Navigate can't get installed.
    20 Posts 3 Posters 4.2k Views 3 Watching
      rkorell Module Developer @crowimu
      @crowimu
      I‘m not using this module and I do not know which of GPIO‘s you are using for your rotary encoder -
      In the module‘s description the author mentioned an eventually necessary modification for some of the PI‘s:
      On some Raspberry Pis it is neccesary to put the following line to /boot/config.txt for the GPIO where "rotary press (SW)" is connected:
      gpio=19=ip,pu
      Background: Sets your GPIO 19 as input (ip) and pull up (pu) Change the entry according to the GPIO pin you use.
      Have you double checked this?
      Your error-listing shows „invalid argument , write“ in some context to GPIO…
      May there is a topic for further investigation….
      Good luck!
      Regards,
      Ralf
      C 1 Reply Last reply
        crowimu @rkorell
        @rkorell said in Again -- MMM-Navigate can't get installed.:
        gpio=19=ip,pu
        Thanks for your help, , but it did not solve the error.
        I still get:
        [2025-02-28 22:27:10.007] [ERROR] Whoops! There was an uncaught exception...
        [2025-02-28 22:27:10.011] [ERROR] Error: EINVAL: invalid argument, write
            at Object.writeFileSync (node:fs:2427:20)
            at exportGpio (/home/dietpi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:18:8)
            at new Gpio (/home/dietpi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:172:36)
            at Class.intializeRotary (/home/dietpi/MagicMirror/modules/MMM-Navigate/node_helper.js:36:15)
            at Class.socketNotificationReceived (/home/dietpi/MagicMirror/modules/MMM-Navigate/node_helper.js:110:10)
            at Socket.<anonymous> (/home/dietpi/MagicMirror/js/node_helper.js:91:10)
            at Socket.onevent (/home/dietpi/MagicMirror/node_modules/socket.io/dist/socket.js:462:26)
            at Socket._onpacket (/home/dietpi/MagicMirror/node_modules/socket.io/dist/socket.js:430:22)
            at /home/dietpi/MagicMirror/node_modules/socket.io/dist/client.js:214:24
            at process.processTicksAndRejections (node:internal/process/task_queues:85:11) {
          errno: -22,
          code: 'EINVAL',
          syscall: 'write'
        [2025-02-28 22:27:10.012] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2025-02-28 22:27:10.013] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
          sdetweil @crowimu
          @crowimu and you rebooted?
            crowimu @sdetweil
            @sdetweil Yes, sure. I assume there must have been a change in the GPIO handling, but have not figured out where. :(
            R 3 Replies Last reply
              @crowimu
              Only thing that comes in my mind that you have either put cable on wrong GPIO or cable is broken.
              As per default you have either to use GPIOPins: [26,20,19]//rotary cw, rotary ccw, rotary press (BCM Numbering - marked yellow in the above picture) or (if occupied) enter the correct BCM (!) numbers in config of module.
              If this is all correct, module should work.
                @crowimu Last thought - after some googeling…
                Axled (the author has a thread about his module.
                In one of his posting he stated
                “rotation and click (Button press) uses the same library (onOff).”.
                “node_modules/onoff/onoff” is part of your error-listing.
                So I can imagine you need this onoff -library to read the GPIO-output.
                Further research on this let me assume that onoff in some kind is associated to node.js (@sdetweil for sure knows more on this than me…).
                At least one onoff library in this context is this one - but I’m not sure if this is the right one.
                May you give it a try…
                edit: I’ve just checked - on my own mirror there is NO onoff directory in “MagicMirror/node_modules/”
                Good luck.
                Ralf
                  @crowimu Found in completely different context another hint to onoff - also related to GPIO (in concrete a GPIO related implemetation of a rotary decoder).
                  There was a suggestion
                  npm install --save onoff@6.0.0
                  I currently only „assume“ that @6.0.0 is the version - cause the cited post is from 2021 there could be a new version.
                  A quick google delivers this page and this one stated
                  npm install onoff
                  Will do the trick…
                  Good luck.
