    I cannot disable screen blanking with MagicMirrorOS
    27 Posts 3 Posters 10.6k Views 3 Watching
      sdetweil @smegbadger
      @smegbadger @karsten13 will have to advise
      karsten13K 1 Reply Last reply
      • karsten13K
        karsten13 @sdetweil
        the setup is “Raspberry Pi OS Lite” with the normal docker setup and an additional labwc container
        @smegbadger
        I have no idea what is happening. Sounds like the monitor totally cuts the connection to the pi after a while.
        Maybe this post contains something helpful.
        What is your wlr-randr command for waking up?
          @smegbadger if you stop mmos does the screen still turn off overnight?
            smegbadger
            @sdetweil I stopped docker at 9:30 last night with docker compose down leaving the screen at the magicmirror login prompt. This morning the screen was still showing the login prompt . MM was reinstated perfectly with docker compose up -d --force-recreate. @karsten13 I notice there are now four objects that start:
            [+] Running 4/4
             ✔ Network magicmirror_default  Created        0.1s
             ✔ Container mm                 Started        0.9s
             ✔ Container init               Started        1.0s
             ✔ Container labwc              Started        1.0s
            Steve
            • karsten13K
              karsten13 @smegbadger
              @smegbadger
              the 4 objects are o.k., one network and 3 containers (init is only for setting correct permissions in the mount folders, it runs for a very short time, you can disable it in the .env file if wanted).
              Question: When the failed to connect to display occurs, how do you get the screen back working? Is a docker rm -f labwc && docker compose up -d sufficient or a docker compose up -d --force-recreate? Or do you have do reboot? Or do you switch the monitor off and on?
              Other idea is to implement a wlr-randr call every 30min. in the labwc container.
                smegbadger
                @karsten13 i have disabled the init container as suggested.
                When the display fails I can get it back with docker rm -f labwc && docker compose up -d (docker compose up -d --force-recreate also works but docker compose up -d on it’s own doesn’t). I am running it today with the MMM-Universal-Pir module disabled as another test (although when sitting at a login prompt it never went off).
                Note that the display fails after a few hours of no PIR trigger, it doesn’t have to be overnight.
                Steve
                • karsten13K
                  @smegbadger said in I cannot disable screen blanking with MagicMirrorOS:
                  so restarting only the labwc container solves the problem …
                  I will try to build a labwc container which executes wlr-randr e.g. every 30min. so we can see if this helps.
                  • karsten13K
                    karsten13 @karsten13
                    @karsten13 said in I cannot disable screen blanking with MagicMirrorOS:
                    you can now test with a new labwc container which does the wlr-randr call every 15min. but I’m not sure this helps …
                    For testing change this line in the .env file
                    LABWC_IMAGE="karsten13/labwc:develop"
                    and then do a docker compose pull && docker compose up -d
                      smegbadger
                      @karsten13 unfortunately that change did not prevent the display from dropping. There’s no time timestamp in the docker logs for labwc but when i looked this morning there were some 40 calls to wlr-randr that had failed. If they are every 15mins that’s about 10:00 it failed. I will make a more accurate observation tonight
                      • karsten13K
                        @smegbadger
                        I expected this already …
                        can you post the exact error message of wlr-randr when it fails?
                        Other point: What happens if you disable MMM-Universal-Pir for a test? Are you still getting the errors or does mm runs correctly over night?
                        • karsten13K
                          for testing I added wlopm to the current mm-develop docker image.
                          So for another test use this lines in the .env file
                          MM_IMAGE="karsten13/magicmirror:develop"
                          Then change the on/off commands in the config.js
                                                  module: "MMM-Universal-Pir",
                                                          onCommand: "wlopm --on HDMI-A-1",
                                                          offCommand: "wlopm --off HDMI-A-1",
                            smegbadger
                            @karsten13 I left it running overnight with the MMM-Universal-Pir config lines commented out and the monitor physically switched off and this morning MM was still working fine when I switched the monitor back on again. When I looked at docker logs labwc the wlr-randr command was failing (still being triggered every fifteen mins) which suggests the connection between the MMM-Universal-Pir and the display driver is the issue rather than the display actually going off. I will try your new build today although i will have to add --transform 90 to the onCommand to get my screen rotation.
