    How to Swipe between pages
    19 Posts 5 Posters 879 Views 5 Watching
    • T Offline
      TheSteveBennett
      I have MagicMirror2 installed on a Raspberry PI 4 with a Pi Touch Display2. I am trying to Swipe between pages using MMM-SmartTouch and MMM-Pages. The config looks right but I can’t figure out what I am doing wrong? Here is a copy of my config.
      let config = {
          address: "0.0.0.0",
          port: 8080,
          basePath: "/",
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.4.0/24"],
          useHttps: false,
          httpsPrivateKey: "",
          httpsCertificate: "",
          language: "en",
          locale: "en-US",
          logLevel: ["INFO", "LOG", "WARN", "ERROR"],
          timeFormat: 12,
          units: "imperial",
                  module: "alert",
                  module: "updatenotification",
                  position: "top_bar"
                  module: "clock",
                  classes: "page-1"
                  header: "US Holidays",
                  classes: "page-1",
                              symbol: "calendar-check",
                              url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                  module: "compliments",
                  position: "lower_third",
                  classes: "page-1"
                  module: "weather",
                  classes: "page-2",
                      weatherProvider: "openmeteo",
                      type: "current",
                      lat: 40.776676,
                      lon: -73.971321
                  module: "weather",
                  header: "Weather Forecast",
                  classes: "page-2",
                      type: "forecast",
                      lat: 40.776676,
                      lon: -73.971321
                  module: "MMM-MyWeather",
                  classes: "page-2",
                      // Your MyWeather configuration
                  module: "newsfeed",
                  position: "bottom_bar",
                  classes: "page-2",
                      feeds: [
                              title: "New York Times",
                              url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                      showSourceTitle: true,
                      showPublishDate: true,
                      broadcastNewsFeeds: true,
                      broadcastNewsUpdates: true
                  module: "MMM-HomeAssistantDisplay",
                  position: "middle_center",
                  classes: "page-3",
                      // Your Home Assistant configuration
                  module: "MMM-Cursor",
                      timeout: 3000  // Increased timeout for better touch experience
                  module: 'MMM-BackgroundSlideshow',
                  position: 'fullscreen_below',
                      imagePaths: ['modules/MMM-BackgroundSlideshow/exampleImages/'],
                      transitionImages: true,
                      randomizeImageOrder: true,
                      slideshowSpeed: 30000  // 30 seconds per background
                  module: "MMM-Pages",
                          ["page-1"],  // Page 1: Clock, Calendar, Compliments
                          ["page-2"],  // Page 2: Weather and News
                          ["page-3"]   // Page 3: Home Assistant
                      fixed: ["alert", "updatenotification", "MMM-page-indicator", "MMM-SmartTouch", "MMM-Cursor", "MMM-BackgroundSlideshow"],
                      animationTime: 1000,     // Smooth transition between pages
                      rotationTime: 0,         // No automatic rotation
                      rotationDelay: 10000,
                      touchMode: true,          // Enable touch support
                      useSwipe: true,
                      swipeSensitivity: 30
                  module: "MMM-page-indicator",
                      pages: 3,                // Now 3 pages total
                      activeBrightness: 100,
                      inactiveBrightness: 30
                  module: "MMM-SmartTouch",
                  position: "fullscreen_above",
                      debug: true,
                      enableCursor: true,
                      cursorTimeout: 3000,     // Hide cursor after 3 seconds
                      gesture: {
                          sensitivity: 15,     // Better for Raspberry Pi Touch Display
                          minSwipeDistance: 30, // Lower threshold for easier swiping
                          maxTimeThreshold: 1000 // More time allowed to complete swipe
                      touches: [
                              gesture: "swipeleft",
                              command: "NEXT_PAGE"
                              gesture: "swiperight",
                              command: "PREVIOUS_PAGE"
                              gesture: "tap",
                              command: "SHOW_CURSOR"
                              gesture: "doubletap",
                              command: "REFRESH"  // Allows refreshing the mirror if needed
        sdetweil @TheSteveBennett
        @TheSteveBennett where is smarttouch from? only one i see doesn’t have any config, and doesn’t do swipe
        https://github.com/EbenKouao/MMM-SmartTouch
        S T 2 Replies Last reply Reply Quote 0
          @TheSteveBennett also you should install
          MMM-ViewNotifications
          so you can see what events are being processed
          • T Offline
            TheSteveBennett @sdetweil
            @sdetweil That is the one I installed. How can you tell that it doesn’t support swipe and could you recommend one that does.
              @TheSteveBennett it has no config, i looked at the code
              i dont know where you got the config from.
              id look at the 3rd party list (linked above) and search on swipe
              there have bern a few posts recently(last monthish) on this topic
              sadly MagicMirror forum search stinks
                rkorell @sdetweil
                @sdetweil said in How to Swipe between pages:
                what I’m using regularly and works pretty well is external search via Google with limitation to site forum.mgicmirror.builders …
                Astonishing…
                Regards,
                Ralf
                  sdetweil @rkorell
                  @rkorell i tried that a long time ago , but wasnt happy
                  this time better, ill have to figure out some parms cause 2017 results before 2025 is not helpful either
                    @TheSteveBennett MMM-Touch was the module i was thinking of
                      seabass @sdetweil
                      Hi Sam, were you able to get the swipe functionality working and did you use the MMM-SmartTouch along with the MMM-Touch modules? If so, could you provide your code to get this working as I’m new to the Magic Mirror community and struggling to get this swipe functionality working.
                      Thanks!
                      Seabass
                        sdetweil @seabass
                        @seabass wasnt me trying to do swipe. i was trying to help the OP debug and find out what was going on.
