    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 490.2k Views 31 Watching
      sdetweil @DarkV
      @DarkV can you show the top of the modules/defaul/updatenotification/updatenotification.js
      make sure the defaults section is shown
      you know you never edit any of the MagicMirror source or module source
      all config goes in config/config.js and all css goes in css/custom.css
      D 1 Reply Last reply
        DarkV @sdetweil
        My bad,iI was trying to dissable the “Update available” banner at the top of mirror
        /* MagicMirror²
        • Module: UpdateNotification
        • By Michael Teeuw https://michaelteeuw.nl
        • MIT Licensed.
          Module.register(“updatenotification”, {
          defaults: {
          updateInterval: 10 * 60 * 1000, // every 10 minutes
          refreshInterval: 24 * 60 * 60 * 1000, // one day
          ignoreModules: [],
          sendUpdatesNotifications: false,
          updates: [],
          updateTimeout: 2 * 60 * 1000, // max update duration
          updateAutorestart: false // autoRestart MM when update done ?
          disabled: true;
          suspended: false,
          moduleList: {},
          needRestart: false,
          updates: {},
          start () {
          Log.info(Starting module: ${this.name});
          this.addFilters();
          setInterval(() => {
          this.moduleList = {};
          this.updateDom(2);
          }, this.config.refreshInterval);
          suspend () {
          this.suspended = true;
          resume () {
          this.suspended = false;
          this.updateDom(2);
          notificationReceived (notification) {
          switch (notification) {
          case “DOM_OBJECTS_CREATED”:
          this.sendSocketNotification(“CONFIG”, this.config);
          this.sendSocketNotification(“MODULES”, Object.keys(Module.definitions));
          break;
          case “SCAN_UPDATES”:
          this.sendSocketNotification(“SCAN_UPDATES”);
          break;
          socketNotificationReceived (notification, payload) {
          case “REPO_STATUS”:
          this.updateUI(payload);
          break;
          case “UPDATES”:
          this.sendNotification(“UPDATES”, payload);
          break;
          case “UPDATE_STATUS”:
          this.updatesNotifier(payload);
          break;
          getStyles () {
          return [${this.name}.css];
          getTemplate () {
          return ${this.name}.njk;
          getTemplateData () {
          return { moduleList: this.moduleList, updatesList: this.updates, suspended: this.suspended, needRestart: this.needRestart };
          updateUI (payload) {
          if (payload && payload.behind > 0) {
          // if we haven’t seen info for this module
          if (this.moduleList[payload.module] === undefined) {
          // save it
          this.moduleList[payload.module] = payload;
          this.updateDom(2);
          } else if (payload && payload.behind === 0) {
          // if the module WAS in the list, but shouldn’t be
          if (this.moduleList[payload.module] !== undefined) {
          // remove it
          delete this.moduleList[payload.module];
          this.updateDom(2);
          addFilters () {
          this.nunjucksEnvironment().addFilter(“diffLink”, (text, status) => {
          if (status.module !== “MagicMirror”) {
          return text;
           	const localRef = status.hash;
           	const remoteRef = status.tracking.replace(/.*\//, "");
           	return `<a href="https://github.com/MichMich/MagicMirror/compare/${localRef}...${remoteRef}" class="xsmall dimmed difflink" target="_blank">${text}</a>`;
          updatesNotifier (payload, done = true) {
          if (this.updates[payload.name] === undefined) {
          this.updates[payload.name] = {
          sdetweil @DarkV
          @DarkV yes i understand
          lets restore the updatenotification module file
          git checkout modules/default/updatenotification/updatenotification.js
          then lets edit config.js to disable the module
                module:"updatenotification",
                position:"top_bar",
                disabled:true
            DarkV @sdetweil
            @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
            fatal: not a git repository (or any of the parent directories): .git
            junior@MAGIC-MIRROR:~/MagicMirror $
              sdetweil @DarkV
              @DarkV hmmm
              how did you install MagicMirror
              manual, scripted or zip file download ?
              • JohanbaJ
                Johanba
                Also not getting it to work
                in the browser i go to installer
                and this is all that loads
                  sdetweil @Johanba
                  @Johanba i posted in your other topic
                    DarkV @sdetweil
                    @sdetweil Script
                    You helped me on a while backScreenshot 2025-04-10 at 11-54-21 Failed Update MagicMirror Forum.png
                      sdetweil @DarkV
                      @DarkV i understand, but that wasn’t the question
                      the git checkout command should have worked,
                      but failed.
                      now i am trying to figure out why. and what to do about it
                      the command prompt looks different after
                      then the last time you did a command
                      so try this way
                      go to your MagicMirror folder
                      and do git status
                      show the results
                        DarkV @sdetweil
                        git status
                        junior@MAGIC-MIRROR:~ $ cd ~/MagicMirror/modules/MMM-Config
                        junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ git status
                        On branch main
                        Your branch is up to date with ‘origin/main’.
                        nothing to commit, working tree clean
                        junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ cd ~/MagicMirror
                        junior@MAGIC-MIRROR:~/MagicMirror $ git status
                          sdetweil @DarkV
                          @DarkV asking again, how did you install MagicMirror?
                            DarkV @sdetweil
                            @sdetweil I think it must have been a script on the net. It was quite a long time ago, between 2022 and 2023. I honestly cannot remember. I found an old config.js from ‎06 ‎October ‎2023
                              sdetweil @DarkV
                              @DarkV ok, my script is the only one I know about and it uses git
                              lets do this to get a new copy and use your config/modules…
                              copy paste this section to a terminal window
                              cd ~
                              # save MM folder
                              mv MagicMirror MagicMirror.org
                              # install new MM (reply N to screen saver/pm2
                              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                              once MM is installed again lets make THIS new version look like the old
                              copy/paste this
                              # copy files
                              cd ~
                              cp MagicMirror.org/config/config.js MagicMirror/config
                              cp MagicMirror.org/css/custom.css MagicMirror/css
                              cd MagicMirror/modules
                              # save the new default module folder
                              mv default ..
                              cd ..
                              # copy all the org modules
                              cp -r -p ~/MagicMirror.org/modules .
                              cd modules
                              # remove the old default  modules folder
                              rm -rf default
                              # move back the new default
                              mv ../default .
                              now
                              npm start should work
                              • 11
                              • 12
                              • 13
                              • 14
                              • 15
                              • 15 / 15
