    MMM-GoogleMapsTraffic
    10 Posts 3 Posters 1.6k Views 4 Watching
      sdetweil @kmanne
      @kmanne I used my fork and added my apikey
      using the default config example in the doc
        chrisfr1976 @sdetweil
        See also my fork: MMM-GoogleMapsTraffic.
        Runs fine without any issue since months.
        Regards, Chris.
        K 1 Reply Last reply Reply Quote 1
        • K Offline
          kmanne
          Thank You @sdetweil & @chrisfr1976 . I have verified the module in depth and the issue is with the API key. I have generated a new API Key and I can load the Google Maps now.
          Really appreciate your assistance.
          • K Offline
            kmanne @chrisfr1976
            @chrisfr1976 - I have been using Google Maps since 3 weeks and I noticed that the maps doesnt get updated with traffic unless I zoom out or zoom in. It is displaying the maps with traffic the last time I zoomed out or zoomed in. I dont see API calls in my google profile as well. Did you notice this on your end?
            S C 2 Replies Last reply Reply Quote 0
              sdetweil @kmanne
              @kmanne the module should refresh the info every 15 minutes (default updateInterval setting)
                chrisfr1976 @kmanne
                @kmanne I can check next weekend. I‘m not at home at the moment. .
                Regards, Chris.
                • K Offline
                  kmanne @sdetweil
                  @sdetweil - Correct. But it is not updating the maps unless I zoom out or zoom in.
                  I tried adding the refresh of 15 mins in the module, but still the same issue.
                    chrisfr1976 @kmanne
                    @kmanne
                    I’ve just updated the code to a more robust solution with more log entry. Use git pull in the MMM-GoogleMapsTraffic-module folder.
                    Check if it works for you. Check the console logs of any issues.
                    Regards, Chris.
