    MMM-GoogleMapsTraffic
    10 Posts 3 Posters 3.2k Views 4 Watching
    • K Offline
      kmanne
      I am trying to add Google Maps Traffic for my MagicMirror and having issues with it.
      I am receiving an error with “Sorry, Something went wrong. This page didnt load Google Maps correctly. See the JavaScript console for technical details.”
      I am using https://github.com/vicmora/MMM-GoogleMapsTraffic repo and having the above error and when I tried git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git the module isn’t displaying.
      Am I missing something or Do I need to use any different repo?
      Note: I have my API key with a credit card activated.
      • K Offline
        kmanne
        Thank You @sdetweil & @chrisfr1976 . I have verified the module in depth and the issue is with the API key. I have generated a new API Key and I can load the Google Maps now.
        Really appreciate your assistance.
          sdetweil @kmanne
          @kmanne i will have to look at my fork, later today
            sdetweil @kmanne
            @kmanne I used my fork and added my apikey
            using the default config example in the doc
              chrisfr1976 @sdetweil
              See also my fork: MMM-GoogleMapsTraffic.
              Runs fine without any issue since months.
              Regards, Chris.
              K 1 Reply Last reply Reply Quote 1
              • K Offline
                kmanne
                • K Offline
                  kmanne @chrisfr1976
                  @chrisfr1976 - I have been using Google Maps since 3 weeks and I noticed that the maps doesnt get updated with traffic unless I zoom out or zoom in. It is displaying the maps with traffic the last time I zoomed out or zoomed in. I dont see API calls in my google profile as well. Did you notice this on your end?
                  S C 2 Replies Last reply Reply Quote 0
                    sdetweil @kmanne
                    @kmanne the module should refresh the info every 15 minutes (default updateInterval setting)
                      chrisfr1976 @kmanne
                      @kmanne I can check next weekend. I‘m not at home at the moment. .
                      Regards, Chris.
                      • K Offline
                        kmanne @sdetweil
                        @sdetweil - Correct. But it is not updating the maps unless I zoom out or zoom in.
                        I tried adding the refresh of 15 mins in the module, but still the same issue.
                          chrisfr1976 @kmanne
                          @kmanne
                          I’ve just updated the code to a more robust solution with more log entry. Use git pull in the MMM-GoogleMapsTraffic-module folder.
                          Check if it works for you. Check the console logs of any issues.
                          Regards, Chris.
