    MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder
    45 Posts 6 Posters 30.4k Views 5 Watching
    • E
      Eisblume
      @AxLed
      Also after clean install with nothing more, the default modules and MMM-Navigate and MMM-Remote-Controll it doesn’t work.
      Here you can see: https://youtu.be/G2eRoPxRPjU
      Only when I remove ground, the press action works. But then, the cw and cww doesn’t work…
      • A
        AxLed Module Developer
        @Eisblume
        Thanks for your reply, i tested at my pi with disconnected ground cable, but there is no press, cw or ccw working at all.
        My last ideas:
        • can you messure your 5 cables if maybe one is interrupted
        • maybe there are two versions of KY-040 on the marked, i have this one Amazon
        • is your second rotary encoder shows same symptoms?
        • did you connect + of rotary encoder to 5V once (which would be wrong and maybe damaged your GPIO PINs/chip)?
        AxLED
        • E
          Eisblume
          @AxLed
          Do not think that I am lying ;-), but it works fine, when I start MagicMirror and after that I start the python - script from here https://github.com/martinohanlon/KY040.
          cw, cww and press works absolutely fine.
          It is very strange.
          • E
            Eisblume
            @AxLed
            Ok, i fix it now for me.
            I know, it is a dirty code, but don’t found another solution :dizzy_face:
            I attached the KY040 python script in the node_helper.js. Then everything works fine.
            //node_helper.js
            /* Magic Mirror
             * Node Helper: {MMM-Navigate}
             * By {AxLED}
             * {MIT} Licensed.
             //Debugging
             //tail -f ~/.pm2/logs/mm-out-0.log
             //tail -f ~/.pm2/logs/mm-error-0.log
            const Gpio = require('onoff').Gpio;
            const spawn = require("child_process").spawn;
            //Variables
              start: function() {
            		var self = this;
            		this.loaded = false;
            		var process = spawn("python", ["/home/pi/Downloads/KY040/examples/python3.py"]);
            • A
              @Eisblume
              No Problem, i am glad it works for you now, so you also did your first coding experiance.
              AxLED
              • E
                Eisblume
                @AxLed
                Yes very interesting experiences :-) !
                Could you explain my how to start “Tagesschau in 100 Sekunden” in MMM-Navigate ??
                • A
                  @Eisblume
                  You need two things:
                  • first: a modules which is able to stream 100Sec Tagesschau, i made a fork see MMM-Podcast2
                  • second: the right config (i posting only the relevant part)
                  			module: 'MMM-Podcast2',
                  				omxargs: ' --win 0,0,1920,1080  -o both '
                  			module: "MMM-Navigate",
                  			header: "Navigation",
                  					Alias: [
                  						'Tagesschau 100 Sekunden',
                  						'Herunterfahren'
                  					Action: [
                  						{notification:'BUTTON_PRESSED',payload:''},
                  						{notification: "REMOTE_ACTION", payload: {action: "SHUTDOWN"}}
                  					GPIOPins: [26,20,19]//rotary cw, rotary ccw, rotary press (BCM Numbering)
                  AxLED
                  E 1 Reply Last reply
                  • E
                    Eisblume @AxLed
                    @AxLed said in MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder:
                    {notification:‘BUTTON_PRESSED’,payload:‘’},
                    Thanks. Works perfect !!!
                    • K
                      keineAhnung123
                      Hello @AxLed ,
                      Two things:
                      First
                      I have the same issue like @Eisblume :
                      The click doesnt work.
                      When i then start a sample code to test the rotary encoder (from like here), the click works in the sample code.
                      If i start the Magic Mirror after that again, then the click works there too.
                      Maybe there is a missing initialization of the rotary encoder in your code?
                      Second
                      Is there a possibility to get more config possibilities?
                      Like starting the module hidden or shortening the time of the hiding process?
                      Thanks in advance :)
                      • A
                        @keineAhnung123,
                        to your first issue:
                        • is only click not working or is rotation also not working?
                          Because rotation and click (Button press) uses the same library (onOff).
                        • on which pin is click connected, as the pi GPIO Pins have different features?
                        • what versions you are using (pi, OS, MM-Version)?
                        To your second issue.
                        • MMM-Navigate uses the MM notification system, so you can do almost everything you want. What are you trying to to, maybe i can give you a sample for your config.js
                        • for shortening time of hidding see MM Docs -> search for hide, there is a parameter for speed.
                        Regards
                        AxLED
                        • K
                          keineAhnung123
                          Hello @AxLed , thanks for your reply
                          first
                          • rotation works fine but the button press does not
                          • i use your standard configuration so it seems to be BCM 19
                          • PI 3 B+, stretch, MM 2.14.0
                          I tried MMM-Buttons too. Same problem there. I first have to run a sample script with python and after that the button works in MM too. It uses the onoff library too.
                          I found a strange behaviour:
                          I start MM -> button click doesnt work
                          I start python test script and after that MM -> button click works
                          When i restart the Raspberry PI and start MM (without the python test script) -> button click works
                          When i shutdown the Raspberry PI and cut off the connection to an electricity source and restart the PI after that -> button click doesnt work
                          Thats strange isnt it?
                          second
                          I changed the hiding time from 10000 to 2000 cause i prefer a shorter time.
                          Is there a way to start the module hidden?
                          I tried following:
                              // Define start sequence.
