    MMM-CountUP (COVID19 example)
    46 Posts 6 Posters 21.7k Views 6 Watching
    • plainbrokeP Offline
      plainbroke @sdetweil
      Try Your pages module running 51 modules, one every 90 seconds.
      DynamicWeather running in the background (cloudy today), was the one that made it impossible to see anything else. After I got it stopped my // it out and disabled: true, for it. I was able to see what you where talking about at least. I just missed the part where it showed the full name of the module as a clue as to how to format the code in the custom.css so that that MM could understand it… FYI you can not use the window with mplayer it covers the whole screen, had to kill it too.
      Bingo the CountUp module header is now big enough to read and orange.
      Thank you so very much Sam.
      I know you have to get tired of those of us that do not have a clue and do not seem to catch on over the years. You are good soul.
      Have a great evening.
      Just Jeff
        sdetweil @plainbroke
        @plainbroke glad you got it.
        i know there was doc about css somewhere
        ill find it eventually
          After messing with Confusius says for some time this morning. Using the window,
          I figured out why I was having so much trouble finding the correct code to use.
          my second half of the window you showed was not showing up, It was hidden.
          Now that it shows and I found my glasses. This should become easier…
          I don’t do it often enough to remember the details so we will see how I do down the line.
          Thanks for the coaching. It is really appreciated.
            @plainbroke that would make it a lot harder, lol
            see the second link in my signature below for a refresher
              @plainbroke and you can make another config.js with just thst module in it
              export MM_CONFIG_FILE=config/newconfig_filename
              npm run start:dev
              without touching your original config
              plainbrokeP 1 Reply Last reply Reply Quote 1
                That is what I eventually did.
                • 3 / 3
