    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      DarkV
      I am a noob at this, how do I set the port to use the browser and how do I show the QR code on my MM?
        sdetweil @DarkV
        @DarkV the default port is 8080
        you can edit in config.js and change the number, or change it in the form
        and in the MMM-Config config set showQR to true
        the doc mentions how to open the form directly in a browser
        note on the QR you MUST change config.js to support outside MagicMirror system access, per the doc
        D 1 Reply Last reply
          DarkV @sdetweil
          @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
          config set showQR
          So, should I add “showQR = True” to the configj.s?
          As I said earlier, I do not have the skill of the format.
            DarkV @DarkV
            @DarkV
              sdetweil @DarkV
              @DarkV the doc (README.md) says the url
                DarkV @sdetweil
                @sdetweil Apologies for my lack of knowledge, but I didn’t fully understand your response about the URL. Please keep in mind that I’m not very experienced with coding.
                  sdetweil @DarkV
                  @DarkV it takes a little bit of info
                  a url contains
                  a protocol type secure(https) or not (http)
                  a server name or address
                  a port
                  a path
                  and optionally some parameters
                  for MMM-Config
                  just protocol, server, port and path
                  on your local network, we dont need to build our everything for secure encrypted communications
                  if the machine you are opening the browser on is the same machine as MagicMirror is running, then you can use localhost
                  otherwise you need to know the MagicMirror server ip address or network name
                  the port value comes from the MagicMirror config.js, default is 8080
                  (if you dont see a port specified in a url, then the browser uses the default for the protocol, 80 or 443 not/secure, as appropriate)
                  and then the path, for MMM-Config there are two :
                  for configuration
                  /configure
                  and for module installation
                  /installer
                  http://ip:port/configure
                  on the same machine, using defaults
                  http://localhost:8080/configure
                  • I
                    IamWayne
                    Hello, Newbie here, how do you go about using this? What do I need to get started? Do I need Node.js? Have it installed, yet completely lost. How about a guide or video. Thanks
                      sdetweil @IamWayne
                      @IamWayne did you add the module to config.js?
                      and restart MagicMirror?
                      if so then the url from the doc
                      http://ip:mm_port/configure
                      but by default the MagicMirror config only allows apps from inside the same system to connect, so you would have to minimize MagicMirror then launch a browser to
                      or for the module installer
                      http://localhost:8080/installer
                      • I
                        IamWayne
                        Oh I think that I understand now. I have to add this to the MM installer in the correct folder, correct?
                          sdetweil @IamWayne
                          @IamWayne this is an add on module, not part of the base
                          see the 1st link in my signature below for short topic about installing modules
                          • citizendevpiC
                            citizendevpi
                            this module works very well , thanks for the hard work and time . makes this project simple and fun !!
                              DarkV @sdetweil
                              @sdetweil Still no joy, I am going to reinstall.I cannot display the QR code as I do not have any zones left and cannot load the web page1.png Screenshot 2025-04-03 155111.png
                                sdetweil @DarkV
                                @DarkV you dont need the qr code
                                can you show the messages from npm start?
                                if using pm2 then
                                pm2 logs --lines=100
                                D 2 Replies Last reply
                                  DarkV @sdetweil
                                  @sdetweil How do I get logs? I am a noob regarding MM
                                  I found this
                                  [08.01.2025 00:49.42.199] [ERROR] Failed to retrieve repo info for MMM-Tools: Error: Command failed: cd /home/junior/MagicMirror/modules/MMM-Tools && git fetch -n --dry-run
                                  fatal: unable to access ‘https://github.com/bugsounet/MMM-Tools/’: Could not resolve host: github.com
                                    DarkV @sdetweil
                                      sdetweil @DarkV
                                      @DarkV way back further in the log, back 50 lines maybe
                                      as using pm2 the good and error lines are separated into two lists
                                      none of the bugsounet repos are online any more
                                      so if you dont want to see those errors, you can exclude them from the updatenotification module scans
                                        DarkV @sdetweil
                                        @sdetweil SyntaxError: Unexpected identifier 'config’
                                         at internalCompileFunction (node:internal/vm:73:18)
                                         at wrapSafe (node:internal/modules/cjs/loader:1185:20)
                                         at Module._compile (node:internal/modules/cjs/loader:1227:27)
                                         at Object…js (node:internal/modules/cjs/loader:1326:10)
                                         at Module.load (node:internal/modules/cjs/loader:1126:32)
                                         at node:internal/modules/cjs/loader:967:12
                                         at Function._load (node:electron/js2c/node_init:2:13357)
                                         at Module.require (node:internal/modules/cjs/loader:1150:19)
                                         at require (node:internal/modules/cjs/helpers:121:18)
                                         at loadConfig (/home/junior/MagicMirror/js/app.js:118:14)
                                         at App.start (/home/junior/MagicMirror/js/app.js:248:18)
                                         at Object. (/home/junior/MagicMirror/js/electron.js:192:7)
                                         at Module._compile (node:internal/modules/cjs/loader:1271:14)
                                        /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                        [27.03.2025 09:44.46.126] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                                        Warning: vkCreateInstance: Found no drivers!
