    node clientonly for Windows
    9 Posts 2 Posters 1.2k Views 2 Watching
      mri_ice
      I’ve recently acquired a few Intel Compute Sticks and as a result am changing from a single Raspberry PI to a distributed architecture where I run the server within a Proxmox LXC and then use the Compute Stick (Windows) to connect to it.
      The server side is done and running but I can’t figure out how to get the client to work.
      With the “full” setup, there is the windows switch:
      npm run start:windows
      What’s the equivalent setting for the client only? I can’t find it in docs or forum posts. When I run
      node clientonly --address x.x.x.x --port 8080
      I’m getting
      Error: Requires environment variable WAYLAND_DISPLAY or DISPLAY, none is provided.
      Any hints greatly appreciated.
        sdetweil @mri_ice
        @mri_ice
        from the doc
        https://docs.magicmirror.builders/getting-started/installation.html#client-only
        because the system is running wayland
        you need to set the variable if not set
        "WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" node clientonly … rest of parms
        copied from package.json
          mri_ice @sdetweil
          @sdetweil said in node clientonly for Windows:
          “WAYLAND_DISPLAY=”${WAYLAND_DISPLAY:=wayland-1}"
          Hi Sam, many thanks.
          I’m confused. I thought Wayland was a *nix-thing?
          I’m trying to run the client on Windows 10.
          Do I need to set this up as an Environment Variable?
            sdetweil @mri_ice
            @mri_ice just responding to the message you got
            is windows on the stick?
              you can also launch a browser to the MagicMirror server
                mri_ice @sdetweil
                Yup, the stick is windows-based.
                Is there a :windows parameter similar to when you run the full npm start:windows?
                  mri_ice @sdetweil
                  This is what I’ve ended up doing for now, thank you.
                    sdetweil @mri_ice
                    @mri_ice if you look at package.json you can see the npm commands we defined in the scripts section
                    i copied the wayland stuff from there.
                      looks like electron (browser) is confused about the os running
