    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.7k Views 31 Watching
      DarkV @sdetweil
      @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
      git checkout modules/default/updatenotification/updatenotification.js
      fatal: not a git repository (or any of the parent directories): .git
      junior@MAGIC-MIRROR:~/MagicMirror $
        sdetweil @DarkV
        @DarkV hmmm
        how did you install MagicMirror
        manual, scripted or zip file download ?
        • JohanbaJ
          Johanba
          Also not getting it to work
          in the browser i go to installer
          and this is all that loads
            sdetweil @Johanba
            @Johanba i posted in your other topic
              DarkV @sdetweil
              @sdetweil Script
              You helped me on a while backScreenshot 2025-04-10 at 11-54-21 Failed Update MagicMirror Forum.png
                sdetweil @DarkV
                @DarkV i understand, but that wasn’t the question
                the git checkout command should have worked,
                but failed.
                now i am trying to figure out why. and what to do about it
                the command prompt looks different after
                then the last time you did a command
                so try this way
                go to your MagicMirror folder
                and do git status
                show the results
                  DarkV @sdetweil
                  git status
                  junior@MAGIC-MIRROR:~ $ cd ~/MagicMirror/modules/MMM-Config
                  junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ git status
                  On branch main
                  Your branch is up to date with ‘origin/main’.
                  nothing to commit, working tree clean
                  junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ cd ~/MagicMirror
                  junior@MAGIC-MIRROR:~/MagicMirror $ git status
                    sdetweil @DarkV
                    @DarkV asking again, how did you install MagicMirror?
                      DarkV @sdetweil
                      @sdetweil I think it must have been a script on the net. It was quite a long time ago, between 2022 and 2023. I honestly cannot remember. I found an old config.js from ‎06 ‎October ‎2023
                        sdetweil @DarkV
                        @DarkV ok, my script is the only one I know about and it uses git
                        lets do this to get a new copy and use your config/modules…
                        copy paste this section to a terminal window
                        cd ~
                        # save MM folder
                        mv MagicMirror MagicMirror.org
                        # install new MM (reply N to screen saver/pm2
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                        once MM is installed again lets make THIS new version look like the old
                        copy/paste this
                        # copy files
                        cd ~
                        cp MagicMirror.org/config/config.js MagicMirror/config
                        cp MagicMirror.org/css/custom.css MagicMirror/css
                        cd MagicMirror/modules
                        # save the new default module folder
                        mv default ..
                        cd ..
                        # copy all the org modules
                        cp -r -p ~/MagicMirror.org/modules .
                        cd modules
                        # remove the old default  modules folder
                        rm -rf default
                        # move back the new default
                        mv ../default .
                        now
                        npm start should work
                        • 11
                        • 12
                        • 13
                        • 14
                        • 15
                        • 15 / 15
