    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.3k Views 31 Watching
      sdetweil @DarkV
      @DarkV way back further in the log, back 50 lines maybe
      as using pm2 the good and error lines are separated into two lists
      none of the bugsounet repos are online any more
      so if you dont want to see those errors, you can exclude them from the updatenotification module scans
        DarkV @sdetweil
        @sdetweil SyntaxError: Unexpected identifier 'config’
         at internalCompileFunction (node:internal/vm:73:18)
         at wrapSafe (node:internal/modules/cjs/loader:1185:20)
         at Module._compile (node:internal/modules/cjs/loader:1227:27)
         at Object…js (node:internal/modules/cjs/loader:1326:10)
         at Module.load (node:internal/modules/cjs/loader:1126:32)
         at node:internal/modules/cjs/loader:967:12
         at Function._load (node:electron/js2c/node_init:2:13357)
         at Module.require (node:internal/modules/cjs/loader:1150:19)
         at require (node:internal/modules/cjs/helpers:121:18)
         at loadConfig (/home/junior/MagicMirror/js/app.js:118:14)
         at App.start (/home/junior/MagicMirror/js/app.js:248:18)
         at Object. (/home/junior/MagicMirror/js/electron.js:192:7)
         at Module._compile (node:internal/modules/cjs/loader:1271:14)
        /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
        [27.03.2025 09:44.46.126] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
        Warning: vkCreateInstance: Found no drivers!
        Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
        at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
        at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
        at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
        at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
        at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
        [27.03.2025 09:46.55.825] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:122
        [27.03.2025 09:47.26.134] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
        [27.03.2025 09:53.43.417] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
        [27.03.2025 09:59.04.576] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
        [27.03.2025 10:02.53.766] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
        [27.03.2025 10:15.08.770] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
        SyntaxError: Unexpected token '{'
        [27.03.2025 10:15.58.981] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
        /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
        [27.03.2025 10:22.57.762] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
        [27.03.2025 10:29.29.494] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
        [27.03.2025 10:30.26.627] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
          sdetweil @DarkV
          @DarkV mmm-config requires MagicMirror version 2.28 or higher
          also, you have some syntax error around line 122 in config.js
          pm2 flush to empty the logs
          and see what hsppens after you fix that config.js error
            DarkV @sdetweil
            @sdetweil, I’m sorry. Can you please highlight where I have the error? I am considering reinstalling it as I cannot even update Magic Mirror. I want to back up Config.js, but if it contains faults, then I will be back to square one.
            * MagicMirror² Config Sample
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
             * see https://docs.magicmirror.builders/configuration/introduction.html
             * and https://docs.magicmirror.builders/modules/configuration.html
            let config = {
            	address: "localhost", 	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
            	ipWhitelist: [], 	// Set [] to allow all IP addresses
            															// or add a specific IPv4 of 192.168.2.49 :
            	language: "en",
            	locale: "en-US",
            	timeFormat: 24,
            	units: "metric",
            	module: 'MMM-MovieListings',
                                            position: 'bottom_center',   // This can be any of the regions. Best results in left or$
            					apiKey: '',
            					region: 'GB',
            					language: 'en-UK',
            					interface: 'poster', //'list', 'poster', 'detailed'
            					includeMoviePlot: false,
            					maxPlotLength: 198,
            					header: 'Kinofilme',
            					moviesPerPage: 0,
            					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
            					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
            					animationSpeed: 2.5 * 1000,
            					pageChangeInterval: 35 * 1000
                    module: 'MMM-Globe',
            	position: 'bottom_left',
            		style: 'geoColor',
            		imageSize: 300,
            		ownImagePath:'',
            		updateInterval: 10*60*1000
              module: 'MMM-Tools',
              position: 'bottom_right',
                refresh: 1000 * 5,
                containerSize: null,
                itemSize: null
                module: "MMM-EyeCandy",
                position: "top_center",
                    maxWidth: "75%",       // Sizes the images. Retains aspect ratio.
