    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      SteakExpert @sdetweil
      @sdetweil The only feedback it produces is:
      [WARN] You're using a full whitelist configuration allow for all IPs
        sdetweil @SteakExpert
        @SteakExpert are you using pm2?
        if so, pm2 logs --lines=xxx
        xxx is the most recent lines
        there should be a lot more output
          @SteakExpert this is my startup
          (base) sam@sams:~/MagicMirror.old$ npm start
          > magicmirror@2.31.0-develop start
          > npm run start:x11
          > magicmirror@2.31.0-develop start:x11
          [2025-01-03 17:46:17.197] [LOG]   Starting MagicMirror: v2.31.0-develop
          [2025-01-03 17:46:17.209] [LOG]   Loading config ...
          [2025-01-03 17:46:17.209] [LOG]   config template file not exists, no envsubst
          [2025-01-03 17:46:17.348] [INFO]  Checking config file /home/sam/MagicMirror.old/config/config.js ...
          [2025-01-03 17:46:17.382] [INFO]  Your configuration file doesn't contain syntax errors :)
          [2025-01-03 17:46:17.382] [INFO]  Checking modules structure configuration ...
          [2025-01-03 17:46:17.409] [INFO]  Your modules structure configuration doesn't contain errors :)
          [2025-01-03 17:46:17.409] [LOG]   Loading module helpers ...
          [2025-01-03 17:46:17.462] [LOG]   Initializing new module helper ...
          [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-Wallpaper
          [2025-01-03 17:46:17.463] [LOG]   No helper found for module: clock.
          [2025-01-03 17:46:17.463] [LOG]   Initializing new module helper ...
          [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-EmbedURL
          [2025-01-03 17:46:17.527] [LOG]   Initializing new module helper ...
          [2025-01-03 17:46:17.527] [LOG]   Module helper loaded: MMM-Config
          [2025-01-03 17:46:17.534] [LOG]   Initializing new module helper ...
          [2025-01-03 17:46:17.534] [LOG]   Module helper loaded: MMM-HomeAssistantDisplay
          [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-CalendarExt3.
          [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-page-indicator.
          [2025-01-03 17:46:17.535] [LOG]   init module helper SampleModule
          [2025-01-03 17:46:17.535] [LOG]   Module helper loaded: SampleModule
          [2025-01-03 17:46:17.535] [LOG]   No helper found for module: MMM-pages.
          [2025-01-03 17:46:17.572] [LOG]   Initializing new module helper ...
          [2025-01-03 17:46:17.572] [LOG]   Module helper loaded: calendar
          [2025-01-03 17:46:17.572] [LOG]   All module helpers loaded.
          [2025-01-03 17:46:17.574] [LOG]   Starting server on port 8090 ...
          [2025-01-03 17:46:17.575] [WARN]  You're using a full whitelist configuration to allow for all IPs
          [2025-01-03 17:46:17.867] [LOG]   Server started ...
          [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Wallpaper
          [2025-01-03 17:46:17.867] [LOG]   Starting node helper for: MMM-Wallpaper
          [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-EmbedURL
          [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Config
          [2025-01-03 17:46:17.868] [INFO]  MMM-Config restart parm ='none'
          [2025-01-03 17:46:17.868] [LOG]   command =/home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
          [2025-01-03 17:46:17.868] [LOG]   Starting module helper:MMM-Config
          [2025-01-03 17:46:17.868] [LOG]   execing /home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
          [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: MMM-HomeAssistantDisplay
          [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: SampleModule
          [2025-01-03 17:46:17.875] [LOG]   Starting module helper:SampleModule
          [2025-01-03 17:46:17.876] [LOG]   Connecting socket for: calendar
          [2025-01-03 17:46:17.876] [LOG]   Starting node helper for: calendar
          [2025-01-03 17:46:17.876] [LOG]   Sockets connected & modules started ...
          [2025-01-03 17:46:17.876] [LOG]    got port=8300
          [2025-01-03 17:46:18.047] [LOG]   Launching application.
