    MMM-CalendarExt3Agenda doesn't work on fresh restored install
    11 Posts 2 Posters 2.6k Views 2 Watching
      sdetweil @rkorell
      @rkorell ~/MagicMirror/installers/restore.log
        rkorell @sdetweil
        @sdetweil :-)
        nmp install DOES the trick!
        (should have come to my mind !!!)
        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-CalendarExt3Agenda $ npm install
        > mmm-calendarext3agenda@1.4.6 postinstall
        > git submodule update --init --recursive
        Submodule 'CX3_Shared' (https://github.com/MMRIZE/CX3_Shared) registered for path 'CX3_Shared'
        Cloning into '/home/pi/MagicMirror/modules/MMM-CalendarExt3Agenda/CX3_Shared'...
        Submodule path 'CX3_Shared': checked out '0b390e2770866533464c81e5b26ff366e9695344'
        up to date, audited 1 package in 1s
        found 0 vulnerabilities
        Thanks!
        Calendar is present, again!
        Nice!
        Now all I’m missing is MMM-Pir :-)
        Just frickling around but cannot get this git-cloned from backup-repository …
        thanks a LOT!
        Ralf
        • R rkorell has marked this topic as solved on
          sdetweil @rkorell
          @rkorell pushed fix for restore script to check for postinstall task as well as dependencies
          the new 3rd party list uses package.json as a documentation vehicle…
          but that doesn’t mean npm install is required… try not to do work that isn’t required and not consume disk space for no reason…
            sdetweil @rkorell
            @rkorell said in MMM-CalendarExt3Agenda doesn't work on fresh restored install:
            yes, I only save the LINK to the module repo, which doesn’t exist anymore
            you can’t binary back it up either, as there are OS level dependencies
            I produce a warning in the output (and log file) that the url is not available
            in both backup and restore…
              rkorell @sdetweil
              @sdetweil said in MMM-CalendarExt3Agenda doesn't work on fresh restored install:
              I’ve “solved” it with my tar.gz archive.
              put all of the working copy in it, extract im MagicMirror/modules and ran npm install in MMM-Pir …
              Now I’m looking around how to get xandr fixed, because now MMM-Pir increase the screen resolution to maximum which is not desired …
                sdetweil @rkorell
                yeh, what about the other 200+ users?? SO much fun
                  rkorell @sdetweil
                  @sdetweil despite getting it “run” it doesn’t work properly :-(
                  I’m looking around but seems to be hard …
                    sdetweil @rkorell
                    @rkorell yes, he ran some setup/installer code that isn’t saved locally
