    My new MagicMirror will not start with Wayland?
    17 Posts 2 Posters 5.0k Views 2 Watching
      sdetweil @rkorell
      @rkorell note that npm start issues npm run start:x11
        @sdetweil said in My new MagicMirror will not start with Wayland?:
        ? can you kindly please eloborate?
        Didn’t get you, sorry!
          rm -rf ~/.config/Electron
          quick question: will this command help, anyway to get “performance” fixed?
          Background: Since running on Pi5 / bookworm the mirror has “problems” on reboot.
          Module load is extremely slow (minutes!).
          A “pm2 reload MagicMirror” after reboot leads to way faster module loadings.
          Thanks,
          Ralf
            sdetweil @rkorell
            @rkorell said in My new MagicMirror will not start with Wayland?:
            no idea
              sdetweil @rkorell
              from package.json
              these are the command types you can issue npm run …
                              "start": "npm run start:x11",
                              "start:dev": "npm run start -- dev",
                              "start:wayland": "WAYLAND_DISPLAY=\"${WAYLAND_DISPLAY:=wayland-1}\" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland",
                              "start:wayland:dev": "npm run start:wayland -- dev",
                              "start:windows": ".\\node_modules\\.bin\\electron js\\electron.js",
                              "start:windows:dev": "npm run start:windows -- dev",
                              "start:x11": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                              "start:x11:dev": "npm run start -- dev",
              if you do npm start or npm run start
              the command is “npm run start:x11”
              which is the “same” as it was before release 2.30.0
              I posted this in
              https://forum.magicmirror.builders/topic/19269/new-magicmirror-start-options-in-version-2-30-0
              so at least you don’t have to edit package.json and break updates…
                sdetweil @rkorell
                @rkorell I can ‘fix’ MagicMirror.sh to detect wayland/labwc and use
                and if not
                npm run start
                switching so it WORKS seems like it takes some drastic changes…(erase electron config)…
                I don’t know what is in the electron config folder, so can’t tell if there is a way to know you switched since last run…
                • R rkorell has marked this topic as solved on
                  @sdetweil As I wrote initially “npm run start:wayland” doesn’t work …
                  (despite wayland configured).
                  And the “stored” auto-start option npm run start:x11 DOES work - for whatever reason.
                  VNC was really sluggish on this, performance a nightmare so - see above marked as “solution” I switched back to x11 and all is working fine.
                  In the meantime I’ve also managed to get MMM-Pir to work by idenitfying and correcting two errors in Bugsounet’s code …
                  Warm regards,
                  Ralf
                  S 2 Replies Last reply Reply Quote 1
                    sdetweil @rkorell
                    @rkorell great work!
                      sdetweil @rkorell
                      @rkorell i am thinking of pushing a change to mm.sh to run with what is detected
                      this is for new installs, i wont change existing on update
                      updated, release on next rev
                        Ohhh - this from you!
                        Makes me proud.
                        Thanks!
                        Ralf
                          @rkorell my updated mm.sh fails when trying wayland, some fontconfig problem
                          apt upgrade /full-upgrade fail… oh so much fun…
                          but npm start works!?
                            @sdetweil said in
                            Not tried.
                            Leave it currently, as is.
                            Via your install script provided autostart calls npm run start:x11 - which works fine.
                            Regards,
                            Ralf
                              sdetweil @rkorell
                              @rkorell yeh, i put it back
