    Made a birthday module
    39 Posts 4 Posters 16.1k Views 5 Watching
    • X
      xIExodusIx
      Hi cgillinger,
      I tested your new modul, MMM-Birthday-Paged, sadly it does not work for me, it should shown up on my MagicMirror on Page 1 with a lot of more informations, it does, firework and confetti work well, but it kills all of my other Informations on that page and the icons in front and back of the “gratulation text” will not be displayed, exactly as mentioned in my post some Days earlier.
      For me this version of yor Modul must have its own Page.
      C 1 Reply Last reply
        cgillinger @xIExodusIx
        @xIExodusIx On the first issue, that is, currently, by design as I outline in my previous post. I’m looking into if there is a method to fix it, but Im not there yet.
        On the second issue that sounds like a font problem. What system are you on?
        • X
          xIExodusIx
          @cgillinger Hi cglinger,
          I’m using a Raspberry Pi 4B 4GB with RaspiOS Bookworm
          MM Version is 2.30,
          npm Version is 10.9.2,
          node Version is 23.6.1.
          I hope this would help.
            @xIExodusIx said in Made a birthday module:
            MM Version is 2.30,
            I think RaspiOS is missing the font. It might be solved by issuing:
            sudo apt update
            sudo apt upgrade -y
            sudo apt install -y fonts-noto-color-emoji fonts-symbola ttf-ancient-fonts
            and then rebuild font cache
            sudo fc-cache -f -v
            Then restarting Magic Mirror and/or Pi.
            And if I get the time, Ill look into a more elegant solution.
            X 1 Reply Last reply
            • X
              xIExodusIx @cgillinger
              @cgillinger said in Made a birthday module:
              MM Version is 2.30,
              sudo apt update
              sudo apt upgrade -y
              sudo fc-cache -f -v
              Thank you :-) , this solved my problem with the funny Icons in front and then end of the text.
              Now the last problem(s) is to tell your Module not to hijack the whole page for itself and not to ignore the position where to be displayd on the mirror.
              Your Module is really great, because there is a little bit of (funny) action on the mirror :-)
              I’m sure you will solve the two Problems too an I’m looking forward for that. :-)
                @xIExodusIx I believe I’ve solved the issue where MMM-Birthday-Pages was taking over the entire screen when active. There’s now a new toggle, immersiveMode, which can be set to either “true” or “false”.
                "false" allows the birthday celebration to overlay existing modules while keeping them visible.
                "true" means only the birthday celebration is displayed, hiding everything else.
                This also means you can have different behaviors on different Pages.
                That said, I’ve only had time for a quick test, and it worked as expected on my Linux Mint installation. To be safe, I’ve uploaded it to a separate test repository. If it proves to be stable, I’ll merge it into the main one (I’m sure there are easier ways to do this, but I suck at Git). Repo URL:
                https://github.com/cgillinger/mmm-Birthday-paged-test (and please note that you need to rename the folder to “mmm-Birthday-paged” after cloning)
                So, give it a try and let me know how it goes!
                • X
                  @cgillinger
                  Hi cgillinger,
                  I installe your new module “MMM-Birthday-Pages-test” as described, and added the “immersiveMode” to the MM2 main config file.
                  It seems to work partly, it accepted the positon, on my MM2 “lower_third”, but it ignores the page and it shows some debug informations with green text on the left side by partly hiding the funny icon and parts of the gratulation text.
                  The fireworks is displayd on fullscreen but in my short test i can’t see the confetti.
                  A little idea for make it for user a bit easier: make it possible to set the firworks in the MM2 main config-file instead to copy it from to… somthing like “Fireworks: “spiral”” and let it load directly out of the of the “…/fireworks/” folder instead to copy it to the MMM-Birthday-Paged folder.
                  I will install the “old” MMM-Birthday-paged" and install it as I had it before. It has its own page on my MM2, and it worked very well.
                    @xIExodusIx Hi!
