    Issues with MMM-Button
    7 Posts 3 Posters 971 Views 3 Watching
      schlomm
      Hi all,
      After using my mirror for some some, I would like to add some custom features using the MMM-Buttons modules, forked / developed by @sdetweil
      After downloading and installing the module, pressing a button does not trigger the desired actions.
      Instead, some “beautiful” logs are coming after restarting my MagicMirror using pm2:
      2025-06-08 00:52:32.659] [ERROR] Whoops! There was an uncaught exception...
      [2025-06-08 00:52:32.667] [ERROR] Error: EINVAL: invalid argument, write
          at Object.writeFileSync (node:fs:2426:20)
          at exportGpio (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:18:8)
          at new Gpio (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:172:36)
          at Class.intializeButton (/home/pi/MagicMirror/modules/MMM-Buttons/node_helper.js:74:19)
          at Class.intializeButtons (/home/pi/MagicMirror/modules/MMM-Buttons/node_helper.js:90:18)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Buttons/node_helper.js:26:18)
          at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:91:10)
          at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:462:26)
          at Socket._onpacket (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:430:22)
          at /home/pi/MagicMirror/node_modules/socket.io/dist/client.js:214:24
          at process.processTicksAndRejections (node:internal/process/task_queues:85:11) {
        errno: -22,
        code: 'EINVAL',
        syscall: 'write'
      I’m using the latest MagicMirror release.
      Do you have any tips, where I can have a look?
      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
        schlomm @KristjanESPERANTO
        @KristjanESPERANTO I set up a fresh MagicMirror instance and checked the https://github.com/MarcLandis/MMM-Buttons repository. As a result I get the same issue:
        [2025-06-09 22:57:35.709] [ERROR] Whoops! There was an uncaught exception...
        [2025-06-09 22:57:35.718] [ERROR] Error: EINVAL: invalid argument, write
            at Class.intializeButton (/home/pi/MagicMirror/modules/MMM-Buttons/node_helper.js:89:19)
            at Class.intializeButtons (/home/pi/MagicMirror/modules/MMM-Buttons/node_helper.js:105:18)
            at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Buttons/node_helper.js:28:18)
          errno: -22,
          code: 'EINVAL',
          syscall: 'write'
        …Yesterday evening I tried to fix the issue of not beingable to control the MagicMirror using some buttons. Digged into the original module, asked help of ChatGPT, debugged some functions and as a result I have a running version for Bookworm.
        I’ll try to put this in a Github Repo - will update this thread as soon as I did :)
        @sdetweil You’ve said that I only need to change some settings in the rasp-config. Do you have any additional information what needs to be changed?
        KristjanESPERANTOK S 2 Replies Last reply Reply Quote 1
          sdetweil @schlomm
          @schlomm the bookworm os requires some configuration for the gpio pins. I think you can do this w raspi-config
          Edit: this is not correct, my mistake (Sam)
          I am not the author. I just fixed the Postinstall process
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @schlomm
            @schlomm Did you try the fork on the module list?
                errno: -22,
                code: 'EINVAL',
                syscall: 'write'
                @schlomm There is a PR that seems to fix the issue: https://github.com/MarcLandis/MMM-Buttons/pull/11
                  @KristjanESPERANTO Argh…I didn’t see that :-/ Nevermind…at least I’ve learned something about the Module…
                    sdetweil @schlomm
                    @schlomm said in Issues with MMM-Button:
                    I updated my post, I was incorrect