                            magicm@magicmirror:/opt/mm/mounts/config $ docker logs labwc
                            HDMI-A-1 "Raspberry PI RPI MON156 81005568472 (HDMI-A-1)"
                              Make: Raspberry PI
                              Model: RPI MON156
                              Serial: 81005568472
                              Physical size: 350x190 mm
                              Enabled: yes
                              Modes:
                                1920x1080 px, 60.000000 Hz (preferred, current)
                                1920x1080 px, 59.939999 Hz
                                1920x1080 px, 50.000000 Hz
                                1920x1080 px, 48.000000 Hz
                                1920x1080 px, 47.952000 Hz
                                1280x720 px, 60.000000 Hz
                                1280x720 px, 59.939999 Hz
                                1280x720 px, 50.000000 Hz
                                1280x720 px, 48.000000 Hz
                                1280x720 px, 47.952000 Hz
                                720x576 px, 50.000000 Hz
                                720x480 px, 60.000000 Hz
                                720x480 px, 59.939999 Hz
                                640x480 px, 60.000000 Hz
                                640x480 px, 59.939999 Hz
                              Position: 0,0
                              Transform: 90
                              Scale: 1.000000
                              Adaptive Sync: disabled
                            magicm@magicmirror:/opt/mm/mounts/config $ docker exec -it labwc bash
                            pi@c7c64f70849e:/$ wlr-randr
                            pi@c7c64f70849e:/$
                            Steve
                              smegbadger
                              @karsten13 my apologies, I see the transform is not needed as you have taken the rotation into account
                                smegbadger
                                @karsten13 the display failed today as before but we have timestamps in the labwc docker logs
                                magicm@magicmirror:~ $ docker logs labwc
                                00:00:00.000 [INFO] [seatd/seat.c:48] Created VT-bound seat seat0
                                00:00:00.000 [INFO] [seatd/seatd.c:194] seatd started
                                00:00:00.052 [INFO] [seatd/server.c:145] New client connected (pid: 17, uid: 1000, gid: 1000)
                                00:00:00.052 [INFO] [seatd/seat.c:239] Added client 1 to seat0
                                00:00:00.052 [INFO] [seatd/seat.c:563] Opened client 1 on seat0
                                00:00:00.120 [ERROR] [EGL] command: eglQueryDeviceStringEXT, error: EGL_BAD_PARAMETER (0x300c), message: "eglQueryDeviceStringEXT"
                                executing: wlr-randr --output HDMI-A-1 --transform 90
                                Sat Mar 29 08:14:25 UTC 2025
                                  Make: Raspberry PI
                                  Model: RPI MON156
                                  Serial: 81005568472
                                  Enabled: yes
                                  Modes:
                                  Position: 0,0
                                  Transform: 90
                                  Scale: 1.000000
                                Sat Mar 29 08:29:25 UTC 2025
                                  Make: Raspberry PI
                                  Model: RPI MON156
                                  Serial: 81005568472
                                  Enabled: yes
                                  Modes:
                                  Position: 0,0
                                  Transform: 90
                                  Scale: 1.000000
                                Sat Mar 29 13:14:26 UTC 2025
                                  Make: Raspberry PI
                                  Model: RPI MON156
                                  Serial: 81005568472
                                  Enabled: yes
                                  Modes:
                                  Position: 0,0
                                  Transform: 90
                                  Scale: 1.000000
                                Sat Mar 29 13:29:26 UTC 2025
                                Sat Mar 29 13:44:26 UTC 2025
                                Sat Mar 29 13:59:26 UTC 2025
                                Sat Mar 29 14:14:26 UTC 2025
                                Sat Mar 29 14:29:26 UTC 2025
                                Sat Mar 29 14:44:26 UTC 2025
                                Sat Mar 29 14:59:26 UTC 2025
                                Sat Mar 29 15:14:26 UTC 2025
                                Sat Mar 29 15:29:26 UTC 2025
                                Sat Mar 29 15:44:26 UTC 2025
                                Sat Mar 29 15:59:26 UTC 2025
                                Sat Mar 29 16:14:26 UTC 2025
                                There's also a new item in the `mm` docker logs when I restarted the docker containers on my return
                                Gdk-Message: 16:25:24.348: Error reading events from display: Broken pipe
                                [entrypoint 16:25:25.533] [INFO]   ***WARNING*** could write to /etc/localtime
                                [entrypoint 16:25:25.539] [INFO]   copy default modules
                                [entrypoint 16:25:25.603] [INFO]   copy css files
                                Steve
                                • karsten13K
                                  @smegbadger
                                  I build another new labwc image. You can revert the changes done to MM_IMAGE and the on-/offCommand in your setup.
                                  The new karsten13/labwc:develop now runs labwc with pid=1 (I thought that was already the case) and additionally kills labwc if the wlr-randr command fails with failed to connect to display.
                                  Now the container will restart if labwc is terminated inside the container. This does not address the root issue but should be a good workaround (hopefully).
                                  So please do again a docker compose pull && docker compose up -d to get the latest changes …
                                    smegbadger
                                    @karsten13, thank you for this. It worked well overnight last night. One question: when the wlr-randr command fails, the labwc container is then killed and then automatically restarts - will the screen be turned on then until the next PIR activity and subsequent timeout of MMM-Universal-Pir?
                                    Steve
                                    • karsten13K
                                      yes, I tested this by killing and restarting the labwc-container from outside.
                                      Not nice but I have no idea how to solve this.
                                        smegbadger
                                        @karsten13 I thought that would be the case. I tried changing the initial RANDR_PARAMS="--output HDMI-A-1 --transform 90" in the .env file to RANDR_PARAMS="--output HDMI-A-1 --off" so that the MMM-Universal-Pir module would be responsible for the first switch on of the display but then I got no display on restart at all.
                                        Steve
                                        karsten13K 2 Replies Last reply
                                        • karsten13K
                                          @smegbadger
                                          had to write it down:
                                          labwc	after start			wlr-randr --output HDMI-A-1 --transform 90
                                          mm	starts and mm is displayed
                                          mm	offCommand			wlr-randr --output HDMI-A-1 --off
                                          mm	still up but not displayed
                                          labwc	fails after a while, killed
                                          mm	still up and displayed again
                                          so another idea would be to execute the command defined in RANDR_PARAMS only if the display is not switched off. Will check if I can get this information …
                                          • karsten13K
                                            @smegbadger
                                            I think I have now a working solution for this.
                                            For testing
                                            use LABWC_IMAGE="karsten13/labwc:develop" in .env.
                                            In /opt/mm do
                                            # check if worktree is clean
                                            git status
                                            # switch to develop branch
                                            git switch develop
                                            # pull
                                            git pull
                                            Go to /opt/mm/run and execute docker compose pull and docker compose up -d --force-recreate.
                                            With these changes the screen should still be blank after a restart of the labwc-container if the screen was blank before. Let me know if it works.
