    cron job hdmi on and off
    29 Posts 4 Posters 10.2k Views 4 Watching
      Sam 0
      ok i checked some more and did some tests
      when I execute the following I get the error message that I also see in the log
      /usr/bin/wlr-randr --output H DMI-A-1 --off
      failed to connect to display
      also running the sh files via putty gives the error
      it seems that the command:
      the error message gives the question is this command incorrect or is there an underlying problem?
      mumblebajM S 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @Sam 0
        @Sam-0 Can you run the following from the command line and she your results:
        wlr-randr
        ls -als /run/user/1000/wayland*
        Share your results. Either the wayland-1 is different as indicated by @evroom or HDMI-A-1 is actually a different version on your system.
        Share the results from the above and we take it from there. Also, @evroom has indicated the there is supposed to be a space before /home on the crontab.
          Sam 0 @Sam 0
          @Sam-0 this is the result
          checked the cron see below
          • evroomE Offline
            evroom @Sam 0
            @Sam-0
            So as stated before you most probably need to change wayland-1 to wayland-0 in your scripts.
            Give it a try.
            Furthermore the .lock file may cause a problem, but I guess this will show in your error log.
            And temporarily change the times in your cronjob to speed things up a bit.
            Waiting till ten and midnight is not really necessary :-)
            MagicMirror version: 2.37.0
            mumblebajM S 2 Replies Last reply Reply Quote 1
              mumblebaj Module Developer @evroom
              @evroom *.lock should not cause an issue. I have same on my system and no issues with it. I agree with the wayland-1 change to wayland-0.
                Sam 0 @evroom
                @evroom
                should it be modified in this way?
                output HDMI-A-1 --on
                Into
                output HDMI-A-0 --on
                • evroomE Offline
                  evroom @Sam 0
                  @Sam-0 said in cron job hdmi on and off:
                  @evroom
                  Into
                  No, like this:
                  export WAYLAND_DISPLAY=wayland-0
                  In both scripts.
                    Sam 0 @evroom
                    @evroom said in cron job hdmi on and off:
                    this way?
                      sdetweil @Sam 0
                      @Sam-0 no… the exports have to be before the wlr_randr
                        Sam 0 @sdetweil
                        thank you i made the adjustment
                        • evroomE Offline
                          evroom @Sam 0
                          @Sam-0
                          You only had to change the 1 into a 0.
                          Not to move the lines around, especially not the ones with export.
                          #!/bin/bash
                          export XDG_RUNTIME_DIR=/run/user/1000
                          wir-randr --output HDMI-A-1 --on
                          But you are slowly getting there :-)
                          Wax on, wax off
                          Screen on, screen off.
                            Sam 0 @evroom
                            ok i will adjust it and see if it works
                              Sam 0 @evroom
                              @Sam-0
                              #!/bin/bash
                              Wax on, wax off
                              Man who catch fly with chopstick, accomplish anything😆
                                Sam 0
                                ok is this good now? :) let me know the result tomorrow…
                                  sdetweil @Sam 0
                                  @Sam-0 think so yes
                                    Sam 0 @Sam 0
                                    @Sam-0
                                    yes it works very well thank you for your patience with me I hope others can now set it up more easily
                                    thanks again for the effort
