Change layout based on orientation?
13 Posts 2 Posters 1.4k Views 2 Watching
  • G Offline
    gonzonia
    I’ve had my mirror in a portrait for a long time. I was thinking of playing around with changing it to landscape and started wondering if i was possible to have the layout change based on browser orientation. I know there’s CSS that can be used to move things around based on orientation (https://developer.mozilla.org/en-US/docs/Web/CSS/@media/orientation) , but I was wondering if there was any way to use that to actually move which modules were in what region.
    S 1 Reply Last reply Mar 1, 2025, 7:36 PM Reply Quote 0
      sdetweil @gonzonia
      @gonzonia modules are hard coded to position.
      while the exact location and size changes by device orientation
      the logical placement is the same
      you could create another config.js or make those variables
      and use the envsub/template support to change the variable definitions in the script that starts MagicMirror
      using older xrandr
      #!/bin/bash
      orientation=$(xrandr | grep " connected" | awk '{print $2 " " $3 " " $4}')
      if [[ $orientation == *"left"* ]]; then
        echo "Screen orientation: left"
      elif [[ $orientation == *"right"* ]]; then
        echo "Screen orientation: right"
      elif [[ $orientation == *"inverted"* ]]; then
        echo "Screen orientation: inverted"
      else
        echo "Screen orientation: normal"
      fi
      see https://docs.magicmirror.builders/configuration/introduction.html#configuration-template-system
      G 1 Reply Last reply Mar 1, 2025, 7:48 PM Reply Quote 0
      • G Offline
        gonzonia @sdetweil
        @sdetweil That’s on the server side though. I was thinking more at the client side, so that you could have multiple clients using a single server with different views.
        For example:
        I have a pi hooked up to a monitor in the kitchen running MM in portrait.
        It might be nice to have it up on the TV in another room or on a second monitor while I’m working. Those will be in landscape.
        I think it can be done with shifting CSS mostly(https://forum.magicmirror.builders/topic/13197/change-the-regions-positions). But modules that use full screen might be a challenge.
        S 1 Reply Last reply Mar 1, 2025, 7:57 PM Reply Quote 0
          sdetweil @gonzonia
          @gonzonia yeh screen shifting is different than module shifting
          you can certainly detect the orientation in css
          on another app i support
          :root{
            --scale-factor: 1;  /* set default scaling in case we have partial window, debug or in vm terminal window */
            --design-width: 1920px;
            --design-height: 1080px;
          @media screen and (orientation: landscape) {
              :root{
                  --scale-factor: var(width) / var(--design-width);
           @media screen and (orientation: portrait) {
              :root{
                  --scale-factor: var(width) / var(--design-height);
          /*@media screen and (width:3840px)  and (orientation: landscape) {
              :root{
              --scale-factor: width/var(--design-width);
          @media  screen and (width:1080px)   {
              :root{
          G 1 Reply Last reply Mar 1, 2025, 8:06 PM Reply Quote 0
          • G Offline
            gonzonia @sdetweil
            @sdetweil Yeah the challenge I’m having with the way I’ve chosen to lay things out is that I have things in the top left, top center, and top right. They are just below things in the top bar on the vertical screen. Using the CSS from the post that shifts them They are still below the top bar but I kind of want them to the right of the top bar. I’m plying with it to see what I can do, but since they are all part of the same container, I’m not sure I can.
            S 1 Reply Last reply Mar 1, 2025, 8:11 PM Reply Quote 0
              sdetweil @gonzonia
              @gonzonia there is a moduke that can
              move dynamically
              https://github.com/Toreke/MMM-Dynamic-Modules
              but it needs notifications
              S 1 Reply Last reply Mar 1, 2025, 8:14 PM Reply Quote 0
                @gonzonia or start a different instance on a different port for landscape
                G 1 Reply Last reply Mar 1, 2025, 8:17 PM Reply Quote 0
                • G Offline
                  gonzonia @sdetweil
                  @sdetweil That’s a thought. I think I can probably adapt the Dynamic Modules to allow for a config option to adjust based on orientation and that gets triggered at the ALL_MODULES_STARTED notification from the core.
                  Let me fork that and see if I can make that work.
                  S 1 Reply Last reply Mar 1, 2025, 8:49 PM Reply Quote 0
                    sdetweil @gonzonia
                    @gonzonia create your own module
                    send the notifications when it matters
                    lot easier
                    G 1 Reply Last reply Mar 1, 2025, 9:05 PM Reply Quote 0
                    • G Offline
                      gonzonia @sdetweil
                      @sdetweil Maybe. I find it easier to build on someone else’s code. After I have some basic stuff functioning, I’ll look for a module template to work from. I’m also not sure the dynamic module will work (it’s 7 years old) so it might need to be updated anyhow.
                      S 1 Reply Last reply Mar 1, 2025, 9:06 PM Reply Quote 0
