    My new MagicMirror will not start with Wayland?
    17 Posts 2 Posters 4.6k Views 2 Watching
      rkorell Module Developer
      Good Morning!
      after my last posting regarding display-stop with X11 (MMM-Universal-Pir) I’ve decided to try to get things to run with Wayland.
      Unfortunately this doesn’t work :-(
      I’ve disabled X11 / enabled Wayland in raspi-config and done a reboot.
      Magic Mirror than doesn’t come up - no surprise.
      issued
       pm2 stop MagicMirror
      [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 0 ])
      [PM2] [MagicMirror](0) ✓
      │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
      │ 0  │ MagicMirror    │ default     │ 2.31.0… │ fork    │ 0        │ 0      │ 0    │ stopped   │ 0%       │ 0b       │ pi       │ disabled │
      Then I’ve tried
      npm run start:wayland
      This exits with an error message from electron :
      pi@MagicMirrorPi5:~/MagicMirror $ npm run start:wayland
      > magicmirror@2.31.0-develop start:wayland
      > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland
      [2025-03-28 10:27:47.902] [LOG]   Starting MagicMirror: v2.31.0-develop
      [2025-03-28 10:27:47.912] [LOG]   Loading config ...
      [2025-03-28 10:27:47.913] [LOG]   config template file not exists, no envsubst
      [2025-03-28 10:27:48.094] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
      [2025-03-28 10:27:48.151] [INFO]  Your configuration file doesn't contain syntax errors :)
      [2025-03-28 10:27:48.152] [INFO]  Checking modules structure configuration ...
      [2025-03-28 10:27:48.193] [INFO]  Your modules structure configuration doesn't contain errors :)
      [2025-03-28 10:27:48.194] [LOG]   Loading module helpers ...
      [2025-03-28 10:27:48.195] [LOG]   No helper found for module: alert.
      [2025-03-28 10:27:48.195] [LOG]   No helper found for module: MMM-MagicMover.
      [2025-03-28 10:27:48.195] [LOG]   No helper found for module: clock.
      [2025-03-28 10:27:48.196] [LOG]   No helper found for module: MMM-Profilepicture.
      [2025-03-28 10:27:48.204] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.204] [LOG]   Module helper loaded: MMM-Logging
      [2025-03-28 10:27:48.211] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.211] [LOG]   Module helper loaded: MMM-MoonPhase
      [2025-03-28 10:27:48.211] [LOG]   No helper found for module: MMM-Globe.
      [2025-03-28 10:27:48.211] [LOG]   No helper found for module: weather.
      [2025-03-28 10:27:48.237] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.237] [LOG]   Module helper loaded: MMM-JsonValue
      [2025-03-28 10:27:48.244] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.245] [LOG]   Module helper loaded: MMM-MyGarbage
      [2025-03-28 10:27:48.245] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
      [2025-03-28 10:27:48.328] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.328] [LOG]   Module helper loaded: MMM-Todoist
      [2025-03-28 10:27:48.359] [LOG]   2025-03-28T10:27:48 <log> init module helper birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:15 Class.init)
      [2025-03-28 10:27:48.359] [LOG]   Module helper loaded: birthdaylist
      [2025-03-28 10:27:48.360] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.360] [LOG]   Module helper loaded: MMM-SystemMonitor
      [2025-03-28 10:27:48.470] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.470] [LOG]   Check MagicMirror² version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.31.0-develop
      [2025-03-28 10:27:48.470] [LOG]   Version is ok!
      [2025-03-28 10:27:48.470] [LOG]   Module helper loaded: MMM-Strava
      [2025-03-28 10:27:48.470] [LOG]   No helper found for module: MMM-EventHorizon.
      [2025-03-28 10:27:48.501] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.501] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
      [2025-03-28 10:27:48.618] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.619] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
      [2025-03-28 10:27:48.619] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.619] [LOG]   Module helper loaded: MMM-SystemInfo
      [2025-03-28 10:27:48.647] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.647] [LOG]   Module helper loaded: newsfeed
      [2025-03-28 10:27:48.647] [LOG]   No helper found for module: MMM-UselessFacts.
      [2025-03-28 10:27:48.667] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.667] [LOG]   Module helper loaded: MMM-Remote-Control
      [2025-03-28 10:27:48.709] [LOG]   Initializing new module helper ...
      [2025-03-28 10:27:48.709] [LOG]   Module helper loaded: calendar
      [2025-03-28 10:27:48.710] [LOG]   All module helpers loaded.
