    Office Display
    12 Posts 2 Posters 3.5k Views 2 Watching
    • K Offline
      Kayos
      This is an early development version of what will be my office display, used as a screensaver when the display isn’t in use
      the actual display is a 4k 65" smart display, it is in storage until the office move
      The 2 modules I wanted did not exist, so I wrote them both
      UK Grid Status https://github.com/KayosPi/MMM-UKGridStatus
      Does not require API’s and shows either realtime or snapshots of the UK grid
      Solax PV https://github.com/KayosPi/MMM-SolaxPV
      Displays information from a Solax PV inverter, customisable to show whatever you want to see. Needs an API and a serial number linked to that API
      Now it works, I will make it look nice
      K 1 Reply Last reply Reply Quote 2
      • K Offline
        Kayos @Kayos
        I gave up with Ext3 calendar and settled on Ext2
        Not completely happy but getting there
          sdetweil @Kayos
          @Kayos why give up?
          • K Offline
            Kayos @sdetweil
            I failed to even get it to load and need a working display for tomorrow morning
            I will return to it when I have time, EXT2 works, for now
              sdetweil @Kayos
              @Kayos ext2 reads the ics directly
              ext3 takes events from the default calendar module
              • K Offline
                Kayos @sdetweil
                And with that tiny, but crucial bit of info, I will get ext3 working
                I deleted default from my config
                  sdetweil @Kayos
                  @Kayos and then when you dont want the default to show,
                  you remove or comment out its position property
                  • K Offline
                    Kayos @sdetweil
                    I have tried again with EXT3, it loads but won’t output on either a connected screen or remote
                    I will need to dig into it, think I followed the setup and config properly
                      sdetweil @Kayos
                      @Kayos does the default calendar module show events?
                      • K Offline
                        Kayos @sdetweil
                        Yes it does, I’ve updated it to show UK holidays and an outlook calendar of mine
                        Both work
