    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      DarkV @sdetweil
      @sdetweil How do I get logs? I am a noob regarding MM
      I found this
      [08.01.2025 00:49.42.199] [ERROR] Failed to retrieve repo info for MMM-Tools: Error: Command failed: cd /home/junior/MagicMirror/modules/MMM-Tools && git fetch -n --dry-run
      fatal: unable to access ‘https://github.com/bugsounet/MMM-Tools/’: Could not resolve host: github.com
        DarkV @sdetweil
          sdetweil @DarkV
          @DarkV way back further in the log, back 50 lines maybe
          as using pm2 the good and error lines are separated into two lists
          none of the bugsounet repos are online any more
          so if you dont want to see those errors, you can exclude them from the updatenotification module scans
          D 1 Reply Last reply
            DarkV @sdetweil
            @sdetweil SyntaxError: Unexpected identifier 'config’
             at internalCompileFunction (node:internal/vm:73:18)
             at wrapSafe (node:internal/modules/cjs/loader:1185:20)
             at Module._compile (node:internal/modules/cjs/loader:1227:27)
             at Object…js (node:internal/modules/cjs/loader:1326:10)
             at Module.load (node:internal/modules/cjs/loader:1126:32)
             at node:internal/modules/cjs/loader:967:12
             at Function._load (node:electron/js2c/node_init:2:13357)
             at Module.require (node:internal/modules/cjs/loader:1150:19)
             at require (node:internal/modules/cjs/helpers:121:18)
             at loadConfig (/home/junior/MagicMirror/js/app.js:118:14)
             at App.start (/home/junior/MagicMirror/js/app.js:248:18)
             at Object. (/home/junior/MagicMirror/js/electron.js:192:7)
             at Module._compile (node:internal/modules/cjs/loader:1271:14)
            /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
            [27.03.2025 09:44.46.126] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
            Warning: vkCreateInstance: Found no drivers!
            Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
            at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
            at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
            at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
            at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
            at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
            [27.03.2025 09:46.55.825] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:122
            [27.03.2025 09:47.26.134] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
            [27.03.2025 09:53.43.417] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
            [27.03.2025 09:59.04.576] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
            [27.03.2025 10:02.53.766] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
            [27.03.2025 10:15.08.770] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
            SyntaxError: Unexpected token '{'
            [27.03.2025 10:15.58.981] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
            /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
            [27.03.2025 10:22.57.762] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
            [27.03.2025 10:29.29.494] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
            [27.03.2025 10:30.26.627] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
              sdetweil @DarkV
              @DarkV mmm-config requires MagicMirror version 2.28 or higher
              also, you have some syntax error around line 122 in config.js
              pm2 flush to empty the logs
              and see what hsppens after you fix that config.js error
                DarkV @sdetweil
                @sdetweil, I’m sorry. Can you please highlight where I have the error? I am considering reinstalling it as I cannot even update Magic Mirror. I want to back up Config.js, but if it contains faults, then I will be back to square one.
                * MagicMirror² Config Sample
                 * By Michael Teeuw https://michaelteeuw.nl
                 * MIT Licensed.
                 * see https://docs.magicmirror.builders/configuration/introduction.html
                 * and https://docs.magicmirror.builders/modules/configuration.html
                let config = {
                	address: "localhost", 	// Address to listen on, can be:
                	port: 8080,
                	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                	ipWhitelist: [], 	// Set [] to allow all IP addresses
                															// or add a specific IPv4 of 192.168.2.49 :
                	language: "en",
                	locale: "en-US",
                	timeFormat: 24,
                	units: "metric",
                	module: 'MMM-MovieListings',
                                                position: 'bottom_center',   // This can be any of the regions. Best results in left or$
                					apiKey: '',
                					region: 'GB',
                					language: 'en-UK',
                					interface: 'poster', //'list', 'poster', 'detailed'
                					includeMoviePlot: false,
                					maxPlotLength: 198,
                					header: 'Kinofilme',
                					moviesPerPage: 0,
                					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                					animationSpeed: 2.5 * 1000,
                					pageChangeInterval: 35 * 1000
                        module: 'MMM-Globe',
                	position: 'bottom_left',
                		style: 'geoColor',
                		imageSize: 300,
                		ownImagePath:'',
                		updateInterval: 10*60*1000
                  module: 'MMM-Tools',
                  position: 'bottom_right',
                    refresh: 1000 * 5,
                    containerSize: null,
                    itemSize: null
                    module: "MMM-EyeCandy",
                    position: "top_center",
                        maxWidth: "75%",       // Sizes the images. Retains aspect ratio.
