    V2.31.0 unable to start
    29 Posts 3 Posters 6.6k Views 3 Watching
    • htilburgsH Offline
      htilburgs
      After upgrade to v2.31.0 MM will not start.
      PM2 doesn’t show errors, but with NPM START I become this error:
      [2025-04-10 19:35:00.301] [LOG]   Sockets connected & modules started ...
      Invalid MIT-MAGIC-COOKIE-1 key
      [873086:0410/193500.307514:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
      [873086:0410/193500.308038:ERROR:env.cc(258)] The platform failed to initialize.  Exiting.
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      I did a new install of MM, same error.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        sdetweil @htilburgs
        @htilburgs how did you upgrade or install
        htilburgsH 1 Reply Last reply Reply Quote 0
          htilburgs @sdetweil
          @sdetweil with the script from you
            sdetweil @htilburgs
            @htilburgs hm
            try
            npm run start:wayland
              htilburgs @sdetweil
              @sdetweil Same error:
              [875833:0410/200935.088653:ERROR:wayland_connection.cc(198)] Failed to connect to Wayland display: No such file or directory (2)
              [875833:0410/200935.088864:ERROR:ozone_platform_wayland.cc(264)] Failed to initialize Wayland platform
              [875833:0410/200935.088893:ERROR:env.cc(258)] The platform failed to initialize.  Exiting.
                sdetweil @htilburgs
                @htilburgs weird,
                show
                lsb_release -a
                  htilburgs @sdetweil
                  No LSB modules are available.
                  Distributor ID: Debian
                  Description:    Debian GNU/Linux 12 (bookworm)
                  Release:        12
                  Codename:       bookworm
                    sdetweil @htilburgs
                    @htilburgs ok, when did you build the sd card?
                    can you show
                    ps -ef | grep way
                    ps -ef | grep labwc
                      htilburgs @sdetweil
                      @sdetweil said in V2.31.0 unable to start:
                      ps -ef | grep way
                      ps -ef | grep labwc
                      pi@mm:~/MagicMirror $ ps -ef | grep way
                      vnc          739       1  0 Apr09 ?        00:00:00 /bin/sh /usr/sbin/wayvnc-run.sh
                      vnc          759     739  0 Apr09 ?        00:00:00 wayvnc --render-cursor --detached --gpu --config /etc/wayvnc/config --socket /tmp/wayvnc/wayvncctl.sock
                      root        1605       1  0 Apr09 ?        00:02:02 python /usr/sbin/wayvnc-control.py
                      lightdm   801759  801726  0 19:20 ?        00:00:02 /usr/bin/rpi-connectd -socket /run/user/106/rpi-connect-wayvnc.sock
                      lightdm   801764  801648  0 19:20 ?        00:00:00 /usr/bin/wayfire -c /usr/share/greeter.ini
                      pi        810604     974  0 19:24 ?        00:00:02 /usr/bin/rpi-connectd -socket /run/user/1000/rpi-connect-wayvnc.sock
                      lightdm   870748       1  0 19:32 ?        00:00:00 /usr/bin/Xwayland -auth /home/lightdm/.Xauthority :0 -rootless -core -terminate 10 -listenfd 30 -listenfd 31 -displayfd 59 -wm 56
                      pi        878864  735951  0 21:00 pts/0    00:00:00 grep --color=auto way
                      pi@mm:~/MagicMirror $ ps -ef | grep labwc
                      pi        878897  735951  0 21:00 pts/0    00:00:00 grep --color=auto labwc
                        sdetweil @htilburgs
                        @htilburgs hm. so start:wayland should have worked
