    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 464.2k Views 31 Watching
      @SteakExpert this is my startup
      (base) sam@sams:~/MagicMirror.old$ npm start
      > magicmirror@2.31.0-develop start
      > npm run start:x11
      > magicmirror@2.31.0-develop start:x11
      [2025-01-03 17:46:17.197] [LOG]   Starting MagicMirror: v2.31.0-develop
      [2025-01-03 17:46:17.209] [LOG]   Loading config ...
      [2025-01-03 17:46:17.209] [LOG]   config template file not exists, no envsubst
      [2025-01-03 17:46:17.348] [INFO]  Checking config file /home/sam/MagicMirror.old/config/config.js ...
      [2025-01-03 17:46:17.382] [INFO]  Your configuration file doesn't contain syntax errors :)
      [2025-01-03 17:46:17.382] [INFO]  Checking modules structure configuration ...
      [2025-01-03 17:46:17.409] [INFO]  Your modules structure configuration doesn't contain errors :)
      [2025-01-03 17:46:17.409] [LOG]   Loading module helpers ...
      [2025-01-03 17:46:17.462] [LOG]   Initializing new module helper ...
      [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-Wallpaper
      [2025-01-03 17:46:17.463] [LOG]   No helper found for module: clock.
      [2025-01-03 17:46:17.463] [LOG]   Initializing new module helper ...
      [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-EmbedURL
      [2025-01-03 17:46:17.527] [LOG]   Initializing new module helper ...
      [2025-01-03 17:46:17.527] [LOG]   Module helper loaded: MMM-Config
      [2025-01-03 17:46:17.534] [LOG]   Initializing new module helper ...
      [2025-01-03 17:46:17.534] [LOG]   Module helper loaded: MMM-HomeAssistantDisplay
      [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-CalendarExt3.
      [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-page-indicator.
      [2025-01-03 17:46:17.535] [LOG]   init module helper SampleModule
      [2025-01-03 17:46:17.535] [LOG]   Module helper loaded: SampleModule
      [2025-01-03 17:46:17.535] [LOG]   No helper found for module: MMM-pages.
      [2025-01-03 17:46:17.572] [LOG]   Initializing new module helper ...
      [2025-01-03 17:46:17.572] [LOG]   Module helper loaded: calendar
      [2025-01-03 17:46:17.572] [LOG]   All module helpers loaded.
      [2025-01-03 17:46:17.574] [LOG]   Starting server on port 8090 ...
      [2025-01-03 17:46:17.575] [WARN]  You're using a full whitelist configuration to allow for all IPs
      [2025-01-03 17:46:17.867] [LOG]   Server started ...
      [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Wallpaper
      [2025-01-03 17:46:17.867] [LOG]   Starting node helper for: MMM-Wallpaper
      [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-EmbedURL
      [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Config
      [2025-01-03 17:46:17.868] [INFO]  MMM-Config restart parm ='none'
      [2025-01-03 17:46:17.868] [LOG]   command =/home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
      [2025-01-03 17:46:17.868] [LOG]   Starting module helper:MMM-Config
      [2025-01-03 17:46:17.868] [LOG]   execing /home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
      [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: MMM-HomeAssistantDisplay
      [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: SampleModule
      [2025-01-03 17:46:17.875] [LOG]   Starting module helper:SampleModule
      [2025-01-03 17:46:17.876] [LOG]   Connecting socket for: calendar
      [2025-01-03 17:46:17.876] [LOG]   Starting node helper for: calendar
      [2025-01-03 17:46:17.876] [LOG]   Sockets connected & modules started ...
      [2025-01-03 17:46:17.876] [LOG]    got port=8300
      [2025-01-03 17:46:18.047] [LOG]   Launching application.
      [2025-01-03 17:46:18.224] [INFO]  System information:
      ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
      ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-125-generic
      ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
      ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
      [3484285:0103/174618.683913:ERROR:nss_util.cc(345)] After loading Root Certs, loaded==false: NSS error code: -8018
      [2025-01-03 17:46:18.707] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840963687&to=1666862563687&panelId=6 with error: ERR_NAME_NOT_RESOLVED
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [2025-01-03 17:46:18.708] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840776401&to=1666862376402&panelId=2 with error: ERR_NAME_NOT_RESOLVED
      [2025-01-03 17:46:18.711] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
      [2025-01-03 17:46:18.799] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_13_MMM-HomeAssistantDisplay' ]
      [2025-01-03 17:46:18.830] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_7_MMM-HomeAssistantDisplay' ]
      [2025-01-03 17:46:18.833] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 120000
      [2025-01-03 17:46:18.834] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-b01395933cda72021e36fae98c07a186/basic.ics - Interval: 120000
      [2025-01-03 17:46:18.834] [LOG]   SampleModule received a socket notification: CONFIG - Payload: [object Object]
      [2025-01-03 17:46:18.844] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
      [2025-01-03 17:46:18.862] [INFO]  [MMM-HomeAssistantDisplay] [
        'Conected to Home Assistant for module_13_MMM-HomeAssistantDisplay after 0 retries'
      [2025-01-03 17:46:18.865] [INFO]  [MMM-HomeAssistantDisplay] [
        'Conected to Home Assistant for module_7_MMM-HomeAssistantDisplay after 0 retries'
      [2025-01-03 17:46:18.873] [LOG]   connection started = connect
      [2025-01-03 17:46:18.874] [LOG]   path=/home/sam/MagicMirror.old/modules/MMM-Config/schema3_16467085098090.json
      [2025-01-03 17:46:19.102] [INFO]  Calendar-Fetcher: Broadcasting 25 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
      [2025-01-03 17:46:19.635] [INFO]  Calendar-Fetcher: Broadcasting 156 events from https://calendar.google.com/calendar/ical/6/basic.ics.
