    Module to Display JSON data from a FILE
    21 Posts 3 Posters 5.1k Views 3 Watching
      sdetweil @mhr320
      @mhr320 there are at least 3 in the 3rd party list
      you will have to load the file via
      http://localhost:mm_port/… file
      file has to be in the MagicMirror folder tree
      you could use file links to reference a file outside the MagicMirror folder tree
      go to the 3rd party list (in the menu) and put json in the search field
        mhr320 @mhr320
        Thank you for replying. I forgot to put in my post I had searched for this type of module already, by simply searching for json on the modules page. I attempted exactly what you suggested with no results.
        The top of my config file looks like this:
        let config = {
        	address: "0.0.0.0",
        	port: 8081,
        	basePath: "/",
        	ipWhitelist: [],
        	useHttps: false,
        	httpsPrivateKey: "",
        	httpsCertificate: "",
        	language: "en",
        	locale: "en-US",
        	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
        	timeFormat: 12,
        	units: "imperial",
        I have attempted on four different modules [
        MMM-ValuesByNotification,
        MMM-JsonTable,
        MMM-JsonValue,
        MMM-json]
        using all of these paths plus other variations with no loading of localhost json data:
        "http://localhost:8081/MagicMirror/modules/file.json"
        "http://localhost:8081/modules/file.json"
        "localhost:8081/MagicMirror/modules/file.json"
        "localhost:8081/modules/file.json"
        "http://0.0.0.0:8081/MagicMirror/modules/file.json"
        "http://0.0.0.0:8081/modules/file.json"
        "0.0.0.0:8081/MagicMirror/modules/file.json"
        "0.0.0.0:8081/modules/file.json"
        Respectfully, thank you to anyone who provides advice or help.
          sdetweil @mhr320
          @mhr320 ok, I put a file in MagicMirror/modules
          fribble.json
           "items":[ {"test":"foo","xyz":"test"}]
          and used this URL
          http://localhost:8090/modules/fribble.json
          and got this
          so the path works…
          using this JsonTable module,
          then config would be
            module: 'MMM-JsonTable',
            position: 'top_right',
            header: 'HouseDB Sevensegment',
              url: 'http://localhost:8090/modules/fribble.json', // Required
              arrayName: 'items' // Optional
          and got this
            @mhr320 JsonTable expects a different format…
            I didn’t try the others… some are more flexible, some not
            i did not try with your data
              mhr320 @sdetweil
              @sdetweil Ok, I’ll get back to trying it, I must have messed up an entry somewhere.
                mhr320 @sdetweil
                @sdetweil So the path does indeed work, what was preventing me from seeing the data was the arrayName in the config. That does have to be set regardless of it saying it is optional.
                So that problem is solved, do you think I can solve the sharing of screen time for each of the three array’s in the json file via css or will that take some javascript? That was really what was important because the information is for my three kids and they each attend a different school.
                I really appreciate your help and patience.
                  sdetweil @mhr320
                  @mhr320 yes , the arrayName has to be set. had the same problem
                  sharing
                  well that gets a bit more complicated . this module doesnt support multiple instances w different urls.
                  if it did, then you could make three files or use different arrayName settings
                  then you could also use mmm-pages and display 1 each per child
                  i can add that support later tonight, pretty easy but. have grandson duty for a while
                    mhr320 @mhr320
                    Enjoy the grandson, i am of no importance! Thank you!
                      sdetweil @mhr320
                      @mhr320 rename the MMM-JsonTable folder out of the way
                      and
                      cd ~/MagicMirror/modules
                      git clone https://github.com/sdetweil/MMM-JsonTable.git
                      cd MMM-JsonTable
                      git checkout multiinstance
                      npm install
                      then in config.js
                      you can have multiple instances with the same url
                      and different arrayName (even the same,…)
                      then if you use MMM-Pages
                              module: "MMM-pages",
                                  rotationTime: 1000 * 20,         // rotate every 20 seconds
                                      ["family"],                // page 1
                                      ["kid1 name"], // page 2
                                      ["kid2 name"], // page 3
                                      ["kid3 name"], // page 4
                                  fixed: [                         // modules that are always shown
                                             "fixed"
                      then on each other module
                      add, after the module: line
                      classes:“xxxx”
                      xxxx one of the names above, family, kid1, kid2, kid3
                      for modules on every page use classes:“fixed”
                      above config has 20 seconds on each page… you can change that
                        mhr320 @mhr320
                        Absolutely Brilliant! Since I downloaded the multi-instance version of MMM-JsonTable from you, I assume it will not be available when updating. I will diff the original from yours and learn what you did to make it multi-instance and send that off to the author of MMM-JsonTable as a feature request. I really appreciate your help. It was nice to have a pleasant experience in a forum for a change, does not always go that way.
                        • M mhr320 has marked this topic as solved on
