    V2.31.0 unable to start
    29 Posts 3 Posters 8.2k Views 3 Watching
      sdetweil @htilburgs
      @htilburgs hm
      try
      npm run start:wayland
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH Offline
        htilburgs @sdetweil
        @sdetweil Same error:
        [875833:0410/200935.088653:ERROR:wayland_connection.cc(198)] Failed to connect to Wayland display: No such file or directory (2)
        [875833:0410/200935.088864:ERROR:ozone_platform_wayland.cc(264)] Failed to initialize Wayland platform
        [875833:0410/200935.088893:ERROR:env.cc(258)] The platform failed to initialize.  Exiting.
        /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          sdetweil @htilburgs
          @htilburgs weird,
          show
          lsb_release -a
            htilburgs @sdetweil
            No LSB modules are available.
            Distributor ID: Debian
            Description:    Debian GNU/Linux 12 (bookworm)
            Release:        12
            Codename:       bookworm
              sdetweil @htilburgs
              @htilburgs ok, when did you build the sd card?
              can you show
              ps -ef | grep way
              ps -ef | grep labwc
                htilburgs @sdetweil
                @sdetweil said in V2.31.0 unable to start:
                ps -ef | grep way
                ps -ef | grep labwc
                pi@mm:~/MagicMirror $ ps -ef | grep way
                vnc          739       1  0 Apr09 ?        00:00:00 /bin/sh /usr/sbin/wayvnc-run.sh
                vnc          759     739  0 Apr09 ?        00:00:00 wayvnc --render-cursor --detached --gpu --config /etc/wayvnc/config --socket /tmp/wayvnc/wayvncctl.sock
                root        1605       1  0 Apr09 ?        00:02:02 python /usr/sbin/wayvnc-control.py
                lightdm   801759  801726  0 19:20 ?        00:00:02 /usr/bin/rpi-connectd -socket /run/user/106/rpi-connect-wayvnc.sock
                lightdm   801764  801648  0 19:20 ?        00:00:00 /usr/bin/wayfire -c /usr/share/greeter.ini
                pi        810604     974  0 19:24 ?        00:00:02 /usr/bin/rpi-connectd -socket /run/user/1000/rpi-connect-wayvnc.sock
                lightdm   870748       1  0 19:32 ?        00:00:00 /usr/bin/Xwayland -auth /home/lightdm/.Xauthority :0 -rootless -core -terminate 10 -listenfd 30 -listenfd 31 -displayfd 59 -wm 56
                pi        878864  735951  0 21:00 pts/0    00:00:00 grep --color=auto way
                pi@mm:~/MagicMirror $ ps -ef | grep labwc
                pi        878897  735951  0 21:00 pts/0    00:00:00 grep --color=auto labwc
                  sdetweil @htilburgs
                  @htilburgs hm. so start:wayland should have worked
                    htilburgs @sdetweil
                    I did the update, it didn’t work afterwards.
                    Then I’ve tried sudo apt-get update / upgrade, still no luck
                    Today I renamed MagicMirror to .org and did a new install of MagicMirror, same result.
                    So now I’m out of options…
                      sdetweil @htilburgs
                      @htilburgs hmm
                      ok. try this
                      rm -rf ~/.config/Electron
                      note the . (dot) in front of of config
                      restart MagicMirror
                        htilburgs @sdetweil
                        Same error😔
                        npm run start
                          htilburgs @htilburgs
                          I think I take a new SD Card and do an install from scratch to see what happens.
                          htilburgsH 1 Reply Last reply Reply Quote 1
                            @htilburgs
                            I took a new SD Card and installed everything from fresh.
                            Some information:
                            cat /sys/firmware/devicetree/base/model
                            Raspberry Pi 4 Model B Rev 1.4
                            cat /etc/debian_version
                            12.10
                            cat /etc/os-release
                            PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
                            NAME="Debian GNU/Linux"
                            VERSION_ID="12"
                            VERSION="12 (bookworm)"
                            VERSION_CODENAME=bookworm
                            ID=debian
                            HOME_URL="https://www.debian.org/"
                            SUPPORT_URL="https://www.debian.org/support"
                            BUG_REPORT_URL="https://bugs.debian.org/"
                            uname -a
                            Linux MagicMirror 6.12.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.20-1+rpt1~bpo12+1 (2025-03-19) aarch64 GNU/Linux
                            node -v
                            v22.14.0
                            npm -v
                            10.9.2
                            When I start MagicMirror with “npm run start”, then everything seems to work.
                            pm2 start MagicMirror works and seems to start MagicMirror in Wayland
                            npm run start:wayland still gives an error
                            pi@MagicMirror:~/MagicMirror $ npm run start:wayland
                            > magicmirror@2.31.0 start:wayland
                            > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland
                            [2025-04-15 21:25:47.140] [LOG]   Starting MagicMirror: v2.31.0
                            [2025-04-15 21:25:47.175] [LOG]   Loading config ...