          [2025-01-03 17:46:18.224] [INFO]  System information:
          ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
          ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-125-generic
          ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
          ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
          [3484285:0103/174618.683913:ERROR:nss_util.cc(345)] After loading Root Certs, loaded==false: NSS error code: -8018
          [2025-01-03 17:46:18.707] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840963687&to=1666862563687&panelId=6 with error: ERR_NAME_NOT_RESOLVED
          (Use `electron --trace-warnings ...` to show where the warning was created)
          [2025-01-03 17:46:18.708] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840776401&to=1666862376402&panelId=2 with error: ERR_NAME_NOT_RESOLVED
          [2025-01-03 17:46:18.711] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
          [2025-01-03 17:46:18.799] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_13_MMM-HomeAssistantDisplay' ]
          [2025-01-03 17:46:18.830] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_7_MMM-HomeAssistantDisplay' ]
          [2025-01-03 17:46:18.833] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 120000
          [2025-01-03 17:46:18.834] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-b01395933cda72021e36fae98c07a186/basic.ics - Interval: 120000
          [2025-01-03 17:46:18.834] [LOG]   SampleModule received a socket notification: CONFIG - Payload: [object Object]
          [2025-01-03 17:46:18.844] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
          [2025-01-03 17:46:18.862] [INFO]  [MMM-HomeAssistantDisplay] [
            'Conected to Home Assistant for module_13_MMM-HomeAssistantDisplay after 0 retries'
          [2025-01-03 17:46:18.865] [INFO]  [MMM-HomeAssistantDisplay] [
            'Conected to Home Assistant for module_7_MMM-HomeAssistantDisplay after 0 retries'
          [2025-01-03 17:46:18.873] [LOG]   connection started = connect
          [2025-01-03 17:46:18.874] [LOG]   path=/home/sam/MagicMirror.old/modules/MMM-Config/schema3_16467085098090.json
          [2025-01-03 17:46:19.102] [INFO]  Calendar-Fetcher: Broadcasting 25 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
          [2025-01-03 17:46:19.635] [INFO]  Calendar-Fetcher: Broadcasting 156 events from https://calendar.google.com/calendar/ical/6/basic.ics.
          [2025-01-03 17:46:20.749] [LOG]   stdout: completed
          I have MMM-Config debug enabled
            @SteakExpert said in Are you tired of editing config.js, or have trouble doing it, see my new module:
            “builder encountered a problem, see MagicMirror messages for info”
            yeh, that message was put there to tell you what to do instead of being dead
            that means the error trap worked…
              @sdetweil Just emailed you the log! Thanks, Sam.
                @SteakExpert there is more after that that I need…
                  @SteakExpert we are looking for content in the MagicMirror runtime messages (from npm start ) that might look like this (forced an error just to get the content)
                   [LOG]   stdout: --------------------MMM-Config
                  module MMM-Carousel has an error in the construction of its defaults section
                  the error line is     transitionTimeout: somevalue,
                  please change it to the literal value of the referenced defaults variable
                  and restart MagicMirror
                  the browser message is the last part setup of the error handler
                    DarkV
                    I am a noob at this, how do I set the port to use the browser and how do I show the QR code on my MM?
                      sdetweil @DarkV
                      @DarkV the default port is 8080
                      you can edit in config.js and change the number, or change it in the form
                      and in the MMM-Config config set showQR to true
                      the doc mentions how to open the form directly in a browser
                      note on the QR you MUST change config.js to support outside MagicMirror system access, per the doc
                      D 1 Reply Last reply
                        DarkV @sdetweil
                        @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                        config set showQR
                        So, should I add “showQR = True” to the configj.s?
                        As I said earlier, I do not have the skill of the format.
                          DarkV @DarkV
                          @DarkV
                            sdetweil @DarkV
                            @DarkV the doc (README.md) says the url
                              DarkV @sdetweil
                              @sdetweil Apologies for my lack of knowledge, but I didn’t fully understand your response about the URL. Please keep in mind that I’m not very experienced with coding.
                                sdetweil @DarkV
                                @DarkV it takes a little bit of info
                                a url contains
                                a protocol type secure(https) or not (http)
                                a server name or address
                                a port
                                a path
                                and optionally some parameters
                                for MMM-Config
                                just protocol, server, port and path
                                on your local network, we dont need to build our everything for secure encrypted communications
                                if the machine you are opening the browser on is the same machine as MagicMirror is running, then you can use localhost
                                otherwise you need to know the MagicMirror server ip address or network name
                                the port value comes from the MagicMirror config.js, default is 8080
                                (if you dont see a port specified in a url, then the browser uses the default for the protocol, 80 or 443 not/secure, as appropriate)
                                and then the path, for MMM-Config there are two :
                                for configuration
                                /configure
                                and for module installation
                                /installer
                                http://ip:port/configure
                                on the same machine, using defaults
                                http://localhost:8080/configure
                                • I
                                  IamWayne
                                  Hello, Newbie here, how do you go about using this? What do I need to get started? Do I need Node.js? Have it installed, yet completely lost. How about a guide or video. Thanks
                                    sdetweil @IamWayne
                                    @IamWayne did you add the module to config.js?
                                    and restart MagicMirror?
                                    if so then the url from the doc
                                    http://ip:mm_port/configure
                                    but by default the MagicMirror config only allows apps from inside the same system to connect, so you would have to minimize MagicMirror then launch a browser to
                                    or for the module installer
                                    http://localhost:8080/installer
                                    • I
                                      IamWayne
                                      Oh I think that I understand now. I have to add this to the MM installer in the correct folder, correct?
                                        sdetweil @IamWayne
                                        @IamWayne this is an add on module, not part of the base
                                        see the 1st link in my signature below for short topic about installing modules
                                        • citizendevpiC
                                          citizendevpi
                                          this module works very well , thanks for the hard work and time . makes this project simple and fun !!
                                            DarkV @sdetweil
                                            @sdetweil Still no joy, I am going to reinstall.I cannot display the QR code as I do not have any zones left and cannot load the web page1.png Screenshot 2025-04-03 155111.png
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
