    MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder
    45 Posts 6 Posters 30.4k Views 5 Watching
    • A
      AxLed Module Developer
      @Eisblume
      You need two things:
      • first: a modules which is able to stream 100Sec Tagesschau, i made a fork see MMM-Podcast2
      • second: the right config (i posting only the relevant part)
      			module: 'MMM-Podcast2',
      				omxargs: ' --win 0,0,1920,1080  -o both '
      			module: "MMM-Navigate",
      			header: "Navigation",
      					Alias: [
      						'Tagesschau 100 Sekunden',
      						'Herunterfahren'
      					Action: [
      						{notification:'BUTTON_PRESSED',payload:''},
      						{notification: "REMOTE_ACTION", payload: {action: "SHUTDOWN"}}
      					GPIOPins: [26,20,19]//rotary cw, rotary ccw, rotary press (BCM Numbering)
      AxLED
      E 1 Reply Last reply
      • E
        Eisblume @AxLed
        @AxLed said in MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder:
        {notification:‘BUTTON_PRESSED’,payload:‘’},
        Thanks. Works perfect !!!
        • K
          keineAhnung123
          Hello @AxLed ,
          Two things:
          First
          I have the same issue like @Eisblume :
          The click doesnt work.
          When i then start a sample code to test the rotary encoder (from like here), the click works in the sample code.
          If i start the Magic Mirror after that again, then the click works there too.
          Maybe there is a missing initialization of the rotary encoder in your code?
          Second
          Is there a possibility to get more config possibilities?
          Like starting the module hidden or shortening the time of the hiding process?
          Thanks in advance :)
          • A
            @keineAhnung123,
            to your first issue:
            • is only click not working or is rotation also not working?
              Because rotation and click (Button press) uses the same library (onOff).
            • on which pin is click connected, as the pi GPIO Pins have different features?
            • what versions you are using (pi, OS, MM-Version)?
            To your second issue.
            • MMM-Navigate uses the MM notification system, so you can do almost everything you want. What are you trying to to, maybe i can give you a sample for your config.js
            • for shortening time of hidding see MM Docs -> search for hide, there is a parameter for speed.
            Regards
            AxLED
            • K
              keineAhnung123
              Hello @AxLed , thanks for your reply
              first
              • rotation works fine but the button press does not
              • i use your standard configuration so it seems to be BCM 19
              • PI 3 B+, stretch, MM 2.14.0
              I tried MMM-Buttons too. Same problem there. I first have to run a sample script with python and after that the button works in MM too. It uses the onoff library too.
              I found a strange behaviour:
              I start MM -> button click doesnt work
              I start python test script and after that MM -> button click works
              When i restart the Raspberry PI and start MM (without the python test script) -> button click works
              When i shutdown the Raspberry PI and cut off the connection to an electricity source and restart the PI after that -> button click doesnt work
              Thats strange isnt it?
              second
              I changed the hiding time from 10000 to 2000 cause i prefer a shorter time.
              Is there a way to start the module hidden?
              I tried following:
                  // Define start sequence.
                  start: function() {
                      this.sendConfig();//pass config to node_helper.js
                      this.hide();
              and this
                  //Helper, to use module without Rotary Encoder and without GPIO Pins, like developing in Pixel VM
                  notificationReceived: function(notification, payload) {
                      if(notification === "CW" || notification === "CCW" || notification === "PRESSED"){
                          this.naviaction({inputtype: ""+ notification +""});
                      if(notification === "SHELLCOMMAND"){
                           this.sendSocketNotification(notification, payload);
                      if(notification === "MODULE_DOM_CREATED"){
                           this.hide();
              but both didnt take effect :(
              third
              I found an reproducable error:
              When i start MM and first rotate counterclockwise there is an error in the MM console:
              [09.01.2021 09:11.07.337] [LOG]   MMM-Navigate, listen on GPIO PINs (BCM): 26,20,19
              [09.01.2021 09:11.18.306] [ERROR] Whoops! There was an uncaught exception...
              [09.01.2021 09:11.18.321] [ERROR] ReferenceError: lastdir is not defined
                  at tick (/home/pi/MagicMirror/modules/MMM-Navigate/node_helper.js:92:39)
                  at /home/pi/MagicMirror/modules/MMM-Navigate/node_helper.js:66:4
                  at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:135:9
                  at Array.forEach (<anonymous>)
                  at pollerEventHandler (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:134:32)
              It doesnt effect the functionality but just wanted to mention it… ;)
              • A
                @keineAhnung123,
                thanks for feedback.
                first:
                Idea A:
                • maybe the pin 19 is the problem, because it is not only a GPIO pin rather it has SPI features. Can you change to BCM16 (and change it in config.js as well) and try it?
