    cron job hdmi on and off
    29 Posts 4 Posters 10.2k Views 4 Watching
      Sam 0
      Re: [Cron Job Question](/tI used a cron job to turn my screen off and on I still want to do this I understand that the addressing of the monitor has changed and now only the code below works:
      Turn off display Sunday - Thursday at 22:00
      00 22 * ​​* 0-4 wlr-randr --output HDMI-A-1 --off
      Turn off display Friday - Saturday at 22:45
      45 22 * ​​* 5,6 wlr-randr --output HDMI-A-1 --off
      Turn on screen Monday - Friday at 7:00
      00 07 * * 1-5 wlr-randr --output HDMI-A-1 --on
      Turn on screen Saturday - Sunday at 8:00
      00 08 * * 6,0 wlr-randr --output HDMI-A-1 --onopic/16967/cron-job-question)
      i see that running the commands:
      works fine
      only putting this in cron and making it work didn’t work. i think i need to point the above cron job to files to have it run by cronjob can someone give a good example of what this looks like
      mumblebajM S 3 Replies Last reply Reply Quote 0
        Sam 0
        ok is this good now? :) let me know the result tomorrow…
        • mumblebajM Offline
          mumblebaj Module Developer @Sam 0
          @Sam-0 Have a look at my post about this.
          https://forum.magicmirror.builders/topic/19116/having-trouble-with-screen-on-and-off-here-are-some-tips-that-could-help?_=1743776945326
            Sam 0 @Sam 0
            @Sam-0 thanks I will test it and share the result with you
              Sam 0 @Sam 0
              i created two files
              off.sh and on.sh
              they contain the following lines
              i also created a folder
              with the following rights:
              cmod 777
              the cron contains the following lines:
              unfortunately this does not work what is wrong?
              # Schakel display uit zondag - donderdag om 22.00
              00 22 * * 0-4 /home/username/MagicMirror/config/hdmionoff/off.sh>> /home/username/MagicMirror/config/hdmionoff/mof.log 2>&1
              # Schakel display uit vrijdag - zaterdag om 22.45
              45 22 * * 5,6 /home/username/MagicMirror/config/hdmionoff/off.sh>> /home/username/MagicMirror/config/hdmionoff/mof.log 2>&1
              # Zet het scherm aan maandag - vrijdag om 7u00
              00 07 * * 1-5/home/username/MagicMirror/config/hdmionoff/on.sh>> /home/username/MagicMirror/config/hdmionoff/mon.log 2>&1
              # Zet het scherm aan zaterdag - zondag om 8u00
              00 08 * * 6,0/home/username/MagicMirror/config/hdmionoff/on.sh>> /home/username/MagicMirror/config/hdmionoff/mon.log 2>&1
              S S evroomE 3 Replies Last reply Reply Quote 0
                sdetweil @Sam 0
                @Sam-0 are the sh files marked executable?
                ls -laF in your folder to see
                permissions are 3 groups of 3 settings
                read/write/execute
                for user, group and all others
                9 settings from the right
                one more for directory and 1 for system
                ds, user, group, other
                  Sam 0 @Sam 0
                  I thought it was right but now the rights on the sh files are set to 0777 and also on the folders
                  I also did a test to see if I could execute the sh files, this works tonight the cron should execute it, let me know if it works
                    sdetweil @Sam 0
                    @Sam-0 yes. although you dont need write permission, (except for user)
                    means anyone else could change the script
                    • evroomE Offline
                      evroom @Sam 0
                      @Sam-0 said in cron job hdmi on and off:
                      i created two files
                      off.sh and on.sh
                      Do you have #!/bin/bash or #!/bin/sh at the very beginning of your shell scripts ?
                      #! /bin/sh – Execute the file using the Bourne shell, or a compatible shell, assumed to be in the /bin directory
                      #! /bin/bash – Execute the file using the Bash shell
                      You can also put /bin/bash in the crontab entry (before /home/username/...).
                      Then there is no way for cron to not execute it as a shell script and it will even run without the executable bit set.
                      And what Sam mentioned: the scripts need to be executable but not necessarily writable (chmod 755).
                      This should normally do the trick.
                      If you have mail installed (which mail) you can put this at the very beginning of the crontab file:
                      MAILTO=username (in my case admin).
                      With
                      journalctl --since "1 day ago" --unit cron.service --no-pager
                      you can see if cron ran your script and with mail you can see more details on the cron job executed.
                      Good luck.
                      1 Reply Last reply Reply Quote -1
                        Sam 0 @sdetweil
                        @evroom Thanks for your explanation, I have made adjustments and will check tonight if it works. I will report this back. Thanks for the effort.
                          Sam 0
                          unfortunately it still doesn’t work what am I doing
                          wrong?!
                          cron info
                          on sh file
                          off sh file
                          error logfile:
                          • evroomE Offline
                            evroom @Sam 0
                            @Sam-0
                            So it seems that the cronjob is okay.
                            Can you do:
                            ˋˋˋls -als /run/user/1000/wayland*ˋˋˋ
                            I think you need wayland-0 iso wayland-1.
                            With ˋˋˋ grep username /etc/passwdˋˋˋ (use your username) you can verify that your user has uid 1000.
                            • evroomE Offline
                              evroom @Sam 0
                              @Sam-0
                              In de laatste 2 regels mist een spatie bij /home.
                              • evroomE Offline
                                evroom @Sam 0
                                  Sam 0
                                  ok i checked some more and did some tests
                                  when I execute the following I get the error message that I also see in the log
                                  /usr/bin/wlr-randr --output H DMI-A-1 --off
                                  failed to connect to display
                                  also running the sh files via putty gives the error
                                  it seems that the command:
                                  the error message gives the question is this command incorrect or is there an underlying problem?
                                  mumblebajM S 2 Replies Last reply Reply Quote 0
                                    @Sam-0 Can you run the following from the command line and she your results:
                                    wlr-randr
                                    Share your results. Either the wayland-1 is different as indicated by @evroom or HDMI-A-1 is actually a different version on your system.
                                    Share the results from the above and we take it from there. Also, @evroom has indicated the there is supposed to be a space before /home on the crontab.
                                      Sam 0 @Sam 0
                                      @Sam-0 this is the result
                                      checked the cron see below
                                      • evroomE Offline
                                        evroom @Sam 0
                                        @Sam-0
                                        So as stated before you most probably need to change wayland-1 to wayland-0 in your scripts.
                                        Give it a try.
                                        Furthermore the .lock file may cause a problem, but I guess this will show in your error log.
                                        And temporarily change the times in your cronjob to speed things up a bit.
                                        Waiting till ten and midnight is not really necessary :-)
                                        mumblebajM S 2 Replies Last reply Reply Quote 1
                                          mumblebaj Module Developer @evroom
                                          @evroom *.lock should not cause an issue. I have same on my system and no issues with it. I agree with the wayland-1 change to wayland-0.
                                            Sam 0 @evroom
                                            @evroom
                                            should it be modified in this way?
                                            Into
                                            output HDMI-A-0 --on
                                            • evroomE Offline
                                              evroom @Sam 0
                                              @evroom
                                              Into
                                              No, like this:
                                              export WAYLAND_DISPLAY=wayland-0
                                              In both scripts.