      [2025-01-03 17:46:20.749] [LOG]   stdout: completed
      I have MMM-Config debug enabled
        sdetweil @SteakExpert
        @SteakExpert said in Are you tired of editing config.js, or have trouble doing it, see my new module:
        “builder encountered a problem, see MagicMirror messages for info”
        yeh, that message was put there to tell you what to do instead of being dead
        that means the error trap worked…
          SteakExpert @sdetweil
          @sdetweil Just emailed you the log! Thanks, Sam.
            @SteakExpert there is more after that that I need…
              @SteakExpert we are looking for content in the MagicMirror runtime messages (from npm start ) that might look like this (forced an error just to get the content)
               [LOG]   stdout: --------------------MMM-Config
              module MMM-Carousel has an error in the construction of its defaults section
              the error line is     transitionTimeout: somevalue,
              please change it to the literal value of the referenced defaults variable
              and restart MagicMirror
              the browser message is the last part setup of the error handler
                DarkV
                I am a noob at this, how do I set the port to use the browser and how do I show the QR code on my MM?
                  sdetweil @DarkV
                  @DarkV the default port is 8080
                  you can edit in config.js and change the number, or change it in the form
                  and in the MMM-Config config set showQR to true
                  the doc mentions how to open the form directly in a browser
                  note on the QR you MUST change config.js to support outside MagicMirror system access, per the doc
                    DarkV @sdetweil
                    @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                    config set showQR
                    So, should I add “showQR = True” to the configj.s?
                    As I said earlier, I do not have the skill of the format.
                      DarkV @DarkV
                      @DarkV
                        sdetweil @DarkV
                        @DarkV the doc (README.md) says the url
                          DarkV @sdetweil
                          @sdetweil Apologies for my lack of knowledge, but I didn’t fully understand your response about the URL. Please keep in mind that I’m not very experienced with coding.
                            sdetweil @DarkV
                            @DarkV it takes a little bit of info
                            a url contains
                            a protocol type secure(https) or not (http)
                            a server name or address
                            a port
                            a path
                            and optionally some parameters
                            for MMM-Config
                            just protocol, server, port and path
                            on your local network, we dont need to build our everything for secure encrypted communications
                            if the machine you are opening the browser on is the same machine as MagicMirror is running, then you can use localhost
                            otherwise you need to know the MagicMirror server ip address or network name
                            the port value comes from the MagicMirror config.js, default is 8080
                            (if you dont see a port specified in a url, then the browser uses the default for the protocol, 80 or 443 not/secure, as appropriate)
                            and then the path, for MMM-Config there are two :
                            for configuration
                            /configure
                            and for module installation
                            /installer
                            http://ip:port/configure
                            on the same machine, using defaults
                            http://localhost:8080/configure
                            • I Offline
                              IamWayne
                              Hello, Newbie here, how do you go about using this? What do I need to get started? Do I need Node.js? Have it installed, yet completely lost. How about a guide or video. Thanks
                                sdetweil @IamWayne
                                @IamWayne did you add the module to config.js?
                                and restart MagicMirror?
                                if so then the url from the doc
                                http://ip:mm_port/configure
                                but by default the MagicMirror config only allows apps from inside the same system to connect, so you would have to minimize MagicMirror then launch a browser to
                                or for the module installer
                                http://localhost:8080/installer
                                • I Offline
                                  IamWayne
                                  Oh I think that I understand now. I have to add this to the MM installer in the correct folder, correct?
                                    sdetweil @IamWayne
                                    @IamWayne this is an add on module, not part of the base
                                    see the 1st link in my signature below for short topic about installing modules
                                    • citizendevpiC Offline
                                      citizendevpi
                                      this module works very well , thanks for the hard work and time . makes this project simple and fun !!
                                        DarkV @sdetweil
                                        @sdetweil Still no joy, I am going to reinstall.I cannot display the QR code as I do not have any zones left and cannot load the web page1.png Screenshot 2025-04-03 155111.png
                                          sdetweil @DarkV
                                          @DarkV you dont need the qr code
                                          can you show the messages from npm start?
                                          if using pm2 then
                                          pm2 logs --lines=100
                                            DarkV @sdetweil
                                            @sdetweil How do I get logs? I am a noob regarding MM
                                            I found this
                                            [08.01.2025 00:49.42.199] [ERROR] Failed to retrieve repo info for MMM-Tools: Error: Command failed: cd /home/junior/MagicMirror/modules/MMM-Tools && git fetch -n --dry-run
                                            fatal: unable to access ‘https://github.com/bugsounet/MMM-Tools/’: Could not resolve host: github.com
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
