    MM Windows 11 install - 3rd party modules won't work
    9 Posts 3 Posters 1.1k Views 3 Watching
    • KristjanESPERANTOK Online
      KristjanESPERANTO Module Developer @lvolkjr
      @lvolkjr Show us the config of the module from the windows machine. Did you write apikey or apiKey?
      • L Offline
        lvolkjr @KristjanESPERANTO
        @KristjanESPERANTO
        				module: "MMM-OneCallWeather",
        				header: "Weather in San Ramon",
        				  latitude: "37.76470886457069",  // Longitude from https://www.latlong.net/
        				  longitude: "-121.9619230575287", // Longitude from https://www.latlong.net/
        				  apikey: "*mysecretkey*", // openweathermap.org API key
        				  iconset: "4a",          // Icon set to use.
        				  iconsetFormat: "png",   // File format of the icons.
        I just copied what you had on the example and then plugged in my information. I tried apiKey, because I was using apikey from the beginning, but still get the same error.
        S L 2 Replies Last reply Reply Quote 0
          sdetweil @lvolkjr
          @lvolkjr please always use code block around config entries, else the quote marks are changed and anyone copying the text will get junk. it also keeps the indentation of the source
          to use code block
          paste text into message editor, blank line above and below
          select the text just pasted
          hit the </> button to wrap in a code block
          for info
          code block is three backtics in a row starting in column 1 on line by itself, start and end of the block
          backtic is lowercase left of the 1 key on US keyboard
            @lvolkjr I copied your config and changed to my apikey and it worked as expected… (On windows 11)
            maybe you have missed a character in the apikey at the start or end on a copy/paste
            • L Offline
              lvolkjr @lvolkjr
              @sdetweil Thank you for all your help, I’ll be sure to use the Code Block in the future.
              I’ll have to go back to the default weather module, as the firewall I’m behind won’t let me use the OpenWeathermap api. It took me a while to figure out, but I found out what the issue was.
              Thanks again, Sam!
              • L lvolkjr has marked this topic as solved on
                sdetweil @lvolkjr
                @lvolkjr the default weather module, using the OpenWeather provider uses the same api url…
