    Module to Display JSON data from a FILE
    21 Posts 3 Posters 7.2k Views 3 Watching
      sdetweil @mhr320
      @mhr320 rename the MMM-JsonTable folder out of the way
      and
      cd ~/MagicMirror/modules
      git clone https://github.com/sdetweil/MMM-JsonTable.git
      cd MMM-JsonTable
      git checkout multiinstance
      npm install
      then in config.js
      you can have multiple instances with the same url
      and different arrayName (even the same,…)
      then if you use MMM-Pages
              module: "MMM-pages",
                  rotationTime: 1000 * 20,         // rotate every 20 seconds
                      ["family"],                // page 1
                      ["kid1 name"], // page 2
                      ["kid2 name"], // page 3
                      ["kid3 name"], // page 4
                  fixed: [                         // modules that are always shown
                             "fixed"
      then on each other module
      add, after the module: line
      classes:“xxxx”
      xxxx one of the names above, family, kid1, kid2, kid3
      for modules on every page use classes:“fixed”
      above config has 20 seconds on each page… you can change that
        mhr320 @mhr320
        Absolutely Brilliant! Since I downloaded the multi-instance version of MMM-JsonTable from you, I assume it will not be available when updating. I will diff the original from yours and learn what you did to make it multi-instance and send that off to the author of MMM-JsonTable as a feature request. I really appreciate your help. It was nice to have a pleasant experience in a forum for a change, does not always go that way.
        • M mhr320 has marked this topic as solved on
          sdetweil @mhr320
          @mhr320 I submitted pull request
          https://github.com/timdows/MMM-JsonTable/pull/98
            sdetweil @mhr320
            @mhr320 said in Module to Display JSON data from a FILE:
            I am glad to hear that it worked out, and sad to hear the other.
            as the moderator here, I am interested in feedback on how to make it better most of the time…
              mhr320 @sdetweil
              @sdetweil Hard to say how to improve things from our interaction. 5/5 Stars. I am new-ish to actively using this forum and wanted to give you props for your efforts, not sure if I did through any formal process, I tried to show the answer as the solution and attempted to upvote, but not sure if I did. But if you are the mod and jumped in to help me, that is a great way to make the forum better. Take care and enjoy the grandchild!
              S 2 Replies Last reply Reply Quote 1
                sdetweil @mhr320
                @mhr320 no… you said in " a " forum for a change, does not always go that way.
                I wanted to know what that was… was that HERE?
                we try hard to make sure everyone gets supported in some way
                  sdetweil @mhr320
                  upvote/downvote are restricted to user that have reputation 2 or above (means someone liked/upvoted your contribution twice)
                  this was we know reputation is not tainted with transient (mostly down) voters…
                  same as having all posts reviewed before live posting, til you rep is 2 or above.
                    mhr320 @sdetweil
                    @sdetweil Oh, in “a forum” was relative to another forum, this is the first time, in a long time, i’ve used this forum. HERE has been great every time so far, sorry for the misunderstanding.
                      @mhr320 the author accepted my change request
                      so you could go to the old folder (if you just renamed it) and git pull to get the update
                      then swap(rename) the folders and retry with his code again
                      and then delete mine
                        mhr320 @mhr320
                        Whoa, that was fast on both of your parts. I went to his github page and saw several old open “issues” i figured he’d be asleep on the project, but wow! It worked, great job sir! I really look forward to my next issue.
                        • T Offline
                          timdows @sdetweil
                          Thanks for the PR
                          Just approved the it, it did fail some prittier checks that I’ll fix later
                          Hope you’ll find it usefull over here!
                            sdetweil @timdows
                            @timdows you should add a git pre-commit hook to run prettier for whoever…
                            here is mine
                            .pre-commit
                            #!/bin/sh
                            FILES=$(git diff --cached --name-only --diff-filter=ACMR "*.js" "*.jsx *.json" | sed 's| |\\ |g')
                            [ -z "$FILES" ] && exit 0
                            # Prettify all selected files
                            echo "$FILES" | xargs ./node_modules/.bin/prettier --write
                            # Add back the modified/prettified files to staging
                            echo "$FILES" | xargs git add
                            exit 0
                            and an npm postinstall script to copy to the git folder
                            #!/bin/bash
                            #echo copying git pre-commit hook
                            cp .pre-commit .git/hooks
                            package.json
                              "scripts": {
                                "postinstall":"whatever you call it"
