    My new MagicMirror will not start with Wayland?
    17 Posts 2 Posters 4.9k Views 2 Watching
      sdetweil @rkorell
      @rkorell electron saves a bunch of info , you may need to erase that to allow it to save different info
      stop MagicMirror
      rm -rf ~/.config/Electron
      note the dot in front of config
        @sdetweil Thanks!
        overall it doesn’t work for me :-(
        system is so slow that even editing config.js took 8 seconds to load the tiny file from pi to Laptop…
        So I’ve re-configured to X11 …
        NO idea what happened but unusable with wayland.
        In addition the target of whole szenario - to get MMM-Pir working without error message is not reached because with wayland, too an error is produced …
        So I will stay with X11 and try MMM-Pir-universal …
        (which is kinda unreliable…)
        Warm regards,
        Ralf
          sdetweil @rkorell
          @rkorell note that npm start issues npm run start:x11
            @sdetweil said in My new MagicMirror will not start with Wayland?:
            ? can you kindly please eloborate?
            Didn’t get you, sorry!
              quick question: will this command help, anyway to get “performance” fixed?
              Background: Since running on Pi5 / bookworm the mirror has “problems” on reboot.
              Module load is extremely slow (minutes!).
              A “pm2 reload MagicMirror” after reboot leads to way faster module loadings.
              Thanks,
              Ralf
                sdetweil @rkorell
                @rkorell said in My new MagicMirror will not start with Wayland?:
                no idea
                  sdetweil @rkorell
                  from package.json
                  these are the command types you can issue npm run …
                                  "start": "npm run start:x11",
                                  "start:dev": "npm run start -- dev",
                                  "start:wayland": "WAYLAND_DISPLAY=\"${WAYLAND_DISPLAY:=wayland-1}\" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland",
                                  "start:wayland:dev": "npm run start:wayland -- dev",
                                  "start:windows": ".\\node_modules\\.bin\\electron js\\electron.js",
                                  "start:windows:dev": "npm run start:windows -- dev",
                                  "start:x11": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                                  "start:x11:dev": "npm run start -- dev",
                  if you do npm start or npm run start
                  the command is “npm run start:x11”
                  which is the “same” as it was before release 2.30.0
                  I posted this in
                  https://forum.magicmirror.builders/topic/19269/new-magicmirror-start-options-in-version-2-30-0
                  so at least you don’t have to edit package.json and break updates…
                    sdetweil @rkorell
                    @rkorell I can ‘fix’ MagicMirror.sh to detect wayland/labwc and use
                    and if not
                    npm run start
                    switching so it WORKS seems like it takes some drastic changes…(erase electron config)…
                    I don’t know what is in the electron config folder, so can’t tell if there is a way to know you switched since last run…
                    • R rkorell has marked this topic as solved on
                      @sdetweil As I wrote initially “npm run start:wayland” doesn’t work …
                      (despite wayland configured).
                      And the “stored” auto-start option npm run start:x11 DOES work - for whatever reason.
                      VNC was really sluggish on this, performance a nightmare so - see above marked as “solution” I switched back to x11 and all is working fine.
                      In the meantime I’ve also managed to get MMM-Pir to work by idenitfying and correcting two errors in Bugsounet’s code …
                      Warm regards,
                      Ralf
                      S 2 Replies Last reply Reply Quote 1
                        sdetweil @rkorell
                        @rkorell great work!
                          sdetweil @rkorell
                          @rkorell i am thinking of pushing a change to mm.sh to run with what is detected
                          this is for new installs, i wont change existing on update
                          updated, release on next rev
                            Ohhh - this from you!
                            Makes me proud.
                            Thanks!
                            Ralf
                              @rkorell my updated mm.sh fails when trying wayland, some fontconfig problem
                              apt upgrade /full-upgrade fail… oh so much fun…
                              but npm start works!?
                                @sdetweil said in
                                Not tried.
                                Leave it currently, as is.
                                Via your install script provided autostart calls npm run start:x11 - which works fine.
                                Regards,
                                Ralf
                                  sdetweil @rkorell
                                  @rkorell yeh, i put it back