                    style: '1',            // Style number or use ownImagePath to override style
                    ownImagePath: '',      // 'modules/MMM-EyeCandy/pix/name-graphics-lisa-596441.jpg'
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_right"
            			header: "UK Holidays",
            						symbol: "calendar-check-o ",
                                    url: "https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
            			module: "compliments",
            			position: "top_bar"
            			module: "MMM-OpenmapWeather",
            		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
            		header: "Current Weather", //Location is the default value if header is empty or not defined.
            			locationID: "2651817", //Location ID from http://openweathermap.org/help/city_list.txt
            			appid: "",  //openweathermap.org API key
                  			colorIcon: true
            		module:"MMM-Config",
            		position:"top_left",
            			// the QR code (if requested) will appear here
            		config:{
                                    showQR: true
            			module: "weather",
            			header: "Weather Forecast",
            				type: "forecast",
            				locationID: "2651817", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            				apiKey: ""
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "BBC UK News",
            						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: true,
            				broadcastNewsUpdates: true
              sdetweil @DarkV
              @DarkV i do not SEE anything, but i am away from my computer all day, driving.
              so i cannot run it thru the
              npm run config:check
              command
                DarkV @sdetweil
                @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                [04.04.2025 16:09.03.683] [INFO] Checking file… /home/junior/MagicMirror/config/config.js
                [04.04.2025 16:09.03.781] [INFO] Your configuration file doesn’t contain syntax errors :)
                junior@MAGIC-MIRROR:~/MagicMirror $
                  sdetweil @DarkV
                  @DarkV ok
                  now do
                  cd ~/MagicMirror/MMM-Config
                  ./test-convert.sh override
                  you should get one message
                  completed
                    DarkV @sdetweil
                    Results
                    junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test-convert.sh override
                    -bash: ./test-convert.sh: No such file or directory
                    I used a fresh SD card for the reinstallation, but some of her modules are incompatible with the new setup. Consequently, my wife has firmly decided to stick with the current version until her modules stop functioning. Unfortunately, since one of the modules doesn’t work with the old MagicMirror version, I’m at an impasse. It is a pity, I wanted this as due to dyslexia, this would have been perfect for my situation
                      sdetweil @DarkV
                      @DarkV ok,my fault
                      cd ~/MagicMirror/modules/MMM-Config
                      ./test_convert.sh  override
                        DarkV @sdetweil
                        junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test_convert.sh overri de
                        --------------------MMM-Config
                        module updatenotification-defaults has an error in the construction of its defau lts section
                        the error line is disabled: true;
                        please change it to the literal value of the referenced variable
                        and restart MagicMirror
                          sdetweil @DarkV
                          @DarkV can you show the top of the modules/defaul/updatenotification/updatenotification.js
                          make sure the defaults section is shown
                          you know you never edit any of the MagicMirror source or module source
                          all config goes in config/config.js and all css goes in css/custom.css
                            DarkV @sdetweil
                            My bad,iI was trying to dissable the “Update available” banner at the top of mirror
                            /* MagicMirror²
                            • Module: UpdateNotification
                            • By Michael Teeuw https://michaelteeuw.nl
                            • MIT Licensed.
                              Module.register(“updatenotification”, {
                              defaults: {
                              updateInterval: 10 * 60 * 1000, // every 10 minutes
                              refreshInterval: 24 * 60 * 60 * 1000, // one day
                              ignoreModules: [],
                              sendUpdatesNotifications: false,
                              updates: [],
                              updateTimeout: 2 * 60 * 1000, // max update duration
                              updateAutorestart: false // autoRestart MM when update done ?
