    MMM-Homeassistant-sensors doesn't work anymore, recommended alternative.
    5 Posts 3 Posters 501 Views 3 Watching
    • F Offline
      flac_rules
      I use https://github.com/Snille/MMM-homeassistant-sensors but after the last update of Home assistant it doesn’t work anymore (the program crashes after some seconds with an error about javascript being out of memory. So i was wondering if anyone had any suggested alternatives? There is another module named the same, I don’t know if that causes issues when it gets installed? Will it overwrite files? https://github.com/ledsi/MMM-homeassistant-sensors
        rkorell @flac_rules
        @flac_rules
        If you git-pull the second one - which seems to have the exact same name - the git-clone (<- edited!) will fail.
        But if you rename the „original“ directory with e.g.
        mv MMM-homeassistant-sensors MMM-homeassistant-sensors_original
        you should be able to issue a git clone (<- edited) for the second variant, install this and give it a try.
        If t his doesn‘t work, either - delete the newly created directory and re-rename the original one …
        Regards,
        Ralf
          sdetweil @rkorell
          @rkorell not git pull after rename, git clone to get the first copy
          two different source repos, cant merge them
            rkorell @sdetweil
            @sdetweil said in MMM-Homeassistant-sensors doesn't work anymore, recommended alternative.:
            git clone
            Dear Sam, you are SO right!
            Sorry - typo …
            Have edited above in my first post.
            Thanks for paying attention!
            Regards,
            Ralf
            • F Offline
              flac_rules
              Thanks. Renaming the folders worked fine.
