    Logitech Media Server (Squeezebox) - Multiroom Wlan Speaker System
    13 Posts 6 Posters 11.1k Views 7 Watching
      MirrorImage @barnosch
      Noticed this topic is quite old, but I would also like a module for this.
      The software might not be trendy like Sonos, but it has had a thriving community and active development for over 20 years.
      It would be nice with a local network solution that simply shows what is playing on a perticular player.
      Cheers!
        barnosch @MirrorImage
        I finally did it and KI helped me
        for me it works. Maybe someone else still uses it .
        Now the LMS is called Lyrion Music Server… just for the records
        https://github.com/barnosch/MMM-Lyrion
        A L G E 4 Replies Last reply Reply Quote 3
          Athlon @barnosch
          @barnosch
          Thank you for this!
          I’ve added it to my Mirror - works great! I will likely convert the language shown on my screen to English…
            barnosch @Athlon
            @Athlon
            Very cool. I like that ! Then it already was worth it.
            Yeah, feel free to edit the language part.
            Maybe i’ll try to add a language feature.
            • L Offline
              lxne Project Sponsor @barnosch
              @barnosch awesome. I am using LMS and it’s rocking cool.
              With pCP one should be able to use the MM as a Squeezeplayer, too. That would be a pretty nice in combination with your module.
              I am going to try that.
              Best wishes,
              Alex
                barnosch @lxne
                @lxne cool bananas.
                I really like it, that someone else still use it.
                And that it works for you aswell.
                I only use PiCorePlayers, but i have no idea why you would use ur MM as Player aswell.
                Do you have touch?
                • G Offline
                  Glou @barnosch
                  @barnosch heart and stars in my eyes !!!
                  • L Offline
                    @barnosch I don’t have touch, but I can control lms/Squeezelite via my smartphone. I didn’t know that PiCorePlayers was a system, not just some application. So now I am using SqueezeLite on my MM and that works great. My MM is connected to an usb audio system. It now can play music from my lms and MM is displaying the title. Quite cool :)
                    This tutorial helped me getting SqueezeLite running on my MM (latest Bookworm 64bit).
                    Those were my steps for 64bit:
                    Create a squeezelite “work” directory and download squeezelite
                    cd
                    mkdir squeezelite
                    cd squeezelite
                    wget -O squeezelite.tar.gz https://sourceforge.net/projects/lmsclients/files/squeezelite/linux/squeezelite-2.0.0.1524-aarch64.tar.gz/download
                    # for newest version see: https://sourceforge.net/projects/lmsclients/files/squeezelite/linux
                    tar -zxvf squeezelite.tar.gz
                    rm squeezelite.tar.gz
                    mv squeezelite squeezelite-aarch64
                    Move it to the usr directory, and make it executable:
                    sudo mv squeezelite-aarch64 /usr/bin
                    sudo chmod a+x /usr/bin/squeezelite-aarch64
                    With my USB audio device the following commands works (there is more info in the tutorial on how to find the correct device)
                    sudo /usr/bin/squeezelite-aarch64 -n Pi4-MagicMirror -o front:CARD=MicroII,DEV=0
                    I don’t use it as a service yet (the steps in the tutorial didn’t work for me). So right now I have to manually start it after reboot.
                    • E Offline
                      eldrik @barnosch
                      @barnosch thanks for sharing, working fine for me on my “old” mm install with 2.18.0.
                      Kleiner Hinweis im repo ist für die Config Einbindung MMM-MMM-Lyrion statt MMM-Lyrion angegeben.
                      Greetz
                      Eldrik
                        barnosch @eldrik
                        @eldrik
                        Happy you also use it and, that it works for you.
                        Error fixed, thanks for that
                          barnosch
                          I had a little time and have redone the thing.
                          Since i did not want to kill the old module, i created a new git repository
                          (i am not good with this kind of stuff)
                          MMM-Lyrion2
                          https://github.com/barnosch/MMM-Lyrion2
                          no additional npm needed anymore and
                          cover support from MusicBrainz and Deezer.
                          works very good for my webradio streams i currently use.
                          Please feel free to test it.
                          Looks like this with two synced players