                  Ralf
                    crowimu @rkorell
                    @rkorell Thank you and all others for the hints, however up to now I did not manage to get the ‘onoff’ and the MMM-Navigate module workingon my system.
                    I have recompiled onoff, installed it globally, changed the node version.
                    Nothing helped yet :(
                    I have started to create a simple module for my needs to control some fuctions with a rotary encoder,
                    https://github.com/crowimu/MMM-RotaryNav
                    It’s early stage, please wish me luck. :)
                    R 2 Replies Last reply
                      @crowimu
                      very unfortunate!
                      cross the fingers & good luck for you…
                      Ralf
                        @crowimu - Just a quick question: Have you considered to use a newer version of a Pi? A 4B or even 5?
                        Pi2 is somewhat old - may there is a kind of a root cause?
                        Regards,
                        Ralf
                        C 2 Replies Last reply
                          crowimu @rkorell
                          @rkorell Hi Ralf,
                          I think the quadcore RPi2 is quite sufficient for a Magic Mirror, but I’ve also tested it on a RPi3 with the same results.
                          I don’t like the power consumption of RPi4 and 5 and I also don’t like to add cooling fans to an SBC.
                          So up to now I have always used RPi Zero / Zero2 / RPi 1/2 and 3 smoothly for my projects. :)
                            crowimu @rkorell
                            @rkorell finally I got it solved :)
                            The issue is really the GPIO numbering, I found this SO thread:
                            https://stackoverflow.com/questions/78173749/use-raspberry-pi-4-gpio-with-node-js
                            It is also valid for Pi3 and Pi2
                            cat /sys/kernel/debug/gpio
                            gpiochip0: GPIOs 512-565, parent: platform/3f200000.gpio, pinctrl-bcm2835:
                             gpio-512 (ID_SDA              )
                             gpio-513 (ID_SCL              )
                             gpio-514 (GPIO2               )
                             gpio-515 (GPIO3               )
                             gpio-516 (GPIO4               )
                             gpio-517 (GPIO5               )
                             gpio-518 (GPIO6               )
                             gpio-519 (GPIO7               |spi0 CS1            ) out hi ACTIVE LOW
                             gpio-520 (GPIO8               |spi0 CS0            ) out hi ACTIVE LOW
                             gpio-521 (GPIO9               )
                             gpio-522 (GPIO10              )
                             gpio-523 (GPIO11              )
                             gpio-524 (GPIO12              )
                             gpio-525 (GPIO13              )
                             gpio-526 (GPIO14              )
                             gpio-527 (GPIO15              )
                             gpio-528 (GPIO16              )
                             gpio-529 (GPIO17              |sysfs               ) in  hi IRQ
                             gpio-530 (GPIO18              )
                             gpio-531 (GPIO19              )
                             gpio-532 (GPIO20              )
                             gpio-533 (GPIO21              )
                             gpio-534 (GPIO22              |sysfs               ) in  hi IRQ
                             gpio-535 (GPIO23              )
                             gpio-536 (GPIO24              )
                             gpio-537 (GPIO25              )
                             gpio-538 (GPIO26              )
                             gpio-539 (GPIO27              |sysfs               ) in  hi IRQ
                            I needed to set up the numbers according to the output
                            e.g. Pin27 is 539 in the MMM-Navigate config.
                            Now everything works so far as expected, thank you all for your help!
                              @crowimu COOL!
                              congratulations!
                              For me the “confusing” part was the fact that INSTALL doesn’t work…
                              Installing should NOT check GPIO pinouts …
                              Really great that you worked this out!
                              Warmest regards,
                              Ralf
                                A Pi4 or a Pi5 had solved this as well :-)
                                  sdetweil @rkorell
                                  @rkorell because MagicMirror is started with the electron binary, the compiled module code must match the engine version
                                  electron rebuild does that.
                                  tricky problem if not running under electron
                                  then npm rebuild works for nodejs engine match
                                  R 1 Reply Last reply
                                    @sdetweil said in Again -- MMM-Navigate can't get installed.:
                                    OK, sounds plausible.
                                    Thanks.
                                    Learned a lot, today :-)
                                    Regards,
                                    Ralf
