    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
      DarkV @sdetweil
      Results
      junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test-convert.sh override
      -bash: ./test-convert.sh: No such file or directory
      I used a fresh SD card for the reinstallation, but some of her modules are incompatible with the new setup. Consequently, my wife has firmly decided to stick with the current version until her modules stop functioning. Unfortunately, since one of the modules doesn’t work with the old MagicMirror version, I’m at an impasse. It is a pity, I wanted this as due to dyslexia, this would have been perfect for my situation
        sdetweil @DarkV
        @DarkV ok,my fault
        cd ~/MagicMirror/modules/MMM-Config
        ./test_convert.sh  override
          DarkV @sdetweil
          @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
          junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test_convert.sh overri de
          --------------------MMM-Config
          module updatenotification-defaults has an error in the construction of its defau lts section
          the error line is disabled: true;
          please change it to the literal value of the referenced variable
          and restart MagicMirror
            sdetweil @DarkV
            @DarkV can you show the top of the modules/defaul/updatenotification/updatenotification.js
            make sure the defaults section is shown
            you know you never edit any of the MagicMirror source or module source
            all config goes in config/config.js and all css goes in css/custom.css
              DarkV @sdetweil
              My bad,iI was trying to dissable the “Update available” banner at the top of mirror
              /* MagicMirror²
              • Module: UpdateNotification
              • By Michael Teeuw https://michaelteeuw.nl
              • MIT Licensed.
                Module.register(“updatenotification”, {
                defaults: {
                updateInterval: 10 * 60 * 1000, // every 10 minutes
                refreshInterval: 24 * 60 * 60 * 1000, // one day
                ignoreModules: [],
                sendUpdatesNotifications: false,
                updates: [],
                updateTimeout: 2 * 60 * 1000, // max update duration
                updateAutorestart: false // autoRestart MM when update done ?
                disabled: true;
                suspended: false,
                moduleList: {},
                needRestart: false,
                updates: {},
                start () {
                Log.info(Starting module: ${this.name});
                this.addFilters();
                setInterval(() => {
                this.moduleList = {};
                this.updateDom(2);
                }, this.config.refreshInterval);
                suspend () {
                this.suspended = true;
                resume () {
                this.suspended = false;
                this.updateDom(2);
                notificationReceived (notification) {
                switch (notification) {
                case “DOM_OBJECTS_CREATED”:
                this.sendSocketNotification(“CONFIG”, this.config);
                this.sendSocketNotification(“MODULES”, Object.keys(Module.definitions));
                break;
                case “SCAN_UPDATES”:
                this.sendSocketNotification(“SCAN_UPDATES”);
                break;
                socketNotificationReceived (notification, payload) {
                case “REPO_STATUS”:
                this.updateUI(payload);
                break;
                case “UPDATES”:
                this.sendNotification(“UPDATES”, payload);
                break;
                case “UPDATE_STATUS”:
                this.updatesNotifier(payload);
                break;
                getStyles () {
                return [${this.name}.css];
                getTemplate () {
                return ${this.name}.njk;
                getTemplateData () {
                return { moduleList: this.moduleList, updatesList: this.updates, suspended: this.suspended, needRestart: this.needRestart };
                updateUI (payload) {
                if (payload && payload.behind > 0) {
                // if we haven’t seen info for this module
                if (this.moduleList[payload.module] === undefined) {
                // save it
                this.moduleList[payload.module] = payload;
                this.updateDom(2);
                } else if (payload && payload.behind === 0) {
                // if the module WAS in the list, but shouldn’t be
                if (this.moduleList[payload.module] !== undefined) {
                // remove it
                delete this.moduleList[payload.module];
                this.updateDom(2);
                addFilters () {
                this.nunjucksEnvironment().addFilter(“diffLink”, (text, status) => {
                if (status.module !== “MagicMirror”) {
                return text;
                 	const localRef = status.hash;
                 	const remoteRef = status.tracking.replace(/.*\//, "");
                 	return `<a href="https://github.com/MichMich/MagicMirror/compare/${localRef}...${remoteRef}" class="xsmall dimmed difflink" target="_blank">${text}</a>`;
                updatesNotifier (payload, done = true) {
                if (this.updates[payload.name] === undefined) {
                this.updates[payload.name] = {
                sdetweil @DarkV
                @DarkV yes i understand
                lets restore the updatenotification module file
                git checkout modules/default/updatenotification/updatenotification.js
                then lets edit config.js to disable the module
                      module:"updatenotification",
                      position:"top_bar",
                      disabled:true
                  DarkV @sdetweil
                  fatal: not a git repository (or any of the parent directories): .git
                  junior@MAGIC-MIRROR:~/MagicMirror $
                    sdetweil @DarkV
                    @DarkV hmmm
                    how did you install MagicMirror
                    manual, scripted or zip file download ?
                    • JohanbaJ
                      Johanba
                      Also not getting it to work
                      in the browser i go to installer
                      and this is all that loads
                        sdetweil @Johanba
                        @Johanba i posted in your other topic
                          DarkV @sdetweil
                          @sdetweil Script
                          You helped me on a while backScreenshot 2025-04-10 at 11-54-21 Failed Update MagicMirror Forum.png
                            sdetweil @DarkV
                            @DarkV i understand, but that wasn’t the question
                            the git checkout command should have worked,
                            but failed.
                            now i am trying to figure out why. and what to do about it
                            the command prompt looks different after
                            then the last time you did a command
                            so try this way
                            go to your MagicMirror folder
                            and do git status
                            show the results
                              DarkV @sdetweil
                              git status
                              junior@MAGIC-MIRROR:~ $ cd ~/MagicMirror/modules/MMM-Config
                              junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ git status
                              On branch main
                              Your branch is up to date with ‘origin/main’.
                              nothing to commit, working tree clean
                              junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ cd ~/MagicMirror
                              junior@MAGIC-MIRROR:~/MagicMirror $ git status
                                sdetweil @DarkV
                                @DarkV asking again, how did you install MagicMirror?
                                  DarkV @sdetweil
                                  @sdetweil I think it must have been a script on the net. It was quite a long time ago, between 2022 and 2023. I honestly cannot remember. I found an old config.js from ‎06 ‎October ‎2023
                                    sdetweil @DarkV
                                    @DarkV ok, my script is the only one I know about and it uses git
                                    lets do this to get a new copy and use your config/modules…
                                    copy paste this section to a terminal window
                                    cd ~
                                    # save MM folder
                                    mv MagicMirror MagicMirror.org
                                    # install new MM (reply N to screen saver/pm2
                                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                    once MM is installed again lets make THIS new version look like the old
                                    copy/paste this
                                    # copy files
                                    cd ~
                                    cp MagicMirror.org/config/config.js MagicMirror/config
                                    cp MagicMirror.org/css/custom.css MagicMirror/css
                                    cd MagicMirror/modules
                                    # save the new default module folder
                                    mv default ..
                                    cd ..
                                    # copy all the org modules
                                    cp -r -p ~/MagicMirror.org/modules .
                                    cd modules
                                    # remove the old default  modules folder
                                    rm -rf default
                                    # move back the new default
                                    mv ../default .
                                    now
                                    npm start should work
                                    • 11
                                    • 12
                                    • 13
                                    • 14
                                    • 15
                                    • 15 / 15