      [2025-03-28 10:27:48.713] [LOG]   Starting server on port 8080 ...
      [2025-03-28 10:27:48.714] [WARN]  You're using a full whitelist configuration to allow for all IPs
      [2025-03-28 10:27:49.037] [LOG]   Server started ...
      [2025-03-28 10:27:49.037] [LOG]   Connecting socket for: MMM-Logging
      [2025-03-28 10:27:49.038] [LOG]   2025-03-28T10:27:49 <log> Module helper started for MMM-Logging (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:19 Class.start)
      [2025-03-28 10:27:49.039] [LOG]   Connecting socket for: MMM-MoonPhase
      [2025-03-28 10:27:49.039] [LOG]   Starting module helper: MMM-MoonPhase
      [2025-03-28 10:27:49.044] [LOG]   Connecting socket for: MMM-JsonValue
      [2025-03-28 10:27:49.045] [LOG]   Connecting socket for: MMM-MyGarbage
      [2025-03-28 10:27:49.045] [LOG]   2025-03-28T10:27:49 <log> Starting node_helper for module: MMM-MyGarbage (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_helper.js:9 Class.start)
      [2025-03-28 10:27:49.046] [LOG]   Connecting socket for: MMM-Todoist
      [2025-03-28 10:27:49.047] [LOG]   2025-03-28T10:27:49 <log> Starting node helper for: MMM-Todoist (/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js:19 Class.start)
      [2025-03-28 10:27:49.047] [LOG]   Connecting socket for: birthdaylist
      [2025-03-28 10:27:49.047] [LOG]   Connecting socket for: MMM-SystemMonitor
      [2025-03-28 10:27:49.048] [LOG]   Starting module helper: MMM-SystemMonitor
      [2025-03-28 10:27:49.048] [LOG]   Connecting socket for: MMM-Strava
      [2025-03-28 10:27:49.050] [LOG]   2025-03-28T10:27:49 <log> Starting module helper: MMM-Strava (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:47 Class.start)
      [2025-03-28 10:27:49.051] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
      [2025-03-28 10:27:49.052] [LOG]   2025-03-28T10:27:49 <log> Starting module: MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:28 Class.start)
      [2025-03-28 10:27:49.053] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
      [2025-03-28 10:27:49.053] [LOG]   Connecting socket for: MMM-SystemInfo
      [2025-03-28 10:27:49.053] [LOG]   Starting node helper: MMM-SystemInfo
      [2025-03-28 10:27:49.054] [LOG]   Connecting socket for: newsfeed
      [2025-03-28 10:27:49.054] [LOG]   Starting node helper for: newsfeed
      [2025-03-28 10:27:49.054] [LOG]   Connecting socket for: MMM-Remote-Control
      [2025-03-28 10:27:49.055] [LOG]   Starting node helper for: MMM-Remote-Control
      [2025-03-28 10:27:49.060] [LOG]   Connecting socket for: calendar
      [2025-03-28 10:27:49.061] [LOG]   Starting node helper for: calendar
      [2025-03-28 10:27:49.061] [LOG]   Sockets connected & modules started ...
      [2025-03-28 10:27:49.346] [LOG]   Launching application.
      [2025-03-28 10:27:49.594] [INFO]  System information:
      ### SYSTEM:   manufacturer: ; model: ; virtual: false
      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.74+rpt-rpi-2712
      ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
      ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
      pm2 knows that about MagicMirror:
      pi@MagicMirrorPi5:~/MagicMirror $ pm2 show MagicMirror
       Describing process with id 0 - name MagicMirror
      │ status            │ stopped                                  │
      │ name              │ MagicMirror                              │
      │ namespace         │ default                                  │
      │ version           │ 2.31.0-develop                           │
      │ restarts          │ 0                                        │
      │ uptime            │ 0                                        │
      │ script path       │ /home/pi/MagicMirror/installers/mm.sh    │
      │ script args       │ N/A                                      │
      │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
      │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
      │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
      │ interpreter       │ bash                                     │
      │ interpreter args  │ N/A                                      │
      │ script id         │ 0                                        │
      │ exec cwd          │ /home/pi                                 │
      │ exec mode         │ fork_mode                                │
      │ node.js version   │ N/A                                      │
      │ node env          │ N/A                                      │
      │ watch & reload    │ ✘                                        │
      │ unstable restarts │ 0                                        │
      │ created at        │ 2025-03-28T09:21:32.089Z                 │
       Divergent env variables from local env
      │ PWD            │ /home/pi                            │
      │ SSH_CONNECTION │ 172.23.56.21 53109 172.23.56.157 22 │
      │ TERM           │ xterm                               │
      │ SHLVL          │ 2                                   │
      │ SSH_CLIENT     │ 172.23.56.21 53109 22               │
      │ OLDPWD         │ /home/pi/MagicMirror/splashscreen   │
      What to do to get it fixed?
      is
      fixuppm2.sh a possible solution?
