    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      sdetweil @DarkV
      @DarkV mmm-config requires MagicMirror version 2.28 or higher
      also, you have some syntax error around line 122 in config.js
      pm2 flush to empty the logs
      and see what hsppens after you fix that config.js error
      D 1 Reply Last reply
        DarkV @sdetweil
        @sdetweil, I’m sorry. Can you please highlight where I have the error? I am considering reinstalling it as I cannot even update Magic Mirror. I want to back up Config.js, but if it contains faults, then I will be back to square one.
        * MagicMirror² Config Sample
         * By Michael Teeuw https://michaelteeuw.nl
         * MIT Licensed.
         * see https://docs.magicmirror.builders/configuration/introduction.html
         * and https://docs.magicmirror.builders/modules/configuration.html
        let config = {
        	address: "localhost", 	// Address to listen on, can be:
        	port: 8080,
        	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
        	ipWhitelist: [], 	// Set [] to allow all IP addresses
        															// or add a specific IPv4 of 192.168.2.49 :
        	language: "en",
        	locale: "en-US",
        	timeFormat: 24,
        	units: "metric",
        	module: 'MMM-MovieListings',
                                        position: 'bottom_center',   // This can be any of the regions. Best results in left or$
        					apiKey: '',
        					region: 'GB',
        					language: 'en-UK',
        					interface: 'poster', //'list', 'poster', 'detailed'
        					includeMoviePlot: false,
        					maxPlotLength: 198,
        					header: 'Kinofilme',
        					moviesPerPage: 0,
        					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
        					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
        					animationSpeed: 2.5 * 1000,
        					pageChangeInterval: 35 * 1000
                module: 'MMM-Globe',
        	position: 'bottom_left',
        		style: 'geoColor',
        		imageSize: 300,
        		ownImagePath:'',
        		updateInterval: 10*60*1000
          module: 'MMM-Tools',
          position: 'bottom_right',
            refresh: 1000 * 5,
            containerSize: null,
            itemSize: null
            module: "MMM-EyeCandy",
            position: "top_center",
                maxWidth: "75%",       // Sizes the images. Retains aspect ratio.
                style: '1',            // Style number or use ownImagePath to override style
                ownImagePath: '',      // 'modules/MMM-EyeCandy/pix/name-graphics-lisa-596441.jpg'
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_right"
        			header: "UK Holidays",
        						symbol: "calendar-check-o ",
                                url: "https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
        			module: "compliments",
        			position: "top_bar"
        			module: "MMM-OpenmapWeather",
        		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
        		header: "Current Weather", //Location is the default value if header is empty or not defined.
        			locationID: "2651817", //Location ID from http://openweathermap.org/help/city_list.txt
        			appid: "",  //openweathermap.org API key
              			colorIcon: true
        		module:"MMM-Config",
        		position:"top_left",
        			// the QR code (if requested) will appear here
        		config:{
                                showQR: true
        			module: "weather",
        			header: "Weather Forecast",
        				type: "forecast",
        				locationID: "2651817", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        				apiKey: ""
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "BBC UK News",
        						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
        				showSourceTitle: true,
        				showPublishDate: true,
        				broadcastNewsFeeds: true,
        				broadcastNewsUpdates: true
          sdetweil @DarkV
          @DarkV i do not SEE anything, but i am away from my computer all day, driving.
          so i cannot run it thru the
          npm run config:check
          command
            DarkV @sdetweil
            @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
            [04.04.2025 16:09.03.683] [INFO] Checking file… /home/junior/MagicMirror/config/config.js
            [04.04.2025 16:09.03.781] [INFO] Your configuration file doesn’t contain syntax errors :)
            junior@MAGIC-MIRROR:~/MagicMirror $
              sdetweil @DarkV
              @DarkV ok
              now do
              cd ~/MagicMirror/MMM-Config
              ./test-convert.sh override
              you should get one message
              completed
                DarkV @sdetweil
                Results
                junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test-convert.sh override
                -bash: ./test-convert.sh: No such file or directory
                I used a fresh SD card for the reinstallation, but some of her modules are incompatible with the new setup. Consequently, my wife has firmly decided to stick with the current version until her modules stop functioning. Unfortunately, since one of the modules doesn’t work with the old MagicMirror version, I’m at an impasse. It is a pity, I wanted this as due to dyslexia, this would have been perfect for my situation
                  sdetweil @DarkV
                  @DarkV ok,my fault
                  cd ~/MagicMirror/modules/MMM-Config
                  ./test_convert.sh  override
                    DarkV @sdetweil
                    junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test_convert.sh overri de
                    --------------------MMM-Config
                    module updatenotification-defaults has an error in the construction of its defau lts section
                    the error line is disabled: true;
                    please change it to the literal value of the referenced variable
                    and restart MagicMirror
                      sdetweil @DarkV
                      @DarkV can you show the top of the modules/defaul/updatenotification/updatenotification.js
                      make sure the defaults section is shown
                      you know you never edit any of the MagicMirror source or module source
                      all config goes in config/config.js and all css goes in css/custom.css
                        DarkV @sdetweil
                        My bad,iI was trying to dissable the “Update available” banner at the top of mirror
                        /* MagicMirror²
                        • Module: UpdateNotification
                        • By Michael Teeuw https://michaelteeuw.nl
                        • MIT Licensed.