                              start: function() {
                                  this.sendConfig();//pass config to node_helper.js
                                  this.hide();
                          and this
                              //Helper, to use module without Rotary Encoder and without GPIO Pins, like developing in Pixel VM
                              notificationReceived: function(notification, payload) {
                                  if(notification === "CW" || notification === "CCW" || notification === "PRESSED"){
                                      this.naviaction({inputtype: ""+ notification +""});
                                  if(notification === "SHELLCOMMAND"){
                                       this.sendSocketNotification(notification, payload);
                                  if(notification === "MODULE_DOM_CREATED"){
                                       this.hide();
                          but both didnt take effect :(
                          third
                          I found an reproducable error:
                          When i start MM and first rotate counterclockwise there is an error in the MM console:
                          [09.01.2021 09:11.07.337] [LOG]   MMM-Navigate, listen on GPIO PINs (BCM): 26,20,19
                          [09.01.2021 09:11.18.306] [ERROR] Whoops! There was an uncaught exception...
                          [09.01.2021 09:11.18.321] [ERROR] ReferenceError: lastdir is not defined
                              at tick (/home/pi/MagicMirror/modules/MMM-Navigate/node_helper.js:92:39)
                              at /home/pi/MagicMirror/modules/MMM-Navigate/node_helper.js:66:4
                              at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:135:9
                              at Array.forEach (<anonymous>)
                              at pollerEventHandler (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:134:32)
                          It doesnt effect the functionality but just wanted to mention it… ;)
                          • A
                            @keineAhnung123,
                            thanks for feedback.
                            first:
                            Idea A:
                            • maybe the pin 19 is the problem, because it is not only a GPIO pin rather it has SPI features. Can you change to BCM16 (and change it in config.js as well) and try it?
                            Idea B:
                            • Do you use capacitors for debouncing? If not, you can change debouncing value of following line: https://github.com/Ax-LED/MMM-Navigate/blob/master/node_helper.js#L37
                            second:
                            • Which module should start hidden? MMM-Navigate?
                            third:
                            I tried to reproduce on my pi 3 and get no error, so i checked the code.
                            You can add following line as new line 19 in node_helper.js
                            var lastdir = '';
                            AxLED
                            • K
                              keineAhnung123
                              @AxLed
                              I will try that later. Thanks
                              And yes, i want to start MMM-Navigate hidden. Is that possible?
                              • A
                                @keineAhnung123 ,
                                informations to your second issue:
                                Your request is not provided by MMM-Navigate, maybe it is possible with one of the following modules (untested):
                                • MMM-ModuleScheduler
                                • MMM-ModuleToggle
                                AxLED
                                • K
                                  keineAhnung123
                                  Hello @AxLed
                                  first
                                  • Idea A: didnt solve the problem. Still no click
                                  • Idea B: I tried capacitors and software debouncing. Still no click
                                  I will use this python script to get the click working:
                                  import RPi.GPIO as GPIO
                                  GPIO.setmode(GPIO.BCM)
                                  BUTTON_PIN = 16
                                  GPIO.setup(BUTTON_PIN, GPIO.IN, pull_up_down = GPIO.PUD_UP)
                                  and start it within node_helper.js:
                                  var child_process = require('child_process');
                                  	// Subclass start method.
                                    start: function() {
                                  		var self = this;
                                  		this.createRoutes();
                                  		child_process.execFile('python', ['/home/pi/MagicMirror/modules/MMM-Navigate/ky-040-initialisieren.py']);
                                  Now it works.
                                  Btw: In intializeRotary-function (node_helper.js) there ist a CLK and DT.read and also a CLK and DT.watch instruction. For the SW there is only a SW.watch but not a read instruction. Is that right? Just wanted to mention. Im not an expert in programming.
                                  third
                                  Yes, the error is gone :)
                                  • A
                                    @keineAhnung123 ,
                                    thanks for your patience.
                                    to first:
                                    it seems to be something with the pullup / pulldown resistors, see also https://github.com/fivdi/onoff#configuring-pullup-and-pulldown-resistors
                                    See also the new “gpio” config command (https://www.raspberrypi.org/forums/viewtopic.php?f=117&t=208748)
                                    So here is another idea, can you try (based on informations mentione above):
                                    • (i suppose your SW pin is 16)
                                    • add following line in /boot/config.txt
                                      gpio=16=ip,pu
                                      Meaning: sets your GPIO 16 as input (ip) and pull up (pu)
                                    • if this doesnt work try:
                                      gpio=16=ip,pd
                                      Meaning: sets your GPIO 16 as input (ip) and pull down (pd)
                                    Maybe this way MMM-Navigate works without the python script.
                                    To SW.watch you mentioned, this is ok, as i dont need to know the initial state of SW.
                                    to third:
                                    • i added the line in node_helper.js in the github repo.
                                    Regards
                                    AxLED
                                    • K
                                      keineAhnung123
                                      @AxLed Now it works with gpio=16=ip,pu
                                      Do the changes in boot.txt affect the Raspberry Pi in any way i have to know?
                                      Thanks a lot so far :)
                                      • A
                                        @keineAhnung123,
                                        great to hear it works, i will update the readme at github.
                                        The line in config.txt only tells the pi at boottime, that GPIO16 is set to input and the internal resistor is set to pullup. So there is nothing else to know unless you change your GPIO Pins for something else.
                                        @Eisblume maybe this is a solution for your issue.
                                        AxLED
                                        R 1 Reply Last reply
                                          robiv8 @AxLed
                                          @AxLed
                                          also a great modul from you :-)
                                          I have tested and works fine. Two questions.
                                          When I press any selection, the module disappears.
                                          It fades out and the module below it jumps up. Why?
                                          Is it possible to control the MMM-Dreambox module with it? That would be great, of course.
                                          Thanks in advance
                                          • A
                                            @robiv8
                                            the modul MMM-Navigate disappears by design. If it is faded out and you use rotary or button it comes back on (fades in).
                                            Yes MMM-Dreambox can be controlled bei MMM-Navigate, see https://github.com/Ax-LED/MMM-Dreambox#further-options
                                            AxLED
                                            • 2 / 3
