    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
    • citizendevpiC
      citizendevpi
      this module works very well , thanks for the hard work and time . makes this project simple and fun !!
        DarkV @sdetweil
        @sdetweil Still no joy, I am going to reinstall.I cannot display the QR code as I do not have any zones left and cannot load the web page1.png Screenshot 2025-04-03 155111.png
          sdetweil @DarkV
          @DarkV you dont need the qr code
          can you show the messages from npm start?
          if using pm2 then
          pm2 logs --lines=100
          D 2 Replies Last reply
            DarkV @sdetweil
            @sdetweil How do I get logs? I am a noob regarding MM
            I found this
            [08.01.2025 00:49.42.199] [ERROR] Failed to retrieve repo info for MMM-Tools: Error: Command failed: cd /home/junior/MagicMirror/modules/MMM-Tools && git fetch -n --dry-run
            fatal: unable to access ‘https://github.com/bugsounet/MMM-Tools/’: Could not resolve host: github.com
              DarkV @sdetweil
                sdetweil @DarkV
                @DarkV way back further in the log, back 50 lines maybe
                as using pm2 the good and error lines are separated into two lists
                none of the bugsounet repos are online any more
                so if you dont want to see those errors, you can exclude them from the updatenotification module scans
                D 1 Reply Last reply
                  DarkV @sdetweil
                  @sdetweil SyntaxError: Unexpected identifier 'config’
                   at internalCompileFunction (node:internal/vm:73:18)
                   at wrapSafe (node:internal/modules/cjs/loader:1185:20)
                   at Module._compile (node:internal/modules/cjs/loader:1227:27)
                   at Object…js (node:internal/modules/cjs/loader:1326:10)
                   at Module.load (node:internal/modules/cjs/loader:1126:32)
                   at node:internal/modules/cjs/loader:967:12
                   at Function._load (node:electron/js2c/node_init:2:13357)
                   at Module.require (node:internal/modules/cjs/loader:1150:19)
                   at require (node:internal/modules/cjs/helpers:121:18)
                   at loadConfig (/home/junior/MagicMirror/js/app.js:118:14)
                   at App.start (/home/junior/MagicMirror/js/app.js:248:18)
                   at Object. (/home/junior/MagicMirror/js/electron.js:192:7)
                   at Module._compile (node:internal/modules/cjs/loader:1271:14)
                  /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  [27.03.2025 09:44.46.126] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                  Warning: vkCreateInstance: Found no drivers!
                  Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                  at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                  at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                  at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                  at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                  at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                  [27.03.2025 09:46.55.825] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:122
                  [27.03.2025 09:47.26.134] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                  [27.03.2025 09:53.43.417] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                  [27.03.2025 09:59.04.576] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                  [27.03.2025 10:02.53.766] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                  [27.03.2025 10:15.08.770] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                  SyntaxError: Unexpected token '{'
                  [27.03.2025 10:15.58.981] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                  /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                  [27.03.2025 10:22.57.762] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                  [27.03.2025 10:29.29.494] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                  [27.03.2025 10:30.26.627] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                    sdetweil @DarkV
                    @DarkV mmm-config requires MagicMirror version 2.28 or higher
                    also, you have some syntax error around line 122 in config.js
                    pm2 flush to empty the logs
                    and see what hsppens after you fix that config.js error
                      DarkV @sdetweil
                      @sdetweil, I’m sorry. Can you please highlight where I have the error? I am considering reinstalling it as I cannot even update Magic Mirror. I want to back up Config.js, but if it contains faults, then I will be back to square one.
                      * MagicMirror² Config Sample
                       * By Michael Teeuw https://michaelteeuw.nl
                       * MIT Licensed.
