    My new MagicMirror will not start with Wayland?
    17 Posts 2 Posters 5.1k Views 2 Watching
      @sdetweil said in My new MagicMirror will not start with Wayland?:
      rm -rf ~/.config/Electron
      quick question: will this command help, anyway to get “performance” fixed?
      Background: Since running on Pi5 / bookworm the mirror has “problems” on reboot.
      Module load is extremely slow (minutes!).
      A “pm2 reload MagicMirror” after reboot leads to way faster module loadings.
      Thanks,
      Ralf
      S 2 Replies Last reply
        sdetweil @rkorell
        @rkorell said in My new MagicMirror will not start with Wayland?:
        no idea
          sdetweil @rkorell
          Didn’t get you, sorry!
          from package.json
          these are the command types you can issue npm run …
                          "start": "npm run start:x11",
                          "start:dev": "npm run start -- dev",
                          "start:wayland": "WAYLAND_DISPLAY=\"${WAYLAND_DISPLAY:=wayland-1}\" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland",
                          "start:wayland:dev": "npm run start:wayland -- dev",
                          "start:windows": ".\\node_modules\\.bin\\electron js\\electron.js",
                          "start:windows:dev": "npm run start:windows -- dev",
                          "start:x11": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                          "start:x11:dev": "npm run start -- dev",
          if you do npm start or npm run start
          the command is “npm run start:x11”
          which is the “same” as it was before release 2.30.0
          I posted this in
          https://forum.magicmirror.builders/topic/19269/new-magicmirror-start-options-in-version-2-30-0
          so at least you don’t have to edit package.json and break updates…
            sdetweil @rkorell
            @rkorell I can ‘fix’ MagicMirror.sh to detect wayland/labwc and use
            and if not
            npm run start
            switching so it WORKS seems like it takes some drastic changes…(erase electron config)…
            I don’t know what is in the electron config folder, so can’t tell if there is a way to know you switched since last run…
            R 1 Reply Last reply
            • R rkorell has marked this topic as solved on
              @sdetweil As I wrote initially “npm run start:wayland” doesn’t work …
              (despite wayland configured).
              And the “stored” auto-start option npm run start:x11 DOES work - for whatever reason.
              VNC was really sluggish on this, performance a nightmare so - see above marked as “solution” I switched back to x11 and all is working fine.
              In the meantime I’ve also managed to get MMM-Pir to work by idenitfying and correcting two errors in Bugsounet’s code …
              Warm regards,
              Ralf
                sdetweil @rkorell
                @rkorell great work!
                  sdetweil @rkorell
                  @rkorell i am thinking of pushing a change to mm.sh to run with what is detected
                  this is for new installs, i wont change existing on update
                  updated, release on next rev
                    Ohhh - this from you!
                    Makes me proud.
                    Thanks!
                    Ralf
                      @rkorell my updated mm.sh fails when trying wayland, some fontconfig problem
                      apt upgrade /full-upgrade fail… oh so much fun…
                      but npm start works!?
                        @sdetweil said in
                        Not tried.
                        Leave it currently, as is.
                        Via your install script provided autostart calls npm run start:x11 - which works fine.
                        Regards,
                        Ralf
                          sdetweil @rkorell
                          @rkorell yeh, i put it back
