    Module to Display JSON data from a FILE
    21 Posts 3 Posters 5.1k Views 3 Watching
      sdetweil @mhr320
      @mhr320 ok, I put a file in MagicMirror/modules
      fribble.json
       "items":[ {"test":"foo","xyz":"test"}]
      and used this URL
      http://localhost:8090/modules/fribble.json
      and got this
      so the path works…
      using this JsonTable module,
      then config would be
        module: 'MMM-JsonTable',
        position: 'top_right',
        header: 'HouseDB Sevensegment',
          url: 'http://localhost:8090/modules/fribble.json', // Required
          arrayName: 'items' // Optional
      and got this
        @mhr320 JsonTable expects a different format…
        I didn’t try the others… some are more flexible, some not
        i did not try with your data
          mhr320 @sdetweil
          @sdetweil Ok, I’ll get back to trying it, I must have messed up an entry somewhere.
            mhr320 @sdetweil
            @sdetweil So the path does indeed work, what was preventing me from seeing the data was the arrayName in the config. That does have to be set regardless of it saying it is optional.
            So that problem is solved, do you think I can solve the sharing of screen time for each of the three array’s in the json file via css or will that take some javascript? That was really what was important because the information is for my three kids and they each attend a different school.
            I really appreciate your help and patience.
              sdetweil @mhr320
              @mhr320 yes , the arrayName has to be set. had the same problem
              sharing
              well that gets a bit more complicated . this module doesnt support multiple instances w different urls.
              if it did, then you could make three files or use different arrayName settings
              then you could also use mmm-pages and display 1 each per child
              i can add that support later tonight, pretty easy but. have grandson duty for a while
                mhr320 @mhr320
                Enjoy the grandson, i am of no importance! Thank you!
                  sdetweil @mhr320
                  @mhr320 rename the MMM-JsonTable folder out of the way
                  and
                  cd ~/MagicMirror/modules
                  git clone https://github.com/sdetweil/MMM-JsonTable.git
                  cd MMM-JsonTable
                  git checkout multiinstance
                  npm install
                  then in config.js
                  you can have multiple instances with the same url
                  and different arrayName (even the same,…)
                  then if you use MMM-Pages
                          module: "MMM-pages",
                              rotationTime: 1000 * 20,         // rotate every 20 seconds
                                  ["family"],                // page 1
                                  ["kid1 name"], // page 2
                                  ["kid2 name"], // page 3
                                  ["kid3 name"], // page 4
                              fixed: [                         // modules that are always shown
                                         "fixed"
                  then on each other module
                  add, after the module: line
                  classes:“xxxx”
                  xxxx one of the names above, family, kid1, kid2, kid3
                  for modules on every page use classes:“fixed”
                  above config has 20 seconds on each page… you can change that
                    mhr320 @mhr320
                    Absolutely Brilliant! Since I downloaded the multi-instance version of MMM-JsonTable from you, I assume it will not be available when updating. I will diff the original from yours and learn what you did to make it multi-instance and send that off to the author of MMM-JsonTable as a feature request. I really appreciate your help. It was nice to have a pleasant experience in a forum for a change, does not always go that way.
                    • M mhr320 has marked this topic as solved on
                      sdetweil @mhr320
                      @mhr320 I submitted pull request
                      https://github.com/timdows/MMM-JsonTable/pull/98
                        sdetweil @mhr320
                        @mhr320 said in Module to Display JSON data from a FILE:
                        I am glad to hear that it worked out, and sad to hear the other.
                        as the moderator here, I am interested in feedback on how to make it better most of the time…