                       * see https://docs.magicmirror.builders/configuration/introduction.html
                       * and https://docs.magicmirror.builders/modules/configuration.html
                      let config = {
                      	address: "localhost", 	// Address to listen on, can be:
                      	port: 8080,
                      	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                      	ipWhitelist: [], 	// Set [] to allow all IP addresses
                      															// or add a specific IPv4 of 192.168.2.49 :
                      	language: "en",
                      	locale: "en-US",
                      	timeFormat: 24,
                      	units: "metric",
                      	module: 'MMM-MovieListings',
                                                      position: 'bottom_center',   // This can be any of the regions. Best results in left or$
                      					apiKey: '',
                      					region: 'GB',
                      					language: 'en-UK',
                      					interface: 'poster', //'list', 'poster', 'detailed'
                      					includeMoviePlot: false,
                      					maxPlotLength: 198,
                      					header: 'Kinofilme',
                      					moviesPerPage: 0,
                      					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                      					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                      					animationSpeed: 2.5 * 1000,
                      					pageChangeInterval: 35 * 1000
                              module: 'MMM-Globe',
                      	position: 'bottom_left',
                      		style: 'geoColor',
                      		imageSize: 300,
                      		ownImagePath:'',
                      		updateInterval: 10*60*1000
                        module: 'MMM-Tools',
                        position: 'bottom_right',
                          refresh: 1000 * 5,
                          containerSize: null,
                          itemSize: null
                          module: "MMM-EyeCandy",
                          position: "top_center",
                              maxWidth: "75%",       // Sizes the images. Retains aspect ratio.
                              style: '1',            // Style number or use ownImagePath to override style
                              ownImagePath: '',      // 'modules/MMM-EyeCandy/pix/name-graphics-lisa-596441.jpg'
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_right"
                      			header: "UK Holidays",
                      						symbol: "calendar-check-o ",
                                              url: "https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
                      			module: "compliments",
                      			position: "top_bar"
                      			module: "MMM-OpenmapWeather",
                      		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                      		header: "Current Weather", //Location is the default value if header is empty or not defined.
                      			locationID: "2651817", //Location ID from http://openweathermap.org/help/city_list.txt
                      			appid: "",  //openweathermap.org API key
                            			colorIcon: true
                      		module:"MMM-Config",
                      		position:"top_left",
                      			// the QR code (if requested) will appear here
                      		config:{
                                              showQR: true
                      			module: "weather",
                      			header: "Weather Forecast",
                      				type: "forecast",
                      				locationID: "2651817", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      				apiKey: ""
                      			module: "newsfeed",
                      			position: "bottom_bar",
                      				feeds: [
                      						title: "BBC UK News",
                      						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
                      				showSourceTitle: true,
                      				showPublishDate: true,
                      				broadcastNewsFeeds: true,
                      				broadcastNewsUpdates: true
                        sdetweil @DarkV
                        @DarkV i do not SEE anything, but i am away from my computer all day, driving.
                        so i cannot run it thru the
                        npm run config:check
                        command
                          DarkV @sdetweil
                          @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                          [04.04.2025 16:09.03.683] [INFO] Checking file… /home/junior/MagicMirror/config/config.js
                          [04.04.2025 16:09.03.781] [INFO] Your configuration file doesn’t contain syntax errors :)
                          junior@MAGIC-MIRROR:~/MagicMirror $
                            sdetweil @DarkV
                            @DarkV ok
                            now do
                            cd ~/MagicMirror/MMM-Config
                            ./test-convert.sh override
                            you should get one message
                            completed
                              DarkV @sdetweil
                              Results
                              junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test-convert.sh override
                              -bash: ./test-convert.sh: No such file or directory
                              I used a fresh SD card for the reinstallation, but some of her modules are incompatible with the new setup. Consequently, my wife has firmly decided to stick with the current version until her modules stop functioning. Unfortunately, since one of the modules doesn’t work with the old MagicMirror version, I’m at an impasse. It is a pity, I wanted this as due to dyslexia, this would have been perfect for my situation
                                sdetweil @DarkV
                                @DarkV ok,my fault
                                cd ~/MagicMirror/modules/MMM-Config
                                ./test_convert.sh  override
                                  DarkV @sdetweil
                                  junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test_convert.sh overri de
                                  --------------------MMM-Config
                                  module updatenotification-defaults has an error in the construction of its defau lts section
                                  the error line is disabled: true;
                                  please change it to the literal value of the referenced variable
                                  and restart MagicMirror
                                    sdetweil @DarkV
                                    @DarkV can you show the top of the modules/defaul/updatenotification/updatenotification.js
                                    make sure the defaults section is shown
                                    you know you never edit any of the MagicMirror source or module source
                                    all config goes in config/config.js and all css goes in css/custom.css
                                      DarkV @sdetweil
                                      My bad,iI was trying to dissable the “Update available” banner at the top of mirror
                                      /* MagicMirror²
                                      • Module: UpdateNotification
                                      • By Michael Teeuw https://michaelteeuw.nl
                                      • MIT Licensed.
