    LICENSE: on modules.magicmirror.builders shows @noassertion instead of MIT
    12 Posts 5 Posters 3.1k Views 5 Watching
      ASteinsdoerfer
      I added the MIT license to my github project MMM-HusqvarnaAutomower in package.json and as a LICENSE file but on modules.magicmirror.builders it is shown an @noassertion. So no screenshot will be displayed.
      What am I doing wrong?
      Andreas
      S BKeyportB karsten13K 3 Replies Last reply Reply Quote 0
        sdetweil @ASteinsdoerfer
        @ASteinsdoerfer @KristjanESPERANTO will need to help
        • BKeyportB Offline
          BKeyport Module Developer @ASteinsdoerfer
          @ASteinsdoerfer having suffered the same issue - there’s a slight formatting difference between your LICENSE file and mine (other than copyright name). Therefore, I think Kristjan is being too picky on the file.
          Maybe we can get a rethink on this.
          • karsten13K Offline
            karsten13 @BKeyport
            @KristjanESPERANTO
            AFAIS the wrong license is coming from the gitHubData.json file.
            So looking into https://github.com/MagicMirrorOrg/MagicMirror-3rd-Party-Modules/blob/main/scripts/updateGitHubApiData.js I stumbled over the line
            let maxQueryCount = 58; which is used in the shouldFetch function.
            Maybe I’m wrong but this looks like we only fetch 58 repos from github and then switch to historical data?
            KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
            • KristjanESPERANTOK Online
              KristjanESPERANTO Module Developer @karsten13
              @karsten13 is right. We only query GitHub data via the API twice a day - each time we can only make about 50 queries. The infos about a module via the GitHub API are therefore queried over the thumb every 13 days.
              The problem with this module was that it had no license file the first time it was called, then the API responds with NOASSERTION. This will be automatically corrected after a few days.
              It works and only in rare cases has such rather cosmetic effects, so it is not high on my priority list to optimise this. With authenticating we could make 5000 requests per hour. If anyone would like to implement this, please feel free to create a PR.
                karsten13 @KristjanESPERANTO
                @KristjanESPERANTO
                Thanks! Maybe I take a look into the authenticating stuff …
                karsten13K 1 Reply Last reply Reply Quote 1
                  karsten13 @karsten13
                  see https://github.com/MagicMirrorOrg/MagicMirror-3rd-Party-Modules/pull/65
                    karsten13 @ASteinsdoerfer
                    @ASteinsdoerfer
                    the problems (license and screenshot) are fixed.
                      sdetweil @karsten13
                      @karsten13 my screenshot is not displayed and dev advice page will not open
                      MMM-Config
                      license reporting is correct
                      seems all dev view is broken
                      took 45 seconds to open on my phone on wifi on 1g network.
                        karsten13 @sdetweil
                        everything working on my side …
                          @sdetweil said in LICENSE: on modules.magicmirror.builders shows @noassertion instead of MIT:
                          that is the wrong screen image…
                          How the image is selected is documented here:
                          https://github.com/MagicMirrorOrg/MagicMirror-3rd-Party-Modules#how-do-i-get-my-module-presented-perfectly-in-the-new-list
                            karsten13
                            click the hints for dev view bottom left
                            hint link works … looks like problems on your side …
