    cron job hdmi on and off
    29 Posts 4 Posters 10.7k Views 4 Watching
      Sam 0 @Sam 0
      i created two files
      off.sh and on.sh
      they contain the following lines
      wlr-randr --output HDMI-A-1 --off
      wlr-randr --output HDMI-A-1 --on
      i also created a folder
      with the following rights:
      cmod 777
      the cron contains the following lines:
      unfortunately this does not work what is wrong?
      # Schakel display uit zondag - donderdag om 22.00
      00 22 * * 0-4 /home/username/MagicMirror/config/hdmionoff/off.sh>> /home/username/MagicMirror/config/hdmionoff/mof.log 2>&1
      # Schakel display uit vrijdag - zaterdag om 22.45
      45 22 * * 5,6 /home/username/MagicMirror/config/hdmionoff/off.sh>> /home/username/MagicMirror/config/hdmionoff/mof.log 2>&1
      # Zet het scherm aan maandag - vrijdag om 7u00
      00 07 * * 1-5/home/username/MagicMirror/config/hdmionoff/on.sh>> /home/username/MagicMirror/config/hdmionoff/mon.log 2>&1
      # Zet het scherm aan zaterdag - zondag om 8u00
      00 08 * * 6,0/home/username/MagicMirror/config/hdmionoff/on.sh>> /home/username/MagicMirror/config/hdmionoff/mon.log 2>&1
      S S evroomE 3 Replies Last reply
        sdetweil @Sam 0
        @Sam-0 are the sh files marked executable?
        ls -laF in your folder to see
        permissions are 3 groups of 3 settings
        read/write/execute
        for user, group and all others
        9 settings from the right
        one more for directory and 1 for system
        ds, user, group, other
          Sam 0 @Sam 0
          I thought it was right but now the rights on the sh files are set to 0777 and also on the folders
          I also did a test to see if I could execute the sh files, this works tonight the cron should execute it, let me know if it works
            sdetweil @Sam 0
            @Sam-0 yes. although you dont need write permission, (except for user)
            means anyone else could change the script
            • evroomE
              evroom @Sam 0
              @Sam-0 said in cron job hdmi on and off:
              i created two files
              off.sh and on.sh
              Do you have #!/bin/bash or #!/bin/sh at the very beginning of your shell scripts ?
              #! /bin/sh – Execute the file using the Bourne shell, or a compatible shell, assumed to be in the /bin directory
              #! /bin/bash – Execute the file using the Bash shell
              You can also put /bin/bash in the crontab entry (before /home/username/...).
              Then there is no way for cron to not execute it as a shell script and it will even run without the executable bit set.
              And what Sam mentioned: the scripts need to be executable but not necessarily writable (chmod 755).
              This should normally do the trick.
              If you have mail installed (which mail) you can put this at the very beginning of the crontab file:
              MAILTO=username (in my case admin).
              With
              journalctl --since "1 day ago" --unit cron.service --no-pager
              you can see if cron ran your script and with mail you can see more details on the cron job executed.
              Good luck.
              Reply Quote -1
                Sam 0 @sdetweil
                @evroom Thanks for your explanation, I have made adjustments and will check tonight if it works. I will report this back. Thanks for the effort.
                  Sam 0
                  unfortunately it still doesn’t work what am I doing
                  wrong?!
                  cron info
                  on sh file
                  off sh file
                  error logfile:
                  • evroomE
                    evroom @Sam 0
                    @Sam-0
                    So it seems that the cronjob is okay.
                    Can you do:
                    ˋˋˋls -als /run/user/1000/wayland*ˋˋˋ
                    I think you need wayland-0 iso wayland-1.
                    With ˋˋˋ grep username /etc/passwdˋˋˋ (use your username) you can verify that your user has uid 1000.
                    • evroomE
                      evroom @Sam 0
                      @Sam-0
                      In de laatste 2 regels mist een spatie bij /home.
                      • evroomE
                        evroom @Sam 0
                          Sam 0
                          ok i checked some more and did some tests
                          when I execute the following I get the error message that I also see in the log
                          /usr/bin/wlr-randr --output H DMI-A-1 --off
                          failed to connect to display
                          also running the sh files via putty gives the error
                          it seems that the command:
                          the error message gives the question is this command incorrect or is there an underlying problem?
                          mumblebajM S 2 Replies Last reply
                          • mumblebajM
                            mumblebaj Module Developer @Sam 0
                            @Sam-0 Can you run the following from the command line and she your results:
                            wlr-randr
                            Share your results. Either the wayland-1 is different as indicated by @evroom or HDMI-A-1 is actually a different version on your system.
                            Share the results from the above and we take it from there. Also, @evroom has indicated the there is supposed to be a space before /home on the crontab.
                              Sam 0 @Sam 0
                              @Sam-0 this is the result
                              checked the cron see below
                              evroomE 1 Reply Last reply
                              • evroomE
                                evroom @Sam 0
                                @Sam-0
                                So as stated before you most probably need to change wayland-1 to wayland-0 in your scripts.
                                Give it a try.
                                Furthermore the .lock file may cause a problem, but I guess this will show in your error log.
                                And temporarily change the times in your cronjob to speed things up a bit.
                                Waiting till ten and midnight is not really necessary :-)
                                • mumblebajM
                                  mumblebaj Module Developer @evroom
                                  @evroom *.lock should not cause an issue. I have same on my system and no issues with it. I agree with the wayland-1 change to wayland-0.
                                    Sam 0 @evroom
                                    @evroom
                                    should it be modified in this way?
                                    Into
                                    output HDMI-A-0 --on
                                    • evroomE
                                      evroom @Sam 0
                                      @evroom
                                      Into
                                      No, like this:
                                      export WAYLAND_DISPLAY=wayland-0
                                      In both scripts.
                                        Sam 0 @evroom
                                        @evroom said in cron job hdmi on and off:
                                        this way?
                                          sdetweil @Sam 0
                                          @Sam-0 no… the exports have to be before the wlr_randr
                                            Sam 0 @sdetweil
                                            thank you i made the adjustment
