    Adjust modules size to match each other (weather/calendar)
    11 Posts 5 Posters 18.8k Views 3 Watching
    • tosti007T Offline
      tosti007 Module Developer @l8kerjuan
      @l8kerjuan did you change the values of font-size? I didn’t check, but I assume those are the default values
      If there is anything don't hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      • L Offline
        l8kerjuan @tosti007
        @tosti007 which font size do i change? all the same. what does the xsmall-xlarge effect?
        tosti007T 1 Reply Last reply Reply Quote 0
        • tosti007T Offline
          @l8kerjuan xsmall means extra small, xlarge means extra large. No not all the same then different font sizes won’t have any effect. Instead you should either add or subtract a certain amount from all of them
          L 1 Reply Last reply Reply Quote 2
          • L Offline
            l8kerjuan @tosti007
            @tosti007 thanks… played with it and figured it out… no rhyme or reason that i could figure out or tried to figure out… got it working though… thanks!!!
            tosti007T brobergB 2 Replies Last reply Reply Quote 1
            • tosti007T Offline
              @l8kerjuan good to hear, you’re welcome!
              • brobergB Offline
                broberg Project Sponsor @l8kerjuan
                @l8kerjuan It’s up to the the person who made the module, the xsmall, small etc are all classes that can be assigned to different divs in the module,
                checking the .js file for each module you can see what part of the module the classes are used on.
                As for the calendar, the normal class is used on the events.
                • L Offline
                  l8kerjuan @broberg
                  @broberg got it. thank you!