                        style: '1',            // Style number or use ownImagePath to override style
                        ownImagePath: '',      // 'modules/MMM-EyeCandy/pix/name-graphics-lisa-596441.jpg'
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_right"
                			header: "UK Holidays",
                						symbol: "calendar-check-o ",
                                        url: "https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
                			module: "compliments",
                			position: "top_bar"
                			module: "MMM-OpenmapWeather",
                		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                		header: "Current Weather", //Location is the default value if header is empty or not defined.
                			locationID: "2651817", //Location ID from http://openweathermap.org/help/city_list.txt
                			appid: "",  //openweathermap.org API key
                      			colorIcon: true
                		module:"MMM-Config",
                		position:"top_left",
                			// the QR code (if requested) will appear here
                		config:{
                                        showQR: true
                			module: "weather",
                			header: "Weather Forecast",
                				type: "forecast",
                				locationID: "2651817", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				apiKey: ""
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "BBC UK News",
                						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                  sdetweil @DarkV
                  @DarkV i do not SEE anything, but i am away from my computer all day, driving.
                  so i cannot run it thru the
                  npm run config:check
                  command
                    DarkV @sdetweil
                    @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                    [04.04.2025 16:09.03.683] [INFO] Checking file… /home/junior/MagicMirror/config/config.js
                    [04.04.2025 16:09.03.781] [INFO] Your configuration file doesn’t contain syntax errors :)
                    junior@MAGIC-MIRROR:~/MagicMirror $
                      sdetweil @DarkV
                      @DarkV ok
                      now do
                      cd ~/MagicMirror/MMM-Config
                      ./test-convert.sh override
                      you should get one message
                      completed
                        DarkV @sdetweil
                        Results
                        junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test-convert.sh override
                        -bash: ./test-convert.sh: No such file or directory
                        I used a fresh SD card for the reinstallation, but some of her modules are incompatible with the new setup. Consequently, my wife has firmly decided to stick with the current version until her modules stop functioning. Unfortunately, since one of the modules doesn’t work with the old MagicMirror version, I’m at an impasse. It is a pity, I wanted this as due to dyslexia, this would have been perfect for my situation
                          sdetweil @DarkV
                          @DarkV ok,my fault
                          cd ~/MagicMirror/modules/MMM-Config
                          ./test_convert.sh  override
                            DarkV @sdetweil
                            junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test_convert.sh overri de
                            --------------------MMM-Config
                            module updatenotification-defaults has an error in the construction of its defau lts section
                            the error line is disabled: true;
                            please change it to the literal value of the referenced variable
                            and restart MagicMirror
                              sdetweil @DarkV
                              @DarkV can you show the top of the modules/defaul/updatenotification/updatenotification.js
                              make sure the defaults section is shown
                              you know you never edit any of the MagicMirror source or module source
                              all config goes in config/config.js and all css goes in css/custom.css
                                DarkV @sdetweil
                                My bad,iI was trying to dissable the “Update available” banner at the top of mirror
                                /* MagicMirror²
                                • Module: UpdateNotification
                                • By Michael Teeuw https://michaelteeuw.nl
                                • MIT Licensed.
