    Error in the calendar module check logs for more details
    14 Posts 4 Posters 2.5k Views 4 Watching
    • NiggichN Offline
      Niggich @sdetweil
      @sdetweil I’ve got the same issue since today. Any other solutions? To change the fetchtimeout doesn’t help.
        sdetweil @Niggich
        @Niggich but it should recover and fetch again
        NiggichN 1 Reply Last reply Reply Quote 0
        • N Offline
          nowayto @sdetweil
          @sdetweil later I’ll try. The version is the last one
          • NiggichN Offline
            Niggich @sdetweil
            @sdetweil Today everything is working normally. I don’t know what happend yesterday.
              sdetweil @Niggich
              @Niggich network congestion probably… there have been some severe DNS denial of service (hacking) storms in the last few days
              • NiggichN Offline
                Niggich @sdetweil
                @sdetweil Ok, maybe. For me the problem is solved.
                • N Offline
                  nowayto @sdetweil
                  I’m sorry Sam, I didn’t figure out where I have to configure the
                  mmFetchTimeout. Where is it located? Thanks
                  H S 2 Replies Last reply Reply Quote 0
                  • H Offline
                    Hilt @nowayto
                    @nowayto
                    I put it here in config.js
                    			header: "Our Calendar",
                    			position: "bottom_right",
                    				mmFetchTimeout: 60000,
                      sdetweil @nowayto
                      @nowayto it is an environment variable
                      So you add it to the script used to launch MagicMirror
                      If using my installer and select pm2 then its
                      ~/MagicMirror/installers/mm.sh
                      Before the npm start line
                      For 45 seconds
                      export mmFetchTimeout=45000
                      • N Offline
                        nowayto @sdetweil
                        @sdetweil Did it. Hope it solve my issue. Thanks
                          sdetweil @nowayto
                          @nowayto if the network is busy, all kinds of problems
