    Looking for feedback and advice
    15 Posts 2 Posters 2.5k Views 2 Watching
    • X Offline
      Xsoldier2000
      Hello, I started out this journey dabbling around and getting in WAY over my head. (I’m still in way over my head, but no longer scared to be here. I had originally setup my mirrorless Family board by resizing regions and while trying to fine tune my board I was running into all kinds of issues. SO I wiped MM from my pi and started over. I’m looking for advice on my current setup (advice on things I did wrong and how I could do better) Also wondering in the agenda side of things, can I somehow make the event line longer on top to have less wrap around…can I also somehow show the location of the event if there is one? Last but not least, I can’t seem to extend the MMM-CalendarEXT3 module to the bottom of the screen, is there some sort of limit to the size of it that I haven’t come across yet? While in Dev model, when I try to select the agenda module, I can only select the EXT3 module because of the Olympics sizes movements I went through to move the module in the spot it is in currently. Should I have done that differently?
      TLDR;
      1. Advice (right or wrong) on current setup
      2. Extend the even name for less wrap-around
      3. Show Location (if any) of event? (line below possible?)
      4. Extend EXT3 to bottom of screen in this position
      5. Reconfigure EXT3 module correctly?
      Config.js:
      timeFormat: 12,
      	units: "imperial",
      			module: "clock",
      			position: "top_left"
      			header: "Today's Events",
      				limitDays: 2,
      				colored: false,
      				coloredSymbol: true,
      				wrapEvents: true,
      				showEnd: false,
      				fontSize: "22px",
      				fade: false,
      				fetchInterval: 60000,
      				eventHeight: "22px",
      				hideTime: true,
      				calendars:[
      						url: "https://calendar.google.com/calendar/ical/XXXXX/XXXXX/basic.ics",
      						symbol: "fa-regular fa-calendar",
      						color: '#008000',
      						url: "webcal://www.bfccps.org/servlet/ICalServlet?id=4",
      						symbol: "school",
      						color: '#644117',
      						url: "http://ical-cdn.teamsnap.com/team_schedule/XXXXX.ics",
      						symbol: "fa-regular fa-futbol",
      						color: "blue",
      						color: "red",
        			module: 'MMM-AnyList',
        			position: 'bottom_left',
          				email: 'XXX@gmail.com',
          				password: 'XXXX',
          				list: "Dylan's Chore List",
          				// Optional, values listed are the defaults
          				onlyShowUnchecked: true,
      				wrapEvents: true,
          				maxItemsInList: 10,
          				fade: false,
      				trimText: false,
      				highlightAlternateRows: true,
      				animationSpeed: 2000,
          				showCategories: false,
          				showQuantities: false,
      				textAlign: 'left',
      		      //position: "top_center",
      				mode: "month",
      				colored: true,
      				wrapEvents:  true,
      				fadePoint: 0.11,
      				broadcastEvents: true,
      				broadcastPastEvents: true,
      				maximumEntries: '10000',
      				fontSize: '20px',
      				eventHeight: '22px',
      				calendars:[
      						color: '#008000',
      						symbol: "school",
      						color: '#644117',
      						color: "blue",
      						color: "red",
      			module: "MMM-CalendarExt3",
        			title: "",
      				mode: "week",
      				instanceId: "WeekCalendar",
      				weekIndex:0,
      				weeksInView:4,
      				maxEventLines: 8,
      				refreshInterval: 60000,
      				animationSpeed: 0,
          				firstDayOfWeek: 0,
         				calendarSet: [],
      				useWeather: false,
      				fontSize: "24px",
      			module: "weather",
      			position: "bottom_left",
      				weatherProvider: "openmeteo",
      				type: "current",
      				lat: 42.040143,
      				lon: -71.452461
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      				lat: 42.040143,
      				lon: -71.452461,
      				fade: false
      Custom.css:
      :root {
        --color-text: #999;
        --color-text-dimmed: #888;
        --color-text-bright: #fff;
        --color-background: black;
        --font-primary: "Roboto Condensed";
        --font-secondary: "Roboto";
        --font-size: 24px;
        --font-size-small: 0.75rem;
        --gap-body-top: 0px;
        --gap-body-right: 0px;
        --gap-body-bottom: 0px;
        --gap-body-left: 0px;
        --gap-modules: 0px;
       /* Global Settings */
      	body {
          margin: 0;
          background: rgb(0 0 0 / 100%);
        .MMM-CalendarExt3 .module-content {
          margin-left: 350px !important;
          height: 1500px !important;
          width: 1550px;
        .MMM-AnyList {
         margin-bottom: 30px !important;
         .clock {
       margin-bottom: 20px;
      	.weather .module-content {
      	width: 350px;
      	.calendar .module-content {
      		width: 350px !important;
        sdetweil @Xsoldier2000
        @Xsoldier2000 you can disable the ext3 while you adjust others
        X 1 Reply Last reply Reply Quote 0
          @Xsoldier2000 there were a couple topics on ext3 agenda more size recently
          • X Offline
            Xsoldier2000 @sdetweil
            @sdetweil Ahhh, I am just using the OOTB Calendar module, I’ll look into the EXT3 Agenda module. Thank you!