                Idea B:
                • Do you use capacitors for debouncing? If not, you can change debouncing value of following line: https://github.com/Ax-LED/MMM-Navigate/blob/master/node_helper.js#L37
                second:
                • Which module should start hidden? MMM-Navigate?
                third:
                I tried to reproduce on my pi 3 and get no error, so i checked the code.
                You can add following line as new line 19 in node_helper.js
                var lastdir = '';
                AxLED
                • K
                  keineAhnung123
                  @AxLed
                  I will try that later. Thanks
                  And yes, i want to start MMM-Navigate hidden. Is that possible?
                  • A
                    @keineAhnung123 ,
                    informations to your second issue:
                    Your request is not provided by MMM-Navigate, maybe it is possible with one of the following modules (untested):
                    • MMM-ModuleScheduler
                    • MMM-ModuleToggle
                    AxLED
                    • K
                      keineAhnung123
                      Hello @AxLed
                      first
                      • Idea A: didnt solve the problem. Still no click
                      • Idea B: I tried capacitors and software debouncing. Still no click
                      I will use this python script to get the click working:
                      import RPi.GPIO as GPIO
                      GPIO.setmode(GPIO.BCM)
                      BUTTON_PIN = 16
                      GPIO.setup(BUTTON_PIN, GPIO.IN, pull_up_down = GPIO.PUD_UP)
                      and start it within node_helper.js:
                      var child_process = require('child_process');
                      	// Subclass start method.
                        start: function() {
                      		var self = this;
                      		this.loaded = false;
                      		this.createRoutes();
                      		child_process.execFile('python', ['/home/pi/MagicMirror/modules/MMM-Navigate/ky-040-initialisieren.py']);
                      Now it works.
                      Btw: In intializeRotary-function (node_helper.js) there ist a CLK and DT.read and also a CLK and DT.watch instruction. For the SW there is only a SW.watch but not a read instruction. Is that right? Just wanted to mention. Im not an expert in programming.
                      third
                      Yes, the error is gone :)
                      • A
                        @keineAhnung123 ,
                        thanks for your patience.
                        to first:
                        it seems to be something with the pullup / pulldown resistors, see also https://github.com/fivdi/onoff#configuring-pullup-and-pulldown-resistors
                        See also the new “gpio” config command (https://www.raspberrypi.org/forums/viewtopic.php?f=117&t=208748)
                        So here is another idea, can you try (based on informations mentione above):
                        • (i suppose your SW pin is 16)
                        • add following line in /boot/config.txt
                          gpio=16=ip,pu
                          Meaning: sets your GPIO 16 as input (ip) and pull up (pu)
                        • if this doesnt work try:
                          gpio=16=ip,pd
                          Meaning: sets your GPIO 16 as input (ip) and pull down (pd)
                        Maybe this way MMM-Navigate works without the python script.
                        To SW.watch you mentioned, this is ok, as i dont need to know the initial state of SW.
                        to third:
                        • i added the line in node_helper.js in the github repo.
                        Regards
                        AxLED
                        • K
                          keineAhnung123
                          @AxLed Now it works with gpio=16=ip,pu
                          Do the changes in boot.txt affect the Raspberry Pi in any way i have to know?
                          Thanks a lot so far :)
                          • A
                            @keineAhnung123,
                            great to hear it works, i will update the readme at github.
                            The line in config.txt only tells the pi at boottime, that GPIO16 is set to input and the internal resistor is set to pullup. So there is nothing else to know unless you change your GPIO Pins for something else.
                            @Eisblume maybe this is a solution for your issue.
                            AxLED
                            R 1 Reply Last reply
                              robiv8 @AxLed
                              @AxLed
                              also a great modul from you :-)
                              I have tested and works fine. Two questions.
                              When I press any selection, the module disappears.
                              It fades out and the module below it jumps up. Why?
                              Is it possible to control the MMM-Dreambox module with it? That would be great, of course.
                              Thanks in advance
                              • A
                                @robiv8
                                the modul MMM-Navigate disappears by design. If it is faded out and you use rotary or button it comes back on (fades in).
                                Yes MMM-Dreambox can be controlled bei MMM-Navigate, see https://github.com/Ax-LED/MMM-Dreambox#further-options
                                AxLED
                                  robiv8 @AxLed
                                  @AxLed
                                  Hallo,
                                  is there a way to deaktivate this Fade out? i want it olways on.
                                  Thanks Robi
                                  OK Sorry, i found it by my self :-)
                                  in MMM-Navigate.js
                                  // this.hide(10000);
                                  • 2 / 3