                              disabled: true;
                              suspended: false,
                              moduleList: {},
                              needRestart: false,
                              updates: {},
                              start () {
                              Log.info(Starting module: ${this.name});
                              this.addFilters();
                              setInterval(() => {
                              this.moduleList = {};
                              this.updateDom(2);
                              }, this.config.refreshInterval);
                              suspend () {
                              this.suspended = true;
                              resume () {
                              this.suspended = false;
                              this.updateDom(2);
                              notificationReceived (notification) {
                              switch (notification) {
                              case “DOM_OBJECTS_CREATED”:
                              this.sendSocketNotification(“CONFIG”, this.config);
                              this.sendSocketNotification(“MODULES”, Object.keys(Module.definitions));
                              break;
                              case “SCAN_UPDATES”:
                              this.sendSocketNotification(“SCAN_UPDATES”);
                              break;
                              socketNotificationReceived (notification, payload) {
                              case “REPO_STATUS”:
                              this.updateUI(payload);
                              break;
                              case “UPDATES”:
                              this.sendNotification(“UPDATES”, payload);
                              break;
                              case “UPDATE_STATUS”:
                              this.updatesNotifier(payload);
                              break;
                              getStyles () {
                              return [${this.name}.css];
                              getTemplate () {
                              return ${this.name}.njk;
                              getTemplateData () {
                              return { moduleList: this.moduleList, updatesList: this.updates, suspended: this.suspended, needRestart: this.needRestart };
                              updateUI (payload) {
                              if (payload && payload.behind > 0) {
                              // if we haven’t seen info for this module
                              if (this.moduleList[payload.module] === undefined) {
                              // save it
                              this.moduleList[payload.module] = payload;
                              this.updateDom(2);
                              } else if (payload && payload.behind === 0) {
                              // if the module WAS in the list, but shouldn’t be
                              if (this.moduleList[payload.module] !== undefined) {
                              // remove it
                              delete this.moduleList[payload.module];
                              this.updateDom(2);
                              addFilters () {
                              this.nunjucksEnvironment().addFilter(“diffLink”, (text, status) => {
                              if (status.module !== “MagicMirror”) {
                              return text;
                               	const localRef = status.hash;
                               	const remoteRef = status.tracking.replace(/.*\//, "");
                               	return `<a href="https://github.com/MichMich/MagicMirror/compare/${localRef}...${remoteRef}" class="xsmall dimmed difflink" target="_blank">${text}</a>`;
                              updatesNotifier (payload, done = true) {
                              if (this.updates[payload.name] === undefined) {
                              this.updates[payload.name] = {
                              sdetweil @DarkV
                              @DarkV yes i understand
                              lets restore the updatenotification module file
                              git checkout modules/default/updatenotification/updatenotification.js
                              then lets edit config.js to disable the module
                                    module:"updatenotification",
                                    position:"top_bar",
                                    disabled:true
                                DarkV @sdetweil
                                fatal: not a git repository (or any of the parent directories): .git
                                  sdetweil @DarkV
                                  @DarkV hmmm
                                  how did you install MagicMirror
                                  manual, scripted or zip file download ?
                                  • JohanbaJ
                                    Johanba
                                    Also not getting it to work
                                    in the browser i go to installer
                                    and this is all that loads
                                      sdetweil @Johanba
                                      @Johanba i posted in your other topic
                                        DarkV @sdetweil
                                        @sdetweil Script
                                        You helped me on a while backScreenshot 2025-04-10 at 11-54-21 Failed Update MagicMirror Forum.png
                                          sdetweil @DarkV
                                          @DarkV i understand, but that wasn’t the question
                                          the git checkout command should have worked,
                                          but failed.
                                          now i am trying to figure out why. and what to do about it
                                          the command prompt looks different after
                                          then the last time you did a command
                                          so try this way
                                          go to your MagicMirror folder
                                          and do git status
                                          show the results
                                            DarkV @sdetweil
                                            git status
                                            junior@MAGIC-MIRROR:~ $ cd ~/MagicMirror/modules/MMM-Config
                                            junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ git status
                                            On branch main
                                            Your branch is up to date with ‘origin/main’.
                                            nothing to commit, working tree clean
                                            junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ cd ~/MagicMirror
                                            junior@MAGIC-MIRROR:~/MagicMirror $ git status
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
