    Change layout based on orientation?
    13 Posts 2 Posters 8.5k Views 2 Watching
    • G Offline
      gonzonia
      I’ve had my mirror in a portrait for a long time. I was thinking of playing around with changing it to landscape and started wondering if i was possible to have the layout change based on browser orientation. I know there’s CSS that can be used to move things around based on orientation (https://developer.mozilla.org/en-US/docs/Web/CSS/@media/orientation) , but I was wondering if there was any way to use that to actually move which modules were in what region.
        sdetweil @gonzonia
        @gonzonia modules are hard coded to position.
        while the exact location and size changes by device orientation
        the logical placement is the same
        you could create another config.js or make those variables
        and use the envsub/template support to change the variable definitions in the script that starts MagicMirror
        using older xrandr
        #!/bin/bash
        orientation=$(xrandr | grep " connected" | awk '{print $2 " " $3 " " $4}')
        if [[ $orientation == *"left"* ]]; then
          echo "Screen orientation: left"
        elif [[ $orientation == *"right"* ]]; then
          echo "Screen orientation: right"
        elif [[ $orientation == *"inverted"* ]]; then
          echo "Screen orientation: inverted"
        else
          echo "Screen orientation: normal"
        fi
        see https://docs.magicmirror.builders/configuration/introduction.html#configuration-template-system
        • G Offline
          gonzonia @sdetweil
          @sdetweil That’s on the server side though. I was thinking more at the client side, so that you could have multiple clients using a single server with different views.
          For example:
          I have a pi hooked up to a monitor in the kitchen running MM in portrait.
          It might be nice to have it up on the TV in another room or on a second monitor while I’m working. Those will be in landscape.
          I think it can be done with shifting CSS mostly(https://forum.magicmirror.builders/topic/13197/change-the-regions-positions). But modules that use full screen might be a challenge.
            sdetweil @gonzonia
            @gonzonia yeh screen shifting is different than module shifting
            you can certainly detect the orientation in css
            on another app i support
            :root{
              --scale-factor: 1;  /* set default scaling in case we have partial window, debug or in vm terminal window */
              --design-width: 1920px;
              --design-height: 1080px;
            @media screen and (orientation: landscape) {
                :root{
                    --scale-factor: var(width) / var(--design-width);
             @media screen and (orientation: portrait) {
                :root{
                    --scale-factor: var(width) / var(--design-height);
            /*@media screen and (width:3840px)  and (orientation: landscape) {
                :root{
                --scale-factor: width/var(--design-width);
            @media  screen and (width:1080px)   {
                :root{
            • G Offline
              gonzonia @sdetweil
              @sdetweil Yeah the challenge I’m having with the way I’ve chosen to lay things out is that I have things in the top left, top center, and top right. They are just below things in the top bar on the vertical screen. Using the CSS from the post that shifts them They are still below the top bar but I kind of want them to the right of the top bar. I’m plying with it to see what I can do, but since they are all part of the same container, I’m not sure I can.
                sdetweil @gonzonia
                @gonzonia there is a moduke that can
                move dynamically
                https://github.com/Toreke/MMM-Dynamic-Modules
                but it needs notifications
                  @gonzonia or start a different instance on a different port for landscape
                  • G Offline
                    gonzonia @sdetweil
                    @sdetweil That’s a thought. I think I can probably adapt the Dynamic Modules to allow for a config option to adjust based on orientation and that gets triggered at the ALL_MODULES_STARTED notification from the core.
                    Let me fork that and see if I can make that work.
                      sdetweil @gonzonia
                      @gonzonia create your own module
                      send the notifications when it matters
                      lot easier
                      • G Offline
                        gonzonia @sdetweil
                        @sdetweil Maybe. I find it easier to build on someone else’s code. After I have some basic stuff functioning, I’ll look for a module template to work from. I’m also not sure the dynamic module will work (it’s 7 years old) so it might need to be updated anyhow.
                          sdetweil @gonzonia
                          @gonzonia all you need is a
                          notificationReceived
                          “DOM_OBJECTS_CREATED”
                          if the width is greater than the height its landscape
                          then loop thru the config
                          • G Offline
                            gonzonia @sdetweil
                            @sdetweil I’m going to make it more dynamic. There’s actually screen.orientation.type that works to get landscape vs portrait
                              sdetweil @gonzonia
                              @gonzonia sameo
