    I cannot disable screen blanking with MagicMirrorOS
    27 Posts 3 Posters 5.5k Views 3 Watching
      smegbadger
      Hi
      I am running MM via MagicMirrorOS on a RPi4B with an RPi monitor in portrait. I use MMM-Universal-Pir to turn the screen on and off during the day (with wlr-randr commands) which works great but the screen switches off for good overnight, the PIR cannot wake it up. I have disabled Screen Blanking with raspi-config but that makes no difference.
      If I run wlr-randr in the labwc container (access via docker exec -it labwc bash) I normally get (some resolutions removed for brevity):
      HDMI-A-1 "Raspberry PI RPI MON156 81005568472 (HDMI-A-1)"
        Make: Raspberry PI
        Model: RPI MON156
        Serial: xxxxxxxxxxxx
        Physical size: 350x190 mm
        Enabled: yes
        Modes:
          1920x1080 px, 60.000000 Hz (preferred, current)
          640x480 px, 59.939999 Hz
        Position: 0,0
        Transform: 90
        Scale: 1.000000
        Adaptive Sync: disabled
      However, once the display has gone to sleep that same wlr-randr command gives
      failed to connect to display
      this make me feel it is something in the docker set up but i see nothing in the docker logs
      Note that I also have RANDR_PARAMS="--output HDMI-A-1 --transform 90" in the .env file to rotate the display at boot.
      Cheers
      Steve
      • karsten13K Offline
        karsten13 @smegbadger
        @smegbadger said in I cannot disable screen blanking with MagicMirrorOS:
        @karsten13 thank you for all the effort you are putting into this issue.
        Well, it is a pleasure to have such a good tester as you
        I agree, let’s go back to the version that will kill and restart the container if the display doesn’t respond to wlr-randr (and then waits for a MMM-Universal-Pir cycle to sleep it again).
        for now I did exactly this, but this issue is still working in my brain …
        So to revert all the changes done before:
        cd /opt/mm
        git switch master
        git pull
        Change the images back to latest in .env:
        MM_IMAGE="karsten13/magicmirror:latest"
        LABWC_IMAGE="karsten13/labwc:latest"
        Get new images and restart:
        cd /opt/mm/run
        docker compose pull
        docker compose up -d
        Last point: You should add the --transform 90 to the onCommand of the MMM-Universal-Pir config:
                                module: "MMM-Universal-Pir",
                                        deactivateDelay: 30000,
                                        onCommand: "wlr-randr --output HDMI-A-1 --transform 90 --on",
          sdetweil @smegbadger
          @smegbadger have you turned off screen blanking on the docker host? ubuntu or whatever owns the actual display?
            smegbadger
            Hi
            I don’t know where that would be. The RPi boots to a login prompt. Then docker takes over and launches MM in electron. There is no GUI for me to fiddle with
            Steve
              @smegbadger @karsten13 will have to advise
                karsten13 @sdetweil
                the setup is “Raspberry Pi OS Lite” with the normal docker setup and an additional labwc container
                @smegbadger
                I have no idea what is happening. Sounds like the monitor totally cuts the connection to the pi after a while.
                Maybe this post contains something helpful.
                What is your wlr-randr command for waking up?
                  @smegbadger if you stop mmos does the screen still turn off overnight?
                    smegbadger
                    @sdetweil I stopped docker at 9:30 last night with docker compose down leaving the screen at the magicmirror login prompt. This morning the screen was still showing the login prompt . MM was reinstated perfectly with docker compose up -d --force-recreate. @karsten13 I notice there are now four objects that start:
                    [+] Running 4/4
                     ✔ Network magicmirror_default  Created        0.1s
                     ✔ Container mm                 Started        0.9s
                     ✔ Container init               Started        1.0s
                     ✔ Container labwc              Started        1.0s
                    Steve
                      @smegbadger
                      the 4 objects are o.k., one network and 3 containers (init is only for setting correct permissions in the mount folders, it runs for a very short time, you can disable it in the .env file if wanted).
                      Question: When the failed to connect to display occurs, how do you get the screen back working? Is a docker rm -f labwc && docker compose up -d sufficient or a docker compose up -d --force-recreate? Or do you have do reboot? Or do you switch the monitor off and on?
                      Other idea is to implement a wlr-randr call every 30min. in the labwc container.
                        smegbadger
                        @karsten13 i have disabled the init container as suggested.
                        When the display fails I can get it back with docker rm -f labwc && docker compose up -d (docker compose up -d --force-recreate also works but docker compose up -d on it’s own doesn’t). I am running it today with the MMM-Universal-Pir module disabled as another test (although when sitting at a login prompt it never went off).
                        Note that the display fails after a few hours of no PIR trigger, it doesn’t have to be overnight.
                        Steve
                          so restarting only the labwc container solves the problem …
                          I will try to build a labwc container which executes wlr-randr e.g. every 30min. so we can see if this helps.
