    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 464.2k Views 31 Watching
    • I Offline
      IamWayne
      Oh I think that I understand now. I have to add this to the MM installer in the correct folder, correct?
        sdetweil @IamWayne
        @IamWayne this is an add on module, not part of the base
        see the 1st link in my signature below for short topic about installing modules
        • citizendevpiC Offline
          citizendevpi
          this module works very well , thanks for the hard work and time . makes this project simple and fun !!
            DarkV @sdetweil
            @sdetweil Still no joy, I am going to reinstall.I cannot display the QR code as I do not have any zones left and cannot load the web page1.png Screenshot 2025-04-03 155111.png
              sdetweil @DarkV
              @DarkV you dont need the qr code
              can you show the messages from npm start?
              if using pm2 then
              pm2 logs --lines=100
                DarkV @sdetweil
                @sdetweil How do I get logs? I am a noob regarding MM
                I found this
                [08.01.2025 00:49.42.199] [ERROR] Failed to retrieve repo info for MMM-Tools: Error: Command failed: cd /home/junior/MagicMirror/modules/MMM-Tools && git fetch -n --dry-run
                fatal: unable to access ‘https://github.com/bugsounet/MMM-Tools/’: Could not resolve host: github.com
                  DarkV @sdetweil
                    sdetweil @DarkV
                    @DarkV way back further in the log, back 50 lines maybe
                    as using pm2 the good and error lines are separated into two lists
                    none of the bugsounet repos are online any more
                    so if you dont want to see those errors, you can exclude them from the updatenotification module scans
                      DarkV @sdetweil
                      @sdetweil SyntaxError: Unexpected identifier 'config’
                       at internalCompileFunction (node:internal/vm:73:18)
                       at wrapSafe (node:internal/modules/cjs/loader:1185:20)
                       at Module._compile (node:internal/modules/cjs/loader:1227:27)
                       at Object…js (node:internal/modules/cjs/loader:1326:10)
                       at Module.load (node:internal/modules/cjs/loader:1126:32)
                       at node:internal/modules/cjs/loader:967:12
                       at Function._load (node:electron/js2c/node_init:2:13357)
                       at Module.require (node:internal/modules/cjs/loader:1150:19)
                       at require (node:internal/modules/cjs/helpers:121:18)
                       at loadConfig (/home/junior/MagicMirror/js/app.js:118:14)
                       at App.start (/home/junior/MagicMirror/js/app.js:248:18)
                       at Object. (/home/junior/MagicMirror/js/electron.js:192:7)
                       at Module._compile (node:internal/modules/cjs/loader:1271:14)
                      /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                      [27.03.2025 09:44.46.126] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                      Warning: vkCreateInstance: Found no drivers!
                      Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                      at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                      at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                      at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                      at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                      at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                      [27.03.2025 09:46.55.825] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:122
                      [27.03.2025 09:47.26.134] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                      [27.03.2025 09:53.43.417] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                      [27.03.2025 09:59.04.576] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                      [27.03.2025 10:02.53.766] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                      [27.03.2025 10:15.08.770] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                      SyntaxError: Unexpected token '{'
                      [27.03.2025 10:15.58.981] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                      /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                      [27.03.2025 10:22.57.762] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                      [27.03.2025 10:29.29.494] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                      [27.03.2025 10:30.26.627] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                        sdetweil @DarkV
                        @DarkV mmm-config requires MagicMirror version 2.28 or higher
                        also, you have some syntax error around line 122 in config.js
                        pm2 flush to empty the logs
                        and see what hsppens after you fix that config.js error
                          DarkV @sdetweil
                          @sdetweil, I’m sorry. Can you please highlight where I have the error? I am considering reinstalling it as I cannot even update Magic Mirror. I want to back up Config.js, but if it contains faults, then I will be back to square one.
                          * MagicMirror² Config Sample
                           * By Michael Teeuw https://michaelteeuw.nl
                           * MIT Licensed.