                            [2025-04-15 21:25:47.179] [LOG]   config template file not exists, no envsubst
                            [2025-04-15 21:25:47.752] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                            [2025-04-15 21:25:47.874] [INFO]  Your configuration file doesn't contain syntax errors :)
                            [2025-04-15 21:25:47.876] [INFO]  Checking modules structure configuration ...
                            [2025-04-15 21:25:47.988] [INFO]  Your modules structure configuration doesn't contain errors :)
                            [2025-04-15 21:25:47.991] [LOG]   Loading module helpers ...
                            [2025-04-15 21:25:47.992] [LOG]   No helper found for module: alert.
                            [2025-04-15 21:25:48.002] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.004] [LOG]   Module helper loaded: updatenotification
                            [2025-04-15 21:25:48.004] [LOG]   No helper found for module: clock.
                            [2025-04-15 21:25:48.005] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                            [2025-04-15 21:25:48.005] [LOG]   No helper found for module: weather.
                            [2025-04-15 21:25:48.061] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.061] [LOG]   Module helper loaded: MMM-Formula1
                            [2025-04-15 21:25:48.099] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.100] [LOG]   Module helper loaded: MMM-MyGarbage
                            [2025-04-15 21:25:48.225] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.225] [LOG]   Module helper loaded: calendar
                            [2025-04-15 21:25:48.270] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.271] [LOG]   Module helper loaded: MMM-OnSpotify
                            [2025-04-15 21:25:48.298] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.298] [LOG]   Module helper loaded: MMM-Bring
                            [2025-04-15 21:25:48.487] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.487] [LOG]   Module helper loaded: MMM-Tado
                            [2025-04-15 21:25:48.489] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.489] [LOG]   Module helper loaded: MMM-MyHomeWizard
                            [2025-04-15 21:25:48.491] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.492] [LOG]   Module helper loaded: MMM-SystemMonitor
                            [2025-04-15 21:25:48.523] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.523] [LOG]   Module helper loaded: MMM-network-signal
                            [2025-04-15 21:25:48.525] [LOG]   Initializing new module helper ...
                            [2025-04-15 21:25:48.526] [LOG]   Module helper loaded: MMM-Universal-Pir
                            [2025-04-15 21:25:48.526] [LOG]   All module helpers loaded.
                            [2025-04-15 21:25:48.536] [LOG]   Starting server on port 8080 ...
                            [2025-04-15 21:25:49.396] [LOG]   Server started ...
                            [2025-04-15 21:25:49.401] [LOG]   Connecting socket for: updatenotification
                            [2025-04-15 21:25:49.407] [LOG]   Starting module helper: updatenotification
                            [2025-04-15 21:25:49.409] [LOG]   Connecting socket for: MMM-Formula1
                            [2025-04-15 21:25:49.414] [LOG]   Starting module: MMM-Formula1
                            [2025-04-15 21:25:49.418] [LOG]   Connecting socket for: MMM-MyGarbage
                            [2025-04-15 21:25:49.419] [LOG]   Starting node_helper for module: MMM-MyGarbage
                            [2025-04-15 21:25:49.420] [LOG]   Connecting socket for: calendar
                            [2025-04-15 21:25:49.422] [LOG]   Starting node helper for: calendar
                            [2025-04-15 21:25:49.424] [LOG]   Connecting socket for: MMM-OnSpotify
                            [2025-04-15 21:25:49.427] [LOG]   [MMM-OnSpotify] by Fabrizz >> Node helper loaded.
                            [2025-04-15 21:25:49.428] [LOG]   Connecting socket for: MMM-Bring
                            [2025-04-15 21:25:49.430] [LOG]   Connecting socket for: MMM-Tado
                            [2025-04-15 21:25:49.438] [LOG]       - MMM-Tado: Refresh token loaded.
                            [2025-04-15 21:25:49.440] [LOG]   Connecting socket for: MMM-MyHomeWizard
                            [2025-04-15 21:25:49.443] [LOG]   Starting node_helper for: MMM-MyHomeWizard
                            [2025-04-15 21:25:49.444] [LOG]   Connecting socket for: MMM-SystemMonitor
                            [2025-04-15 21:25:49.446] [LOG]   Starting module helper: MMM-SystemMonitor
                            [2025-04-15 21:25:49.450] [LOG]   Connecting socket for: MMM-network-signal
                            [2025-04-15 21:25:49.452] [LOG]   MMM-network-signal helper started ...
                            [2025-04-15 21:25:49.454] [LOG]   Connecting socket for: MMM-Universal-Pir
                            [2025-04-15 21:25:49.457] [LOG]   Sockets connected & modules started ...
                            [2025-04-15 21:25:50.513] [LOG]   Launching application.
                            [2025-04-15 21:25:51.278] [INFO]  System information:
                            ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.4; virtual: false
                            ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
                            ### VERSIONS: electron: 35.1.5; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
                            ### OTHER:    timeZone: Europe/Amsterdam; ELECTRON_ENABLE_GPU: undefined
                            /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
                            I was just wondering, couldn’t it have something to do with the WAYLAND_DISPLAY parameter?