                                        Module.register(“updatenotification”, {
                                        defaults: {
                                        updateInterval: 10 * 60 * 1000, // every 10 minutes
                                        refreshInterval: 24 * 60 * 60 * 1000, // one day
                                        ignoreModules: [],
                                        sendUpdatesNotifications: false,
                                        updates: [],
                                        updateTimeout: 2 * 60 * 1000, // max update duration
                                        updateAutorestart: false // autoRestart MM when update done ?
                                        disabled: true;
                                        suspended: false,
                                        moduleList: {},
                                        needRestart: false,
                                        updates: {},
                                        start () {
                                        Log.info(Starting module: ${this.name});
                                        this.addFilters();
                                        setInterval(() => {
                                        this.moduleList = {};
                                        this.updateDom(2);
                                        }, this.config.refreshInterval);
                                        suspend () {
                                        this.suspended = true;
                                        resume () {
                                        this.suspended = false;
                                        this.updateDom(2);
                                        notificationReceived (notification) {
                                        switch (notification) {
                                        case “DOM_OBJECTS_CREATED”:
                                        this.sendSocketNotification(“CONFIG”, this.config);
                                        this.sendSocketNotification(“MODULES”, Object.keys(Module.definitions));
                                        break;
                                        case “SCAN_UPDATES”:
                                        this.sendSocketNotification(“SCAN_UPDATES”);
                                        break;
                                        socketNotificationReceived (notification, payload) {
                                        case “REPO_STATUS”:
                                        this.updateUI(payload);
                                        break;
                                        case “UPDATES”:
                                        this.sendNotification(“UPDATES”, payload);
                                        break;
                                        case “UPDATE_STATUS”:
                                        this.updatesNotifier(payload);
                                        break;
                                        getStyles () {
                                        return [${this.name}.css];
                                        getTemplate () {
                                        return ${this.name}.njk;
                                        getTemplateData () {
                                        return { moduleList: this.moduleList, updatesList: this.updates, suspended: this.suspended, needRestart: this.needRestart };
                                        updateUI (payload) {
                                        if (payload && payload.behind > 0) {
                                        // if we haven’t seen info for this module
                                        if (this.moduleList[payload.module] === undefined) {
                                        // save it
                                        this.moduleList[payload.module] = payload;
                                        this.updateDom(2);
                                        } else if (payload && payload.behind === 0) {
                                        // if the module WAS in the list, but shouldn’t be
                                        if (this.moduleList[payload.module] !== undefined) {
                                        // remove it
                                        delete this.moduleList[payload.module];
                                        this.updateDom(2);
                                        addFilters () {
                                        this.nunjucksEnvironment().addFilter(“diffLink”, (text, status) => {
                                        if (status.module !== “MagicMirror”) {
                                        return text;
                                         	const localRef = status.hash;
                                         	const remoteRef = status.tracking.replace(/.*\//, "");
                                         	return `<a href="https://github.com/MichMich/MagicMirror/compare/${localRef}...${remoteRef}" class="xsmall dimmed difflink" target="_blank">${text}</a>`;
                                        updatesNotifier (payload, done = true) {
                                        if (this.updates[payload.name] === undefined) {
                                        this.updates[payload.name] = {
                                        sdetweil @DarkV
                                        @DarkV yes i understand
                                        lets restore the updatenotification module file
                                        git checkout modules/default/updatenotification/updatenotification.js
                                        then lets edit config.js to disable the module
                                              module:"updatenotification",
                                              position:"top_bar",
                                              disabled:true
                                          DarkV @sdetweil
                                          fatal: not a git repository (or any of the parent directories): .git
                                            sdetweil @DarkV
                                            @DarkV hmmm
                                            how did you install MagicMirror
                                            manual, scripted or zip file download ?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