                           * see https://docs.magicmirror.builders/configuration/introduction.html
                           * and https://docs.magicmirror.builders/modules/configuration.html
                          let config = {
                          	address: "localhost", 	// Address to listen on, can be:
                          	port: 8080,
                          	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                          	ipWhitelist: [], 	// Set [] to allow all IP addresses
                          															// or add a specific IPv4 of 192.168.2.49 :
                          	language: "en",
                          	locale: "en-US",
                          	timeFormat: 24,
                          	units: "metric",
                          	module: 'MMM-MovieListings',
                                                          position: 'bottom_center',   // This can be any of the regions. Best results in left or$
                          					apiKey: '',
                          					region: 'GB',
                          					language: 'en-UK',
                          					interface: 'poster', //'list', 'poster', 'detailed'
                          					includeMoviePlot: false,
                          					maxPlotLength: 198,
                          					header: 'Kinofilme',
                          					moviesPerPage: 0,
                          					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                          					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                          					animationSpeed: 2.5 * 1000,
                          					pageChangeInterval: 35 * 1000
                                  module: 'MMM-Globe',
                          	position: 'bottom_left',
                          		style: 'geoColor',
                          		imageSize: 300,
                          		ownImagePath:'',
                          		updateInterval: 10*60*1000
                            module: 'MMM-Tools',
                            position: 'bottom_right',
                              refresh: 1000 * 5,
                              containerSize: null,
                              itemSize: null
                              module: "MMM-EyeCandy",
                              position: "top_center",
                                  maxWidth: "75%",       // Sizes the images. Retains aspect ratio.
                                  style: '1',            // Style number or use ownImagePath to override style
                                  ownImagePath: '',      // 'modules/MMM-EyeCandy/pix/name-graphics-lisa-596441.jpg'
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_right"
                          			header: "UK Holidays",
                          						symbol: "calendar-check-o ",
                                                  url: "https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
                          			module: "compliments",
                          			position: "top_bar"
                          			module: "MMM-OpenmapWeather",
                          		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                          		header: "Current Weather", //Location is the default value if header is empty or not defined.
                          			locationID: "2651817", //Location ID from http://openweathermap.org/help/city_list.txt
                          			appid: "",  //openweathermap.org API key
                                			colorIcon: true
                          		module:"MMM-Config",
                          		position:"top_left",
                          			// the QR code (if requested) will appear here
                          		config:{
                                                  showQR: true
                          			module: "weather",
                          			header: "Weather Forecast",
                          				type: "forecast",
                          				locationID: "2651817", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                          				apiKey: ""
                          			module: "newsfeed",
                          			position: "bottom_bar",
                          				feeds: [
                          						title: "BBC UK News",
                          						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
                          				showSourceTitle: true,
                          				showPublishDate: true,
                          				broadcastNewsFeeds: true,
                          				broadcastNewsUpdates: true
                            sdetweil @DarkV
                            @DarkV i do not SEE anything, but i am away from my computer all day, driving.
                            so i cannot run it thru the
                            npm run config:check
                            command
                              DarkV @sdetweil
                              @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                              [04.04.2025 16:09.03.683] [INFO] Checking file… /home/junior/MagicMirror/config/config.js
                              [04.04.2025 16:09.03.781] [INFO] Your configuration file doesn’t contain syntax errors :)
                              junior@MAGIC-MIRROR:~/MagicMirror $
                                sdetweil @DarkV
                                @DarkV ok
                                now do
                                cd ~/MagicMirror/MMM-Config
                                ./test-convert.sh override
                                you should get one message
                                completed
                                  DarkV @sdetweil
                                  Results
                                  junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test-convert.sh override
                                  -bash: ./test-convert.sh: No such file or directory
                                  I used a fresh SD card for the reinstallation, but some of her modules are incompatible with the new setup. Consequently, my wife has firmly decided to stick with the current version until her modules stop functioning. Unfortunately, since one of the modules doesn’t work with the old MagicMirror version, I’m at an impasse. It is a pity, I wanted this as due to dyslexia, this would have been perfect for my situation
                                    sdetweil @DarkV
                                    @DarkV ok,my fault
                                    cd ~/MagicMirror/modules/MMM-Config
                                    ./test_convert.sh  override
                                      DarkV @sdetweil
                                      junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test_convert.sh overri de
                                      --------------------MMM-Config
                                      module updatenotification-defaults has an error in the construction of its defau lts section
                                      the error line is disabled: true;
                                      please change it to the literal value of the referenced variable
                                      and restart MagicMirror
                                        sdetweil @DarkV
                                        @DarkV can you show the top of the modules/defaul/updatenotification/updatenotification.js
                                        make sure the defaults section is shown
                                        you know you never edit any of the MagicMirror source or module source
                                        all config goes in config/config.js and all css goes in css/custom.css
                                          DarkV @sdetweil
                                          My bad,iI was trying to dissable the “Update available” banner at the top of mirror
                                          /* MagicMirror²
                                          • Module: UpdateNotification
                                          • By Michael Teeuw https://michaelteeuw.nl
                                          • MIT Licensed.
