    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.3k Views 31 Watching
      sdetweil @MarcLandis
      @MarcLandis change this
      unused_module.module
      to this
      unused_module
        MarcLandis Module Developer @sdetweil
        @sdetweil I got the command running. There is also an issue when the default calendar module is not used. I fixed it by changing the following in buildschema4.js line 1050
        // if the default calendar module is not used, tt will be empty and getValueObject will fail
            if (tt !== undefined && tt.length > 0) {
              module_properties = getValueObject(m, tt);
        Maybe you have a better fix ready :)
          @MarcLandis thanks git pull on the new branch again …
          I didn’t see this particular error with the latest
            @sdetweil the command now works. Now I need to figure out why the socket.io connection isn’t working.
            Failed to load resource: net::ERR_CONNECTION_REFUSED
              MarcLandis Module Developer @MarcLandis
              @MarcLandis said in Are you tired of editing config.js, or have trouble doing it, see my new module:
              Wrong URL :)
              All is working now. Thanks for the help.
                @MarcLandis what url were you trying? that didn’t work?
                  @sdetweil /modules/MMM-Config/config.html without the port parameter that gets added when using /modules/MMM-Config/review
                    @MarcLandis got it… thx
                      SteakExpert
                      Any chance this is still being worked on? Read through this entire thread in hopes I’d be able to solve my problem without bugging (see what I did there?) you, but alas, I did not.
                      Simply returning the “builder encountered a problem, see MagicMirror messages for info” when I navigate via the QR code.
                      Would appreciate any help you might be able to supply.
                      Thank you!
                        sdetweil @SteakExpert
                        @SteakExpert yes , so you need to look in the output of npm start
                          SteakExpert @sdetweil
                          @sdetweil The only feedback it produces is:
                          [WARN] You're using a full whitelist configuration allow for all IPs
                            @SteakExpert are you using pm2?
                            if so, pm2 logs --lines=xxx
                            xxx is the most recent lines
                            there should be a lot more output
                              @SteakExpert this is my startup
                              (base) sam@sams:~/MagicMirror.old$ npm start
                              > magicmirror@2.31.0-develop start
                              > npm run start:x11
                              > magicmirror@2.31.0-develop start:x11
                              [2025-01-03 17:46:17.197] [LOG]   Starting MagicMirror: v2.31.0-develop
                              [2025-01-03 17:46:17.209] [LOG]   Loading config ...
                              [2025-01-03 17:46:17.209] [LOG]   config template file not exists, no envsubst
                              [2025-01-03 17:46:17.348] [INFO]  Checking config file /home/sam/MagicMirror.old/config/config.js ...
                              [2025-01-03 17:46:17.382] [INFO]  Your configuration file doesn't contain syntax errors :)
                              [2025-01-03 17:46:17.382] [INFO]  Checking modules structure configuration ...
                              [2025-01-03 17:46:17.409] [INFO]  Your modules structure configuration doesn't contain errors :)
                              [2025-01-03 17:46:17.409] [LOG]   Loading module helpers ...
                              [2025-01-03 17:46:17.462] [LOG]   Initializing new module helper ...
                              [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-Wallpaper
                              [2025-01-03 17:46:17.463] [LOG]   No helper found for module: clock.
                              [2025-01-03 17:46:17.463] [LOG]   Initializing new module helper ...
                              [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-EmbedURL
                              [2025-01-03 17:46:17.527] [LOG]   Initializing new module helper ...
                              [2025-01-03 17:46:17.527] [LOG]   Module helper loaded: MMM-Config
                              [2025-01-03 17:46:17.534] [LOG]   Initializing new module helper ...
                              [2025-01-03 17:46:17.534] [LOG]   Module helper loaded: MMM-HomeAssistantDisplay
                              [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-CalendarExt3.
                              [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-page-indicator.
                              [2025-01-03 17:46:17.535] [LOG]   init module helper SampleModule
                              [2025-01-03 17:46:17.535] [LOG]   Module helper loaded: SampleModule
                              [2025-01-03 17:46:17.535] [LOG]   No helper found for module: MMM-pages.
                              [2025-01-03 17:46:17.572] [LOG]   Initializing new module helper ...
                              [2025-01-03 17:46:17.572] [LOG]   Module helper loaded: calendar
                              [2025-01-03 17:46:17.572] [LOG]   All module helpers loaded.
                              [2025-01-03 17:46:17.574] [LOG]   Starting server on port 8090 ...
                              [2025-01-03 17:46:17.575] [WARN]  You're using a full whitelist configuration to allow for all IPs
                              [2025-01-03 17:46:17.867] [LOG]   Server started ...