                              sdetweil @htilburgs
                              @htilburgs could be
                              when you open a terminal session and do
                              env
                              is the WAYLAND_DISPLAY variable set?
                              that code you referenced says use WAYLAND_DISPLAY, and if not set, set it to wayland-1
                                htilburgs @sdetweil
                                @sdetweil It seems it’s not set
                                pi@MagicMirror:~ $ env
                                SHELL=/bin/bash
                                NO_AT_BRIDGE=1
                                PWD=/home/pi
                                LOGNAME=pi
                                XDG_SESSION_TYPE=tty
                                MOTD_SHOWN=pam
                                HOME=/home/pi
                                LANG=en_GB.UTF-8
                                LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.swp=00;90:*.tmp=00;90:*.dpkg-dist=00;90:*.dpkg-old=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:
                                SSH_CONNECTION=192.168.0.200 57994 192.168.0.47 22
                                XDG_SESSION_CLASS=user
                                TERM=xterm-256color
                                USER=pi
                                SHLVL=1
                                XDG_SESSION_ID=4
                                XDG_RUNTIME_DIR=/run/user/1000
                                SSH_CLIENT=192.168.0.200 57994 22
                                PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
                                SSH_TTY=/dev/pts/0
                                OLDPWD=/home/pi/.config
                                TEXTDOMAIN=Linux-PAM
                                _=/usr/bin/env
                                pi@MagicMirror:~ $
                                How do I set this?
                                  sdetweil @htilburgs
                                  @htilburgs in terminal window no spaces between things…
                                  this is like the windows set var=value (without the set prefix)
                                  WAYLAND_DISPLAY=wayland-x
                                  x is a number from 0 to …
                                  we thought wayand-1 was default
                                    htilburgs @sdetweil
                                    In terminal window I typed WAYLAND_DISPLAY=wayland-1
                                    Then I did “env”, nothing changed.
                                    npm run start:wayland still gives the same error.
                                      sdetweil @htilburgs
                                      @htilburgs said in V2.31.0 unable to start:
                                      you should have seen this in the env output
                                      but our code says IF NOT SET, use wayland-1
                                      which looks like an error
                                      so if you set it to the same value it won’t improve
                                      I’d try wayland-0
                                      maybe the wlr_randr command will tell you what it is?
                                        htilburgs @sdetweil
                                        @sdetweil Maybe I don’t understand.
                                        WAYLAND_DISPLAY=wayland-0 still gives wayland-1 in npm run start:wayland.
                                        wlr_randr gives
                                        pi@MagicMirror:~/MagicMirror $ wlr_randr
                                        -bash: wlr_randr: command not found
                                        By the way, my PIR command do work
                                        onCommand: "WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1 --on --transform 270 --mode='1920x1080'",
                                        offCommand: "WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1 --off",
                                        htilburgsH R 2 Replies Last reply Reply Quote 0
                                          When I give command
                                          pi@MagicMirror:~ $ WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1
                                          HDMI-A-1 "Samsung Electric Company SyncMaster 0x00000001 (HDMI-A-1)"
                                            Physical size: 700x390 mm
                                            Enabled: yes
                                            Modes:
                                              720x400 px, 70.082001 Hz
                                              640x480 px, 59.939999 Hz
                                              640x480 px, 60.000000 Hz
                                              640x480 px, 66.667000 Hz
                                              640x480 px, 72.808998 Hz
                                              640x480 px, 75.000000 Hz
                                              720x480 px, 59.939999 Hz
                                              720x480 px, 60.000000 Hz
                                              720x576 px, 50.000000 Hz
                                              800x600 px, 60.317001 Hz
                                              800x600 px, 72.188004 Hz
                                              800x600 px, 75.000000 Hz
                                              832x624 px, 74.551003 Hz
                                              1024x768 px, 60.004002 Hz
                                              1024x768 px, 70.069000 Hz
                                              1024x768 px, 75.028999 Hz
                                              1280x720 px, 50.000000 Hz
                                              1280x720 px, 59.939999 Hz
                                              1280x720 px, 60.000000 Hz
                                              1152x864 px, 75.000000 Hz
                                              1280x800 px, 59.910000 Hz
                                              1440x900 px, 59.901001 Hz
                                              1280x1024 px, 60.020000 Hz
                                              1280x1024 px, 75.025002 Hz
                                              1600x900 px, 60.000000 Hz
                                              1680x1050 px, 59.882999 Hz
                                              1920x1080 px, 23.976000 Hz
                                              1920x1080 px, 24.000000 Hz
                                              1920x1080 px, 25.000000 Hz
                                              1920x1080 px, 29.969999 Hz
                                              1920x1080 px, 30.000000 Hz
                                              1920x1080 px, 50.000000 Hz
                                              1920x1080 px, 59.939999 Hz
                                              1920x1080 px, 60.000000 Hz
                                              1920x1080 px, 60.000000 Hz (preferred, current)
                                            Position: 0,0
                                            Transform: 270
                                            Scale: 1.000000
                                            sdetweil @htilburgs
                                            @htilburgs so wayland-1 seems to be correct