      Thanks for any hint!
      Ralf
        @sdetweil Thanks!
        overall it doesn’t work for me :-(
        system is so slow that even editing config.js took 8 seconds to load the tiny file from pi to Laptop…
        So I’ve re-configured to X11 …
        NO idea what happened but unusable with wayland.
        In addition the target of whole szenario - to get MMM-Pir working without error message is not reached because with wayland, too an error is produced …
        So I will stay with X11 and try MMM-Pir-universal …
        (which is kinda unreliable…)
        Warm regards,
        Ralf
          rkorell Module Developer @rkorell
          @rkorell Addition:
          to my 100% surprise the mirror now works - but: extremely slow.
          it is started with “npm run start:x11” !!!
          (in a Wayland configuration !?)
          loginctl show-session 1 | grep "Desktop"
          Desktop=LXDE-pi-wayfire
          pi@MagicMirrorPi5:~ $
          0|MagicMir | > magicmirror@2.31.0-develop start
          0|MagicMir | > npm run start:x11
          0|MagicMir |
          0|MagicMir |
          0|MagicMir | > magicmirror@2.31.0-develop start:x11
          0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
          0|MagicMir |
          0|MagicMir | [2025-03-28 11:39:58.784] [LOG]   Starting MagicMirror: v2.31.0-develop
          0|MagicMir | [2025-03-28 11:39:58.794] [LOG]   Loading config ...
          0|MagicMir | [2025-03-28 11:39:58.795] [LOG]   config template file not exists, no envsubst
          0|MagicMir | [2025-03-28 11:39:58.979] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
          0|MagicMir | [2025-03-28 11:39:59.040] [INFO]  Your configuration file doesn't contain syntax errors :)
          0|MagicMir | [2025-03-28 11:39:59.040] [INFO]  Checking modules structure configuration ...
          0|MagicMir | [2025-03-28 11:39:59.077] [INFO]  Your modules structure configuration doesn't contain errors :)
          0|MagicMir | [2025-03-28 11:39:59.078] [LOG]   Loading module helpers ...
          0|MagicMir | [2025-03-28 11:39:59.079] [LOG]   No helper found for module: alert.
          0|MagicMir | [2025-03-28 11:39:59.079] [LOG]   No helper found for module: MMM-MagicMover.
          0|MagicMir | [2025-03-28 11:39:59.079] [LOG]   No helper found for module: clock.
          0|MagicMir | [2025-03-28 11:39:59.079] [LOG]   No helper found for module: MMM-Profilepicture.
          0|MagicMir | [2025-03-28 11:39:59.088] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.088] [LOG]   Module helper loaded: MMM-Logging
          0|MagicMir | [2025-03-28 11:39:59.095] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.095] [LOG]   Module helper loaded: MMM-MoonPhase
          0|MagicMir | [2025-03-28 11:39:59.095] [LOG]   No helper found for module: MMM-Globe.
          0|MagicMir | [2025-03-28 11:39:59.095] [LOG]   No helper found for module: weather.
          0|MagicMir | [2025-03-28 11:39:59.129] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.129] [LOG]   Module helper loaded: MMM-JsonValue
          0|MagicMir | [2025-03-28 11:39:59.137] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.137] [LOG]   Module helper loaded: MMM-MyGarbage
          0|MagicMir | [2025-03-28 11:39:59.137] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
          0|MagicMir | [2025-03-28 11:39:59.213] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.213] [LOG]   Module helper loaded: MMM-Todoist
          0|MagicMir | [2025-03-28 11:39:59.250] [LOG]   2025-03-28T11:39:59 <log> init module helper birthdaylist (/home/pi/MagicMirror/modules/birthdaylist/node_helper.js:15 Class.init)
          0|MagicMir | [2025-03-28 11:39:59.250] [LOG]   Module helper loaded: birthdaylist
          0|MagicMir | [2025-03-28 11:39:59.251] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.251] [LOG]   Module helper loaded: MMM-SystemMonitor
          0|MagicMir | [2025-03-28 11:39:59.357] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.357] [LOG]   Check MagicMirror² version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.31.0-develop
          0|MagicMir | [2025-03-28 11:39:59.358] [LOG]   Version is ok!
