    Office Display
    12 Posts 2 Posters 3.7k Views 2 Watching
      sdetweil @Kayos
      @Kayos why give up?
      • K Offline
        Kayos @sdetweil
        I failed to even get it to load and need a working display for tomorrow morning
        I will return to it when I have time, EXT2 works, for now
          sdetweil @Kayos
          @Kayos ext2 reads the ics directly
          ext3 takes events from the default calendar module
          • K Offline
            Kayos @sdetweil
            And with that tiny, but crucial bit of info, I will get ext3 working
            I deleted default from my config
              sdetweil @Kayos
              @Kayos and then when you dont want the default to show,
              you remove or comment out its position property
              • K Offline
                Kayos @sdetweil
                I have tried again with EXT3, it loads but won’t output on either a connected screen or remote
                I will need to dig into it, think I followed the setup and config properly
                  sdetweil @Kayos
                  @Kayos does the default calendar module show events?
                  • K Offline
                    Kayos @sdetweil
                    Yes it does, I’ve updated it to show UK holidays and an outlook calendar of mine
                    Both work
                      sdetweil @Kayos
                      @Kayos then default ext3 should display a month
                      copy/paste from the readme
                        @sdetweil see my replies in your other topic
