    cron job hdmi on and off
    29 Posts 4 Posters 10.7k Views 4 Watching
    • evroomE
      evroom @Sam 0
      @Sam-0 said in cron job hdmi on and off:
      i created two files
      off.sh and on.sh
      they contain the following lines
      wlr-randr --output HDMI-A-1 --off
      wlr-randr --output HDMI-A-1 --on
      Do you have #!/bin/bash or #!/bin/sh at the very beginning of your shell scripts ?
      #! /bin/sh – Execute the file using the Bourne shell, or a compatible shell, assumed to be in the /bin directory
      #! /bin/bash – Execute the file using the Bash shell
      You can also put /bin/bash in the crontab entry (before /home/username/...).
      Then there is no way for cron to not execute it as a shell script and it will even run without the executable bit set.
      And what Sam mentioned: the scripts need to be executable but not necessarily writable (chmod 755).
      This should normally do the trick.
      If you have mail installed (which mail) you can put this at the very beginning of the crontab file:
      MAILTO=username (in my case admin).
      With
      journalctl --since "1 day ago" --unit cron.service --no-pager
      you can see if cron ran your script and with mail you can see more details on the cron job executed.
      Good luck.
      Reply Quote -1
        Sam 0 @sdetweil
        @evroom Thanks for your explanation, I have made adjustments and will check tonight if it works. I will report this back. Thanks for the effort.
          Sam 0
          unfortunately it still doesn’t work what am I doing
          wrong?!
          cron info
          on sh file
          off sh file
          error logfile:
          evroomE 3 Replies Last reply
          • evroomE
            evroom @Sam 0
            @Sam-0
            So it seems that the cronjob is okay.
            Can you do:
            ˋˋˋls -als /run/user/1000/wayland*ˋˋˋ
            I think you need wayland-0 iso wayland-1.
            With ˋˋˋ grep username /etc/passwdˋˋˋ (use your username) you can verify that your user has uid 1000.
            • evroomE
              evroom @Sam 0
              @Sam-0
              In de laatste 2 regels mist een spatie bij /home.
              • evroomE
                evroom @Sam 0
                  Sam 0
                  ok i checked some more and did some tests
                  when I execute the following I get the error message that I also see in the log
                  /usr/bin/wlr-randr --output H DMI-A-1 --off
                  failed to connect to display
                  also running the sh files via putty gives the error
                  it seems that the command:
                  the error message gives the question is this command incorrect or is there an underlying problem?
                  mumblebajM S 2 Replies Last reply
                  • mumblebajM
                    mumblebaj Module Developer @Sam 0
                    @Sam-0 Can you run the following from the command line and she your results:
                    wlr-randr
                    Share your results. Either the wayland-1 is different as indicated by @evroom or HDMI-A-1 is actually a different version on your system.
                    Share the results from the above and we take it from there. Also, @evroom has indicated the there is supposed to be a space before /home on the crontab.
                      Sam 0 @Sam 0
                      @Sam-0 this is the result
                      checked the cron see below
                      evroomE 1 Reply Last reply
                      • evroomE
                        evroom @Sam 0
                        @Sam-0
                        So as stated before you most probably need to change wayland-1 to wayland-0 in your scripts.
                        Give it a try.
                        Furthermore the .lock file may cause a problem, but I guess this will show in your error log.
                        And temporarily change the times in your cronjob to speed things up a bit.
                        Waiting till ten and midnight is not really necessary :-)
                        • mumblebajM
                          mumblebaj Module Developer @evroom
                          @evroom *.lock should not cause an issue. I have same on my system and no issues with it. I agree with the wayland-1 change to wayland-0.
                            Sam 0 @evroom
                            @evroom
                            should it be modified in this way?
                            Into
                            output HDMI-A-0 --on
                            • evroomE
                              evroom @Sam 0
                              @evroom
                              Into
                              No, like this:
                              export WAYLAND_DISPLAY=wayland-0
                              In both scripts.
                                Sam 0 @evroom
                                @evroom said in cron job hdmi on and off:
                                this way?
                                  sdetweil @Sam 0
                                  @Sam-0 no… the exports have to be before the wlr_randr
                                    Sam 0 @sdetweil
                                    thank you i made the adjustment
                                    • evroomE
                                      evroom @Sam 0
                                      @Sam-0
                                      You only had to change the 1 into a 0.
                                      Not to move the lines around, especially not the ones with export.
                                      #!/bin/bash
                                      export XDG_RUNTIME_DIR=/run/user/1000
                                      wir-randr --output HDMI-A-1 --on
                                      But you are slowly getting there :-)
                                      Wax on, wax off
                                      Screen on, screen off.
                                        Sam 0 @evroom
                                        ok i will adjust it and see if it works
                                          Sam 0 @evroom
                                          @Sam-0
                                          #!/bin/bash
                                          Wax on, wax off
                                          Man who catch fly with chopstick, accomplish anything😆
                                            Sam 0
                                            ok is this good now? :) let me know the result tomorrow…