          0|MagicMir | [2025-03-28 11:39:59.358] [LOG]   Module helper loaded: MMM-Strava
          0|MagicMir | [2025-03-28 11:39:59.358] [LOG]   No helper found for module: MMM-EventHorizon.
          0|MagicMir | [2025-03-28 11:39:59.389] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.389] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
          0|MagicMir | [2025-03-28 11:39:59.511] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.511] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
          0|MagicMir | [2025-03-28 11:39:59.512] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.512] [LOG]   Module helper loaded: MMM-SystemInfo
          0|MagicMir | [2025-03-28 11:39:59.539] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.539] [LOG]   Module helper loaded: newsfeed
          0|MagicMir | [2025-03-28 11:39:59.539] [LOG]   No helper found for module: MMM-UselessFacts.
          0|MagicMir | [2025-03-28 11:39:59.559] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.559] [LOG]   Module helper loaded: MMM-Remote-Control
          0|MagicMir | [2025-03-28 11:39:59.597] [LOG]   Initializing new module helper ...
          0|MagicMir | [2025-03-28 11:39:59.597] [LOG]   Module helper loaded: calendar
          0|MagicMir | [2025-03-28 11:39:59.598] [LOG]   All module helpers loaded.
          0|MagicMir | [2025-03-28 11:39:59.601] [LOG]   Starting server on port 8080 ...
          0|MagicMir | [2025-03-28 11:39:59.940] [LOG]   Server started ...
          0|MagicMir | [2025-03-28 11:39:59.941] [LOG]   Connecting socket for: MMM-Logging
          0|MagicMir | [2025-03-28 11:39:59.942] [LOG]   2025-03-28T11:39:59 <log> Module helper started for MMM-Logging (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:19 Class.start)
          0|MagicMir | [2025-03-28 11:39:59.942] [LOG]   Connecting socket for: MMM-MoonPhase
          0|MagicMir | [2025-03-28 11:39:59.943] [LOG]   Starting module helper: MMM-MoonPhase
          0|MagicMir | [2025-03-28 11:39:59.943] [LOG]   Connecting socket for: MMM-JsonValue
          0|MagicMir | [2025-03-28 11:39:59.943] [LOG]   Connecting socket for: MMM-MyGarbage
          0|MagicMir | [2025-03-28 11:39:59.944] [LOG]   2025-03-28T11:39:59 <log> Starting node_helper for module: MMM-MyGarbage (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_helper.js:9 Class.start)
          0|MagicMir | [2025-03-28 11:39:59.944] [LOG]   Connecting socket for: MMM-Todoist
          0|MagicMir | [2025-03-28 11:39:59.946] [LOG]   2025-03-28T11:39:59 <log> Starting node helper for: MMM-Todoist (/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js:19 Class.start)
          0|MagicMir | [2025-03-28 11:39:59.946] [LOG]   Connecting socket for: birthdaylist
          0|MagicMir | [2025-03-28 11:39:59.947] [LOG]   Connecting socket for: MMM-SystemMonitor
          0|MagicMir | [2025-03-28 11:39:59.947] [LOG]   Starting module helper: MMM-SystemMonitor
          0|MagicMir | [2025-03-28 11:39:59.947] [LOG]   Connecting socket for: MMM-Strava
          0|MagicMir | [2025-03-28 11:39:59.949] [LOG]   2025-03-28T11:39:59 <log> Starting module helper: MMM-Strava (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:47 Class.start)
          0|MagicMir | [2025-03-28 11:39:59.950] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
          0|MagicMir | [2025-03-28 11:39:59.951] [LOG]   2025-03-28T11:39:59 <log> Starting module: MMM-FRITZ-Box-Callmonitor-py3 (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3/node_helper.js:28 Class.start)
          0|MagicMir | [2025-03-28 11:39:59.952] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
          0|MagicMir | [2025-03-28 11:39:59.953] [LOG]   Connecting socket for: MMM-SystemInfo
          0|MagicMir | [2025-03-28 11:39:59.953] [LOG]   Starting node helper: MMM-SystemInfo
          0|MagicMir | [2025-03-28 11:39:59.953] [LOG]   Connecting socket for: newsfeed
          0|MagicMir | [2025-03-28 11:39:59.954] [LOG]   Starting node helper for: newsfeed
          0|MagicMir | [2025-03-28 11:39:59.954] [LOG]   Connecting socket for: MMM-Remote-Control
          0|MagicMir | [2025-03-28 11:39:59.954] [LOG]   Starting node helper for: MMM-Remote-Control
          0|MagicMir | [2025-03-28 11:39:59.959] [LOG]   Connecting socket for: calendar
          0|MagicMir | [2025-03-28 11:39:59.959] [LOG]   Starting node helper for: calendar
          0|MagicMir | [2025-03-28 11:39:59.960] [LOG]   Sockets connected & modules started ...