                          Module.register(“updatenotification”, {
                          defaults: {
                          updateInterval: 10 * 60 * 1000, // every 10 minutes
                          refreshInterval: 24 * 60 * 60 * 1000, // one day
                          ignoreModules: [],
                          sendUpdatesNotifications: false,
                          updates: [],
                          updateTimeout: 2 * 60 * 1000, // max update duration
                          updateAutorestart: false // autoRestart MM when update done ?
                          disabled: true;
                          suspended: false,
                          moduleList: {},
                          needRestart: false,
                          updates: {},
                          start () {
                          Log.info(Starting module: ${this.name});
                          this.addFilters();
                          setInterval(() => {
                          this.moduleList = {};
                          this.updateDom(2);
                          }, this.config.refreshInterval);
                          suspend () {
                          this.suspended = true;
                          resume () {
                          this.suspended = false;
                          this.updateDom(2);
                          notificationReceived (notification) {
                          switch (notification) {
                          case “DOM_OBJECTS_CREATED”:
                          this.sendSocketNotification(“CONFIG”, this.config);
                          this.sendSocketNotification(“MODULES”, Object.keys(Module.definitions));
                          break;
                          case “SCAN_UPDATES”:
                          this.sendSocketNotification(“SCAN_UPDATES”);
                          break;
                          socketNotificationReceived (notification, payload) {
                          case “REPO_STATUS”:
                          this.updateUI(payload);
                          break;
                          case “UPDATES”:
                          this.sendNotification(“UPDATES”, payload);
                          break;
                          case “UPDATE_STATUS”:
                          this.updatesNotifier(payload);
                          break;
                          getStyles () {
                          return [${this.name}.css];
                          getTemplate () {
                          return ${this.name}.njk;
                          getTemplateData () {
                          return { moduleList: this.moduleList, updatesList: this.updates, suspended: this.suspended, needRestart: this.needRestart };
                          updateUI (payload) {
                          if (payload && payload.behind > 0) {
                          // if we haven’t seen info for this module
                          if (this.moduleList[payload.module] === undefined) {
                          // save it
                          this.moduleList[payload.module] = payload;
                          this.updateDom(2);
                          } else if (payload && payload.behind === 0) {
                          // if the module WAS in the list, but shouldn’t be
                          if (this.moduleList[payload.module] !== undefined) {
                          // remove it
                          delete this.moduleList[payload.module];
                          this.updateDom(2);
                          addFilters () {
                          this.nunjucksEnvironment().addFilter(“diffLink”, (text, status) => {
                          if (status.module !== “MagicMirror”) {
                          return text;
                           	const localRef = status.hash;
                           	const remoteRef = status.tracking.replace(/.*\//, "");
                           	return `<a href="https://github.com/MichMich/MagicMirror/compare/${localRef}...${remoteRef}" class="xsmall dimmed difflink" target="_blank">${text}</a>`;
                          updatesNotifier (payload, done = true) {
                          if (this.updates[payload.name] === undefined) {
                          this.updates[payload.name] = {
                          sdetweil @DarkV
                          @DarkV yes i understand
                          lets restore the updatenotification module file
                          git checkout modules/default/updatenotification/updatenotification.js
                          then lets edit config.js to disable the module
                                module:"updatenotification",
                                position:"top_bar",
                                disabled:true
                            DarkV @sdetweil
                            fatal: not a git repository (or any of the parent directories): .git
                              sdetweil @DarkV
                              @DarkV hmmm
                              how did you install MagicMirror
                              manual, scripted or zip file download ?
                              • JohanbaJ
                                Johanba
                                Also not getting it to work
                                in the browser i go to installer
                                and this is all that loads
                                  sdetweil @Johanba
                                  @Johanba i posted in your other topic
                                    DarkV @sdetweil
                                    @sdetweil Script
                                    You helped me on a while backScreenshot 2025-04-10 at 11-54-21 Failed Update MagicMirror Forum.png
                                      sdetweil @DarkV
                                      @DarkV i understand, but that wasn’t the question
                                      the git checkout command should have worked,
                                      but failed.
                                      now i am trying to figure out why. and what to do about it
                                      the command prompt looks different after
                                      then the last time you did a command
                                      so try this way
                                      go to your MagicMirror folder
                                      and do git status
                                      show the results
                                        DarkV @sdetweil
                                        git status
                                        junior@MAGIC-MIRROR:~ $ cd ~/MagicMirror/modules/MMM-Config
                                        junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ git status
                                        On branch main
                                        Your branch is up to date with ‘origin/main’.
                                        nothing to commit, working tree clean
                                        junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ cd ~/MagicMirror
                                        junior@MAGIC-MIRROR:~/MagicMirror $ git status
                                          sdetweil @DarkV
                                          @DarkV asking again, how did you install MagicMirror?
                                            DarkV @sdetweil
                                            @sdetweil I think it must have been a script on the net. It was quite a long time ago, between 2022 and 2023. I honestly cannot remember. I found an old config.js from ‎06 ‎October ‎2023
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 15 / 15