                                  Module.register(“updatenotification”, {
                                  defaults: {
                                  updateInterval: 10 * 60 * 1000, // every 10 minutes
                                  refreshInterval: 24 * 60 * 60 * 1000, // one day
                                  ignoreModules: [],
                                  sendUpdatesNotifications: false,
                                  updates: [],
                                  updateTimeout: 2 * 60 * 1000, // max update duration
                                  updateAutorestart: false // autoRestart MM when update done ?
                                  disabled: true;
                                  suspended: false,
                                  moduleList: {},
                                  needRestart: false,
                                  updates: {},
                                  start () {
                                  Log.info(Starting module: ${this.name});
                                  this.addFilters();
                                  setInterval(() => {
                                  this.moduleList = {};
                                  this.updateDom(2);
                                  }, this.config.refreshInterval);
                                  suspend () {
                                  this.suspended = true;
                                  resume () {
                                  this.suspended = false;
                                  this.updateDom(2);
                                  notificationReceived (notification) {
                                  switch (notification) {
                                  case “DOM_OBJECTS_CREATED”:
                                  this.sendSocketNotification(“CONFIG”, this.config);
                                  this.sendSocketNotification(“MODULES”, Object.keys(Module.definitions));
                                  break;
                                  case “SCAN_UPDATES”:
                                  this.sendSocketNotification(“SCAN_UPDATES”);
                                  break;
                                  socketNotificationReceived (notification, payload) {
                                  case “REPO_STATUS”:
                                  this.updateUI(payload);
                                  break;
                                  case “UPDATES”:
                                  this.sendNotification(“UPDATES”, payload);
                                  break;
                                  case “UPDATE_STATUS”:
                                  this.updatesNotifier(payload);
                                  break;
                                  getStyles () {
                                  return [${this.name}.css];
                                  getTemplate () {
                                  return ${this.name}.njk;
                                  getTemplateData () {
                                  return { moduleList: this.moduleList, updatesList: this.updates, suspended: this.suspended, needRestart: this.needRestart };
                                  updateUI (payload) {
                                  if (payload && payload.behind > 0) {
                                  // if we haven’t seen info for this module
                                  if (this.moduleList[payload.module] === undefined) {
                                  // save it
                                  this.moduleList[payload.module] = payload;
                                  this.updateDom(2);
                                  } else if (payload && payload.behind === 0) {
                                  // if the module WAS in the list, but shouldn’t be
                                  if (this.moduleList[payload.module] !== undefined) {
                                  // remove it
                                  delete this.moduleList[payload.module];
                                  this.updateDom(2);
                                  addFilters () {
                                  this.nunjucksEnvironment().addFilter(“diffLink”, (text, status) => {
                                  if (status.module !== “MagicMirror”) {
                                  return text;
                                   	const localRef = status.hash;
                                   	const remoteRef = status.tracking.replace(/.*\//, "");
                                   	return `<a href="https://github.com/MichMich/MagicMirror/compare/${localRef}...${remoteRef}" class="xsmall dimmed difflink" target="_blank">${text}</a>`;
                                  updatesNotifier (payload, done = true) {
                                  if (this.updates[payload.name] === undefined) {
                                  this.updates[payload.name] = {
                                  sdetweil @DarkV
                                  @DarkV yes i understand
                                  lets restore the updatenotification module file
                                  git checkout modules/default/updatenotification/updatenotification.js
                                  then lets edit config.js to disable the module
                                        module:"updatenotification",
                                        position:"top_bar",
                                        disabled:true
                                    DarkV @sdetweil
                                    fatal: not a git repository (or any of the parent directories): .git
                                      sdetweil @DarkV
                                      @DarkV hmmm
                                      how did you install MagicMirror
                                      manual, scripted or zip file download ?
                                      • JohanbaJ
                                        Johanba
                                        Also not getting it to work
                                        in the browser i go to installer
                                        and this is all that loads
                                          sdetweil @Johanba
                                          @Johanba i posted in your other topic
                                            DarkV @sdetweil
                                            @sdetweil Script
                                            You helped me on a while backScreenshot 2025-04-10 at 11-54-21 Failed Update MagicMirror Forum.png
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