                              [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Wallpaper
                              [2025-01-03 17:46:17.867] [LOG]   Starting node helper for: MMM-Wallpaper
                              [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-EmbedURL
                              [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Config
                              [2025-01-03 17:46:17.868] [INFO]  MMM-Config restart parm ='none'
                              [2025-01-03 17:46:17.868] [LOG]   command =/home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
                              [2025-01-03 17:46:17.868] [LOG]   Starting module helper:MMM-Config
                              [2025-01-03 17:46:17.868] [LOG]   execing /home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
                              [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: MMM-HomeAssistantDisplay
                              [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: SampleModule
                              [2025-01-03 17:46:17.875] [LOG]   Starting module helper:SampleModule
                              [2025-01-03 17:46:17.876] [LOG]   Connecting socket for: calendar
                              [2025-01-03 17:46:17.876] [LOG]   Starting node helper for: calendar
                              [2025-01-03 17:46:17.876] [LOG]   Sockets connected & modules started ...
                              [2025-01-03 17:46:17.876] [LOG]    got port=8300
                              [2025-01-03 17:46:18.047] [LOG]   Launching application.
                              [2025-01-03 17:46:18.224] [INFO]  System information:
                              ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
                              ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-125-generic
                              ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                              ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                              [3484285:0103/174618.683913:ERROR:nss_util.cc(345)] After loading Root Certs, loaded==false: NSS error code: -8018
                              [2025-01-03 17:46:18.707] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840963687&to=1666862563687&panelId=6 with error: ERR_NAME_NOT_RESOLVED
                              (Use `electron --trace-warnings ...` to show where the warning was created)
                              [2025-01-03 17:46:18.708] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840776401&to=1666862376402&panelId=2 with error: ERR_NAME_NOT_RESOLVED
                              [2025-01-03 17:46:18.711] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
                              [2025-01-03 17:46:18.799] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_13_MMM-HomeAssistantDisplay' ]
                              [2025-01-03 17:46:18.830] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_7_MMM-HomeAssistantDisplay' ]
                              [2025-01-03 17:46:18.833] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 120000
                              [2025-01-03 17:46:18.834] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-b01395933cda72021e36fae98c07a186/basic.ics - Interval: 120000
                              [2025-01-03 17:46:18.834] [LOG]   SampleModule received a socket notification: CONFIG - Payload: [object Object]
                              [2025-01-03 17:46:18.844] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
                              [2025-01-03 17:46:18.862] [INFO]  [MMM-HomeAssistantDisplay] [
                                'Conected to Home Assistant for module_13_MMM-HomeAssistantDisplay after 0 retries'
                              [2025-01-03 17:46:18.865] [INFO]  [MMM-HomeAssistantDisplay] [
                                'Conected to Home Assistant for module_7_MMM-HomeAssistantDisplay after 0 retries'
                              [2025-01-03 17:46:18.873] [LOG]   connection started = connect
                              [2025-01-03 17:46:18.874] [LOG]   path=/home/sam/MagicMirror.old/modules/MMM-Config/schema3_16467085098090.json
                              [2025-01-03 17:46:19.102] [INFO]  Calendar-Fetcher: Broadcasting 25 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                              [2025-01-03 17:46:19.635] [INFO]  Calendar-Fetcher: Broadcasting 156 events from https://calendar.google.com/calendar/ical/6/basic.ics.
                              [2025-01-03 17:46:20.749] [LOG]   stdout: completed
                              I have MMM-Config debug enabled
                                @SteakExpert said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                yeh, that message was put there to tell you what to do instead of being dead
                                that means the error trap worked…
                                  @sdetweil Just emailed you the log! Thanks, Sam.
                                    @SteakExpert there is more after that that I need…
                                      @SteakExpert we are looking for content in the MagicMirror runtime messages (from npm start ) that might look like this (forced an error just to get the content)
                                       [LOG]   stdout: --------------------MMM-Config
                                      module MMM-Carousel has an error in the construction of its defaults section
                                      the error line is     transitionTimeout: somevalue,
                                      please change it to the literal value of the referenced defaults variable
                                      and restart MagicMirror
                                      the browser message is the last part setup of the error handler
                                        DarkV
                                        I am a noob at this, how do I set the port to use the browser and how do I show the QR code on my MM?
                                          sdetweil @DarkV
                                          @DarkV the default port is 8080
                                          you can edit in config.js and change the number, or change it in the form
                                          and in the MMM-Config config set showQR to true
                                          the doc mentions how to open the form directly in a browser
                                          note on the QR you MUST change config.js to support outside MagicMirror system access, per the doc
                                            DarkV @sdetweil
                                            @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                            config set showQR
                                            So, should I add “showQR = True” to the configj.s?
                                            As I said earlier, I do not have the skill of the format.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