          0|MagicMir | [2025-03-28 11:40:00.172] [LOG]   Launching application.
          0|MagicMir | [2025-03-28 11:40:00.631] [INFO]  System information:
          0|MagicMir | ### SYSTEM:   manufacturer: ; model: ; virtual: false
          0|MagicMir | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.74+rpt-rpi-2712
          0|MagicMir | ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
          0|MagicMir | ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
          Now I’m confused totally.
          can anybody please help me to understand, what happens here?
          THANKS!
          Ralf
            sdetweil @rkorell
            @rkorell electron saves a bunch of info , you may need to erase that to allow it to save different info
            stop MagicMirror
            rm -rf ~/.config/Electron
            note the dot in front of config
              @sdetweil Thanks!
              Warm regards,
              Ralf
                sdetweil @rkorell
                @rkorell note that npm start issues npm run start:x11
                  @sdetweil said in My new MagicMirror will not start with Wayland?:
                  ? can you kindly please eloborate?
                  Didn’t get you, sorry!
                    quick question: will this command help, anyway to get “performance” fixed?
                    Background: Since running on Pi5 / bookworm the mirror has “problems” on reboot.
                    Module load is extremely slow (minutes!).
                    A “pm2 reload MagicMirror” after reboot leads to way faster module loadings.
                    Thanks,
                    Ralf
                      sdetweil @rkorell
                      @rkorell said in My new MagicMirror will not start with Wayland?:
                      no idea
                        sdetweil @rkorell
                        from package.json
                        these are the command types you can issue npm run …
                                        "start": "npm run start:x11",
                                        "start:dev": "npm run start -- dev",
                                        "start:wayland": "WAYLAND_DISPLAY=\"${WAYLAND_DISPLAY:=wayland-1}\" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland",
                                        "start:wayland:dev": "npm run start:wayland -- dev",
                                        "start:windows": ".\\node_modules\\.bin\\electron js\\electron.js",
                                        "start:windows:dev": "npm run start:windows -- dev",
                                        "start:x11": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                                        "start:x11:dev": "npm run start -- dev",
                        if you do npm start or npm run start
                        the command is “npm run start:x11”
                        which is the “same” as it was before release 2.30.0
                        I posted this in
                        https://forum.magicmirror.builders/topic/19269/new-magicmirror-start-options-in-version-2-30-0
                        so at least you don’t have to edit package.json and break updates…
                          sdetweil @rkorell
                          @rkorell I can ‘fix’ MagicMirror.sh to detect wayland/labwc and use
                          and if not
                          npm run start
                          switching so it WORKS seems like it takes some drastic changes…(erase electron config)…
                          I don’t know what is in the electron config folder, so can’t tell if there is a way to know you switched since last run…
                          • R rkorell has marked this topic as solved on
                            @sdetweil As I wrote initially “npm run start:wayland” doesn’t work …
                            (despite wayland configured).
                            And the “stored” auto-start option npm run start:x11 DOES work - for whatever reason.
                            VNC was really sluggish on this, performance a nightmare so - see above marked as “solution” I switched back to x11 and all is working fine.
                            In the meantime I’ve also managed to get MMM-Pir to work by idenitfying and correcting two errors in Bugsounet’s code …
                            Warm regards,
                            Ralf
                            S 2 Replies Last reply Reply Quote 1
                              sdetweil @rkorell
                              @rkorell great work!
                                sdetweil @rkorell
                                @rkorell i am thinking of pushing a change to mm.sh to run with what is detected
                                this is for new installs, i wont change existing on update
                                updated, release on next rev
                                  Ohhh - this from you!
                                  Makes me proud.
                                  Thanks!
                                  Ralf
                                    @rkorell my updated mm.sh fails when trying wayland, some fontconfig problem
                                    apt upgrade /full-upgrade fail… oh so much fun…
                                    but npm start works!?
                                      @sdetweil said in
                                      Not tried.
                                      Leave it currently, as is.
                                      Via your install script provided autostart calls npm run start:x11 - which works fine.
                                      Regards,
                                      Ralf
                                        sdetweil @rkorell
                                        @rkorell yeh, i put it back