              @Xsoldier2000 but???
              • X Offline
                @sdetweil said in Looking for feedback and advice:
                Ended up commenting out the position to do that. Just didn’t know if the Calendar module was acting the way it should.
                • X Offline
                  Not sure what you mean here…I’ve tried expanding the height, but it doesn’t seem to go past a certain hard point on the screen. Is there a limit? (I wouldn’t like to add another week on the calendar, just stretch it down.)
                    @Xsoldier2000 you said cant extend ext3, i said look at…
                    then you said only using the default calendar
                    so now i am confused
                    • X Offline
                      @sdetweil Agenda view on left side is default calendar (can see in my posted config)
                      Main month calendar on right side of screen is EXT3.
                      • X Offline
                        Xsoldier2000 @Xsoldier2000
                        Posting this for any newcomers like me that weren’t really pointed in any direction, and don’t know the terminology in which to search for answers.
                          A: I don’t really have answer for this, I know what I did to correct my issues, but don’t fully understand the why of it all.
                        2. Extend the event name for less wrap-around
                          A: maxTitleLength, maxLocationTitleLength & maxLocationEvents (look at the Config details on the github of the module) is what worked for me.
                          A: showLocation: true,
                          A: this took a lot longer to figure out, but using Dev mode is what made me figure it out. I was trying to use a height: XXXXXpx; (in the .css module content) which was making the screen jump up like half a page…in Dev mode, found the body module was way oversized, changed the height parameter to 100% and that fixed the jumping issue, then figured out in the EXT3 module, I could increase the maxEventLines to expand the module to the bottom of the screen (look at the Config details on the github of the module), works perfect now.
                          Answered in #4 above.
                        ***I still don’t know what the body is or does, but I now know it should match your screensize (i believe) There is also something in the EXT3 module that makes the height parameter not work which is probably by design, because stretching a module would probably make it look weird, thankfully adding event lines is builtin. Going back and reading all the modules on github made me figure everything out. Uploading the final result. ***
                        S 2 Replies Last reply Reply Quote 1
                          @Xsoldier2000 when you say look at github, what do you mean? the module README.md file is what is shown for the module github page. after git clone, you have that on your system and can view ut at any time
                          for Ext3 it has definitions and explanations of the css variables used to size the content, and calendar cells to hold the content
                          MagicMirror is a web page, shown in a browser. all the content ( module output) is generated dynamically by javascript code.
                          an html page contains two major elements
                          head - documents scripts and css files used on this page
                          body - holds the displayable context. text, ,tables, graphs, images, etc
                          the design of that page can be seen in the index.html file in the MagicMirror folder
                          all the script and css files are added by the MagicMirror runtime for each active module
                          css/main.css holds the styling for the default page and modules
                          including the size abd shspe of the page and spaces(regions) for module content
                          as you have discovered the Ext3 family of modules is one of the most CSS configurable modules available
                            @Xsoldier2000 for your 3, you should indicate what module that property applies to.
                            Ext3 css height property not working… well
                            as you found ext3 calculates the size base on num event lines, event line height, number of calendar week rows shown, etc, all set with --xxx css variables described in the module doc(readme file)
                            which are all overridable (changable) in/using custom.css
                            • X Offline
                              That makes sense now, as you can tell I’m not fully versed in the understanding of these things. Now I know.
                              I honestly didn’t even know it was showing the README.md file until you brought it up and I just went back to see. (I associate https://github.com/MMRIZE/MMM-CalendarExt3 to a webpage, but it’s kind of a different setup. First real time using github ever)
                              I’m the kind of guy that puts things together first, then when it doesn’t work right, I read the instructions…makes life … difficult sometimes.
                              Thank you for all this info. It helps an old GI like me.
                                @Xsoldier2000 nobody reads the documentation!
                                  @Xsoldier2000 the thing you see on github IS a web page dynamically constructed from a list of files in the project repository AND a rendering of a readme if one is found, and some other github project mgmt services, issues, fixes, …