                                        Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                                        at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                                        at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                                        at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                                        at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                                        at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                                        [27.03.2025 09:46.55.825] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:122
                                        [27.03.2025 09:47.26.134] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                                        [27.03.2025 09:53.43.417] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                                        [27.03.2025 09:59.04.576] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                                        [27.03.2025 10:02.53.766] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                                        [27.03.2025 10:15.08.770] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                                        SyntaxError: Unexpected token '{'
                                        [27.03.2025 10:15.58.981] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                                        /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                        [27.03.2025 10:22.57.762] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                                        [27.03.2025 10:29.29.494] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                                        [27.03.2025 10:30.26.627] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                                          sdetweil @DarkV
                                          @DarkV mmm-config requires MagicMirror version 2.28 or higher
                                          also, you have some syntax error around line 122 in config.js
                                          pm2 flush to empty the logs
                                          and see what hsppens after you fix that config.js error
                                            DarkV @sdetweil
                                            @sdetweil, I’m sorry. Can you please highlight where I have the error? I am considering reinstalling it as I cannot even update Magic Mirror. I want to back up Config.js, but if it contains faults, then I will be back to square one.
                                            * MagicMirror² Config Sample
                                             * By Michael Teeuw https://michaelteeuw.nl
                                             * MIT Licensed.
                                             * see https://docs.magicmirror.builders/configuration/introduction.html
                                             * and https://docs.magicmirror.builders/modules/configuration.html
                                            let config = {
                                            	address: "localhost", 	// Address to listen on, can be:
                                            	port: 8080,
                                            	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                            	ipWhitelist: [], 	// Set [] to allow all IP addresses
                                            															// or add a specific IPv4 of 192.168.2.49 :
                                            	language: "en",
                                            	locale: "en-US",
                                            	timeFormat: 24,
                                            	units: "metric",
                                            	module: 'MMM-MovieListings',
        position: 'bottom_center',   // This can be any of the regions. Best results in left or$
                                            					apiKey: '',
                                            					region: 'GB',
                                            					language: 'en-UK',
                                            					interface: 'poster', //'list', 'poster', 'detailed'
                                            					includeMoviePlot: false,
                                            					maxPlotLength: 198,
                                            					header: 'Kinofilme',
                                            					moviesPerPage: 0,
                                            					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                                            					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                                            					animationSpeed: 2.5 * 1000,
                                            					pageChangeInterval: 35 * 1000
                                                    module: 'MMM-Globe',
                                            	position: 'bottom_left',
                                            		style: 'geoColor',
                                            		imageSize: 300,
                                            		ownImagePath:'',
                                            		updateInterval: 10*60*1000
                                              module: 'MMM-Tools',
                                              position: 'bottom_right',
                                                refresh: 1000 * 5,
                                                containerSize: null,
                                                itemSize: null
                                                module: "MMM-EyeCandy",
                                                position: "top_center",
                                                    maxWidth: "75%",       // Sizes the images. Retains aspect ratio.
                                                    style: '1',            // Style number or use ownImagePath to override style
                                                    ownImagePath: '',      // 'modules/MMM-EyeCandy/pix/name-graphics-lisa-596441.jpg'
                                            			module: "alert",
                                            			module: "updatenotification",
                                            			position: "top_bar"
                                            			module: "clock",
                                            			position: "top_right"
                                            			header: "UK Holidays",
                                            						symbol: "calendar-check-o ",
        url: "https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
                                            			module: "compliments",
                                            			position: "top_bar"
                                            			module: "MMM-OpenmapWeather",
                                            		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                                            		header: "Current Weather", //Location is the default value if header is empty or not defined.
                                            			locationID: "2651817", //Location ID from http://openweathermap.org/help/city_list.txt
                                            			appid: "",  //openweathermap.org API key
                                                  			colorIcon: true
                                            		module:"MMM-Config",
                                            		position:"top_left",
                                            			// the QR code (if requested) will appear here
                                            		config:{
        showQR: true
                                            			module: "weather",
                                            			header: "Weather Forecast",
                                            				type: "forecast",
                                            				locationID: "2651817", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                            				apiKey: ""
                                            			module: "newsfeed",
                                            			position: "bottom_bar",
                                            				feeds: [
                                            						title: "BBC UK News",
                                            						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
                                            				showSourceTitle: true,
                                            				showPublishDate: true,
                                            				broadcastNewsFeeds: true,
                                            				broadcastNewsUpdates: true
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