                                            Module.register(“updatenotification”, {
                                            defaults: {
                                            updateInterval: 10 * 60 * 1000, // every 10 minutes
                                            refreshInterval: 24 * 60 * 60 * 1000, // one day
                                            ignoreModules: [],
                                            sendUpdatesNotifications: false,
                                            updates: [],
                                            updateTimeout: 2 * 60 * 1000, // max update duration
                                            updateAutorestart: false // autoRestart MM when update done ?
                                            disabled: true;
                                            suspended: false,
                                            moduleList: {},
                                            needRestart: false,
                                            updates: {},
                                            start () {
                                            Log.info(Starting module: ${this.name});
                                            this.addFilters();
                                            setInterval(() => {
                                            this.moduleList = {};
                                            this.updateDom(2);
                                            }, this.config.refreshInterval);
                                            suspend () {
                                            this.suspended = true;
                                            resume () {
                                            this.suspended = false;
                                            this.updateDom(2);
                                            notificationReceived (notification) {
                                            switch (notification) {
                                            case “DOM_OBJECTS_CREATED”:
                                            this.sendSocketNotification(“CONFIG”, this.config);
                                            this.sendSocketNotification(“MODULES”, Object.keys(Module.definitions));
                                            break;
                                            case “SCAN_UPDATES”:
                                            this.sendSocketNotification(“SCAN_UPDATES”);
                                            break;
                                            socketNotificationReceived (notification, payload) {
                                            case “REPO_STATUS”:
                                            this.updateUI(payload);
                                            break;
                                            case “UPDATES”:
                                            this.sendNotification(“UPDATES”, payload);
                                            break;
                                            case “UPDATE_STATUS”:
                                            this.updatesNotifier(payload);
                                            break;
                                            getStyles () {
                                            return [${this.name}.css];
                                            getTemplate () {
                                            return ${this.name}.njk;
                                            getTemplateData () {
                                            return { moduleList: this.moduleList, updatesList: this.updates, suspended: this.suspended, needRestart: this.needRestart };
                                            updateUI (payload) {
                                            if (payload && payload.behind > 0) {
                                            // if we haven’t seen info for this module
                                            if (this.moduleList[payload.module] === undefined) {
                                            // save it
                                            this.moduleList[payload.module] = payload;
                                            this.updateDom(2);
                                            } else if (payload && payload.behind === 0) {
                                            // if the module WAS in the list, but shouldn’t be
                                            if (this.moduleList[payload.module] !== undefined) {
                                            // remove it
                                            delete this.moduleList[payload.module];
                                            this.updateDom(2);
                                            addFilters () {
                                            this.nunjucksEnvironment().addFilter(“diffLink”, (text, status) => {
                                            if (status.module !== “MagicMirror”) {
                                            return text;
                                             	const localRef = status.hash;
                                             	const remoteRef = status.tracking.replace(/.*\//, "");
                                             	return `<a href="https://github.com/MichMich/MagicMirror/compare/${localRef}...${remoteRef}" class="xsmall dimmed difflink" target="_blank">${text}</a>`;
                                            updatesNotifier (payload, done = true) {
                                            if (this.updates[payload.name] === undefined) {
                                            this.updates[payload.name] = {
                                            sdetweil @DarkV
                                            @DarkV yes i understand
                                            lets restore the updatenotification module file
                                            git checkout modules/default/updatenotification/updatenotification.js
                                            then lets edit config.js to disable the module
                                                  module:"updatenotification",
                                                  position:"top_bar",
                                                  disabled:true
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