                    First, the green debug code was displayed because I forgot to set it to “false” by default. You can change this in config.js, but I’ll update the default setting so it only appears when the user wants it (ie when setting “true” in config.js).
                    Second, the module still has some quirks in its startup behavior—it requires a full cycle before everything runs smoothly. I’m working on it, but to be honest, it’s a low-priority fix since it’s a fringe case. Typically, the module will be running continuously, so birthday initialization should trigger when the mirror is already active. That’s probably why you’re not seeing the confetti right away.
                    Third, regarding the different versions of Fireworks—absolutely! The reason there are multiple versions is simply that I left them in from my experiments. I didn’t originally plan to include that functionality, but once the core features are fully ironed out, I’d be happy to refine and expand on it.
                    As for positioning, the module is currently designed to use the entire screen. I might look into allowing more customization in the future, but for now, it just places the message in the center and then launches confetti and fireworks.
                    When you say it “ignores the page,” are you referring to the page cycling?
                    I’ve also attached my test config.js. It has three pages, and after cycling through them to align the timings, the expected behavior should be:
                    Page 1 – Normal modules
                    Page 2 – Birthday celebration with dimming
                    Page 3 – Birthday celebration without dimming
                    Test config.js (which needs MMM-page-indicator). I’ve let this run for about an hour now, and everything (apart from weather module because its not part of the test) works as intended:
                    /* MagicMirror² Config for testing MMM-Birthday-Paged with immersiveMode */
                    let config = {
                        address: "localhost",
                        port: 8080,
                        basePath: "/",
                        useHttps: false,
                        httpsPrivateKey: "",
                        httpsCertificate: "",
                        language: "en",
                        locale: "en-US",
                        logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                        timeFormat: 24,
                        units: "metric",
                                module: "alert",
                                module: "clock",
                                classes: "page1 page3" // Show on page 1 and 3
                                header: "Holidays",
                                classes: "page1 page3", // Show on page 1 and 3
                                            symbol: "calendar-check",
                                            url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                                module: "weather",
                                    weatherProvider: "yr",
                                    type: "current",
                                    locationID: "2673730", // Stockholm's ID
                                    roundTemp: true
                                module: "compliments",
                                position: "lower_third",
                            // MMM-Birthday-Paged with immersiveMode = true (dims modules)
                                module: "MMM-Birthday-Paged",
                                position: "middle_center",
                                classes: "page2", // Show on page 2
                                    birthdays: [
                                        // Today's date (March 16, 2025) with name John
                                        { name: "John", date: "03-16" }
                                    fireworkDuration: "infinite",
                                    confettiDuration: "infinite",
                                    immersiveMode: true, // Dims other modules
                                    debug: true,
                                    startupDelay: 500 // Shorter startup delay for testing
                            // MMM-Birthday-Paged with immersiveMode = false (original module behavior)
                                classes: "page3", // Show on page 3
                                    birthdays: [
                                    immersiveMode: false, // Does NOT dim other modules
                                    debug: true,
                            // Page indicator to see which page is showing
                                module: "MMM-page-indicator",
                                position: "bottom_bar",
                                    pages: 3
                            // MMM-pages for page switching
                                module: "MMM-pages",
                                        ["page1"],   // Page 1 - Normal modules
                                        ["page2"],   // Page 2 - Birthday celebration with dimming
                                        ["page3"]    // Page 3 - Birthday celebration without dimming
                                    fixed: ["alert", "MMM-page-indicator"],
                                    rotationTime: 15000, // 15 seconds between page changes
                                    rotationDelay: 15000,
                                    animationTime: 1000
                    plainbrokeP 1 Reply Last reply
                    • plainbrokeP
                      plainbroke @cgillinger
                      @cgillinger
                      Instead of infinite can a time be used in the 2 Duration fields?
                      If I set it to the same value as my pages rotate in, I was wondering if that might fix the problem of it over riding into my other pages.?
                      Just a thought, but do you think it would work?
                        cgillinger @plainbroke
                        @plainbroke Yes, that might do the trick! If MagicMirror manages to keep the two settings in sync.
